Vizio remote codes - Televison & Video
Urc-3021 manual
Jacqueline, Check the attached links codes for a vizio television, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remote Control Codes For Vizio TVs Codes For Universal Remotes
http://www.avsforum.com/forum/93-remote-control-area/710090-programming-remote-vizio-tv.html
Vizio TV Remote Codes
May 30, 2016 | Vizio Televison & Video
I need the codes for a vizio tv
The attached link takes you to Vizio's website and has codes for a Vizio Universal Remote. It gives you universal remote codes for practically every brand of tv, including Vizio. Hopefully that is what you are looking for. Have a great day!
Apr 26, 2016 | Vizio Televison & Video
My wave cable hd dta remote will not turn offandontv...repair guy said to ask vizio
Use the following instructions and code list to program your VIZIO Universal Remote Control. Press the TV (or device) button and hold for 5 seconds until the LED flashes twice. LED will remain lit. Find the programming code for your TV (or device) in the code list and enter it using the Number Buttons.
try a universal remote and program it, from the manual.
3 Digit Universal Remote Codes For TV Codes For Universal Remotes
4 digit GE universal remote control codes with code entering instructions
http://www.remotecodelist.com/
http://cdn.vizio.com/documents/downloads/vizio-universal-remote-codes.pdf
Feb 03, 2016 | Vizio P50HDTV10A 50 in. Plasma HDTV
Can I use your remote universal Llz414
Here is the Remote info
  • VIZIO Universal Remote Setup ' VIZIO www.vizio.com/remote-setup Point the VIZIO remote control at the ... Click the following link to view a complete listing of codes to program your universal remote. ... TV; Audio; VIZIO ...
  • Universal Remote Codes - Vizio cdn.vizio.com/documents/downloads/vizio-universal-remote-codes.pdf · PDF file UNIVERSAL REMOTE SETUP ... Find the programming code for your TV (or device) in the ... Point the VIZIO remote control at the device and press
  • Vizio Universal Remote Codes - TVremoteCodes.net tvremotecodes.net/vizio.html Vizio Remote Codes for TV, DVD, VCR, ... Uverse Remote Codes; Comcast Remote Codes; Dish Remote Codes; Universal Remote Codes; Apple Remote Control; ... VIZIO ...
  • The company started in 2002 as V Inc. by William Wang, Laynie Newsome, and Ken Lowe with $600,000 and three employees. In 2006 the revenue was estimated around $700 million, and in 2007 it was estimated to have exceeded $2 billion. VIZIO is known for aggressively pricing their HDTVs against major competitors.[2]
  • On October 19, 2010, VIZIO signed a 4-year contract to sponsor college football's annual Rose Bowl game in Pasadena, California, beginning with the 2011 Rose Bowl presented by VIZIO and ending with the 2014 VIZIO BCS National Championship Game.[3] When the Rose Bowl contract ended, VIZIO signed a contract to sponsor the Fiesta Bowl making the official name the VIZIO Fiesta Bowl.
    As of 2012, VIZIO has over 400 employees.[4] About half work at its headquarters in Irvine, California, in engineering, design, sales, and operations, while the other half are employed at a call center in Dakota Dunes, South Dakota.[4][5]
    VIZIO also manufactures its products in Mexico and China under agreements with ODM assemblers in those countries.[6]
    Her eis
    Dec 31, 2015 | Vizio L32 32 in. LCD HDTV
    Need code for my vizio tv i bought a ihip remote control for my tv
    The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
    Instructions
    Turn on the Vizio TV.
    Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
    Press the "TV" button at the top of the Jumbo Universal Remote.
    Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
    5
    Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
    6
    Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
    Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
    Not able to program vizio remote towork with att uverse Cisco box
    Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
    Mar 19, 2009 | Vizio VO47L 47 in. LCD TV
    Code for Vizio tv
    It looks like your remote takes a 4 digit code. Try the following codes:
    Vizio 0891, 0912,1783
    Feb 27, 2009 | Vizio VW37L 37 in. LCD HDTV
    Need vizio code for Samsung remote!!
    I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
    Jul 25, 2008 | Zenith ZEN700 Remote Control
    Code for Vizio tv
    I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
    Dec 26, 2007 | Vizio L32 32 in. LCD HDTV
    Televison & Video Logo
    Top Televison & Video Experts
    Electro Med Services...
