Question about Wildgame Innovations WGI Crush 12 Touch Digital Trail Camera WGI-FZ12
Cant get the camera fz12 to turn on - Wildgame Innovations WGI Crush 12 Touch Digital Trail Camera WGI-FZ12
Where do i turn the volume up at on my camera?
The C1450 records audio but will not play it back. To hear your videos you must transfer them to a computer and play them there or connect your camera to a TV. See the bottom of this page of the extended user guide.
Dec 28, 2012 | Kodak Easyshare C1450 14.0 Mp Digital...
I cant charge the battery through computer
The C183 isn't a battery charger. If you use rechargeable AA batteries in it, you must charge the batteries outside the camera using a separate battery charger.
Aug 01, 2012 | Kodak C183 Digital Camera
My olympus sp-590uz will turn on but is then frozen.
I have had a similar problem. My solution was to check the zoom button. It seems that when it is "out of range" you can do nothing with the camera. Try to adjust the zoom a Little bit and you will probably be "in range" and the camera with work.
Jul 01, 2012 | Olympus SP-590 UZ Digital Camera
Need a replacement remote for tower fan
CALL 1-800-295-4448 THE WILL SEND YOU A REPLACEMENT
GOOD LUCK
Jul 03, 2009 | Tower Aloha Breeze Fan
Cant turn on flash
It's the left button <, pressing it turns flash on and off. If the battteries are low it won't turn on. Here's a link to the online manual for your camera.
http://www.goaiptek.com/manuals/manual-pkdv4.pdf
May 03, 2009 | Aiptek PocketCam DV4500 Digital Camera
I cant find the on button
Open the Lens barrier to turn the camera ON and by closing the Lens barrier, you will turn it OFF.
Please let me know if that helps..
Thanks and Regards,
Srinivas
Apr 14, 2009 | Olympus Camedia D-390 Digital Camera
Camera screen turned off?
shadow filter is in need of adjustment please take into a camera retailer for repair
Nov 27, 2008 | HP Photosmart 945 Digital Camera
Cant turn it off
This sounds like a common problem with this product, I hear this one a lot and this also happened on my camera. One of the only solutions is to contact the company's customer support and tell them the issue.
Feb 24, 2008 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Camera won't turn on
ok a little water spilled in my bag but i took my camera out and completely wiped it off ..but now my camera is not turning quickly then when it does i cant turn it off, before it even got to the stage where it cant turn off messages like acrd locked showed up or the message e18 i need help its not even my camera
Feb 24, 2008 | Canon PowerShot A410 Digital Camera
It keeps making a beeping noise and wont let me record or do anything!
Try taking off the battery and reinserting it to see if it resets mech,If this doesnt work you wil have to bring to service.Dont go at it yourself as you could cause serious problems,
May 23, 2007 | Sony Handycam CCD-TRV68 Camcorder
Wildgame Innovations WGI Crush 12 Touch Digital Trail Camera WGI-FZ12 Logo
48 people viewed this question
Top Wildgame Innovations Video Cameras Experts
Are you a Wildgame Innovations Video Camera Expert? Answer questions, earn points and help others
