Question about Directv H25 Component Cable & Composite Audio10 Pin Connector H2510pin -
H2510PIN DirecTV cable audio static
Using this cable with a slingbox 500 and am getting static crackle on the audio. video works great. Is it a bad cable or something else?
If Comcast is my cable provider and does not have component connections on their set top box am I out of luck in using my sling box?
No, if you have a SlingBox M1 or M2, you can use an HDMI to component video converter. Here is one example: https://www.bhphotovideo.com/c/product/770115-REG/KanexPro_HDRGBRL_HDMI_to_Component_Converter.html . You may need an to provide the additional HDMI and/or component video cables separately.
The Slingbox 500 supports an HDMI connection directly.
I hope this helps. Slingbox includes a link to one converter in the specifications for the M1 and the M2 on those product pages: http://www.slingbox.com/Products/SlingboxM1/Specifications and http://www.slingbox.com/en-US/Products/SlingboxM2/Specifications . Look on the right hand side of either page for that link.
Oct 03, 2017 | Comcast Televison & Video
No video or audio from HDMI inputs, (DirecTV and Xbox), rca aux input or Component input. Over-the-air HDTV from the Antenna is perfect audio & video
HDMI Input Problems - TV Not Showing Image - TV Repair ...
? 2:34
https://www.youtube.com/watch?v=ZtaUPX1tHP0
May 26, 2015 - Uploaded by ShopJimmy.com
Basic troubleshooting and replacement tips for HDMI inputs that are not ... video or audio from your HDMI port, you can take the source video ...
no signal? -hdmi - LG 55LE5400 tv - Forums - CNET
www.cnet.com > Forums > LG
CNETJun 14, 2014 - Sunday my husband hooked up an RCA ANT571 antenna with great results. ... The Roku first showed no signal on the TV. I tried hooking the Roku up to other HDMI ports, i changed the hdmi cables, .... Sound comes through, but not picture. ..... Video; All Video · Apple Byte · Carfection · CNET Top 5 · CNET ...
No sound on LCD TV - Desktop HDMI connection [Solved] - CCM
ccm.net > Forum > Hardware
Oct 11, 2012 - The video is excellent, but there is no sound coming out of my TVspeakers. ..... I also tried inputs besides the "HDMI 1" input and the other RCA ...
HDMI vs Component ' TVBlanket
Feb 03, 2016 | RCA Televison & Video
Audio Static on Sharp 32SC26B
Chances are your main board is bad, its where all the sounds are producted, a new board should correct the issue, its something you can install yourself with a screw driver, have the set unplugged for about a day before replacing the board so all the capacitors are discharged..you can get a new board at shopjimmy.
TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 09, 2018 | Sharp 32SC26B 32" TV
I had major static sounds from my yamaha stagepas 500. I plugged in an acoustic guitar into the mixer while running a keyboard and 2 vocal mics. I started getting crackling sounds. I changed the patch...
Chances are there is nothing wrong with the mixer. IF you accidentally turned on Phantom power, that would cause the problem. Phantom is ONLY used with condenser mics and a few DI boxes. Turning it on can create noise unless balanced lines are used everywhere.
Jun 29, 2011 | Yamaha EMX512SC Powered Mixer 500 Watts...
I have bad static from my Pioneer vsx 49 Elite
sorry no easy solution as it sounds like the output transistors blew out or the emmitter resistors. you will need a service manual and an multimeter to measure the resistors on or around the audio output transistors they are a low value resistor usually around 1 to 2 watts in size. Do not replace any bad , burnt or discolloered resistors around the audio output transistors as if tou do you might just cause more damage to the output transistorsor audio output stage including the audio driver stage of the amp!!!!!!
Larry Dillon
Aug 27, 2009 | Audio Players & Recorders
Screen shows staticy image on all components
Bad capacitors on the FMT pwb is what is most likely causeing it are the lines going sideways acrooss the screen, yet the menu appears normal.? If so its bad capacitors. You can get the V26 FMT repair kit at the following link which has the replacement capacitors and instructions on how to do the repair. You may also have an issue with the terminal 1 and terminal 2 pwb in that model as virtually every board within the chassis is plauged with Capacitors that fail. Heres the link.
http://servicemanuals.vstore.ca/
Jan 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No Audio
1. Make sure you have connected the cables from audio OUT on the Directv box to the audio IN on TV input 3 and have selected the correct source on the TV.
2. Many sat boxes have an audio volume control. Select the satellite box on the Directv remote and turn up the box's volume.
Hope this helps.:)
Apr 01, 2008 | JVC AV-56WP30 56" Rear Projection...
Static from right from speaker
The noise is in the pre-amp stages of the Denon AVR. It might be caused by bad capacitors.
Mar 08, 2017 | Denon AVR-1803 Receiver
Directv H25 Component Cable & Composite Audio10 Pin Connector H2510pin - Logo
23 people viewed this question
Top Directv Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Directv Audio Player and Recorder Expert? Answer questions, earn points and help others
