Question about Brother HL-2170W Laser Printer
Brother wireless printer offline
How to get printer back online
Basti
  • 1447 Answers
SOURCE: printer offline
Go to control panel and printers and faxes on your laptop and when you see the printer icon for the printer, right click on it and left click on use printer ONLINE. make sure then that the laptop is communicating with the printer.
Posted on Apr 13, 2008
SOURCE: how to switch from "offline" status to "online" status
I had the same problem with a Brother MFC-6490CW AIO printer. Here is how I resolved it:
Open the printers folder.
Right-click on the Brother printer and display the Properties page
Select the Ports tab.
In my system (Vista Premium), the selected port was a WSD port (whatever that means). Further down the list, there was a TCP/IP port that was obviously created by the Brother installation software. I selected the Brother-created TCP/IP port (which deselected the WSD port), applied the changes, and suddenly my printer was online. No idea what the difference between these two ports is, but I'll stick with the TCP/IP port until further notice.
Posted on Mar 02, 2009
SOURCE: Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
Posted on Apr 16, 2009
  • 7 Answers
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
Posted on May 17, 2009
SOURCE: Brother HL-2170W Laser Printer is 'offline" wpm
I had the same issue and searched ALL over the net for a solution and was thinking about returning the printer until I found this. It works, ALL of my computers are up and running with no issues at all. Just follow these instructions and you should be up and running in no time.
http://welcome.solutions.brother.com/bsc/public_s/id/pdf_pub/faq/faq002519/wireless_wcable_hl2170w.pdf
Posted on Sep 12, 2009
Brother MFC-J615W says offline
Go into control panel, open up printers and devices, select printers, find your printer and double click. When the printer comes up you will be able to choose that printer to be online.
Feb 07, 2015 | Brother Office Equipment & Supplies
The printer still says in offline mode
The Best Solution is with this Tool From Brother Official Site Download It and Follow The instruction :
https://www.mediafire.com/?te6hb9zxmf088tq
My Regards
Jan 14, 2014 | Brother MFC-J5910DW Color Inkjet...
Printer offline and cannot get it to print
Try this:
1: Go to start
2: printers and faxes
3: Right click on printer
4: Click on work offline ( this will put the printer online)
You are ready to go.
Hope this helps.
Regards,
Apr 14, 2011 | Brother DCP-585cw All-in-One Wireless...
Keeps telling me printer is off line when I try to connect wirless to printer
Check the wireless settings on the printer, to be sure that its wireless interface is connected to your wireless network.
On the printer, press the online/offline button.
Nov 17, 2009 | Brother Office Equipment & Supplies
The Printer will not come online
Usualy you have to set up the wirless in the printer driver settings before you go wireless. I suggest pluging the printer in make sure the drivers are installed and before the disconnect choose these settings in your advanced printer driver settings (if it is wireless) and then disconnect and reboot.
Sep 29, 2009 | Brother MFC 490cw Color Inkjet...
Offline wireless printer
Please make sure that printer is turn on, before doing ensure you do power cycle of printer.
Add printer on Standard TCP/IP port.
Sep 13, 2009 | Brother MFC 490cw Color Inkjet...
My brother laser printer 2170w is saying it's offline and I have no idea how to get it back online
just right click your printer icon in printer properties.it will pop out some options.in that options it will also pop out the offline option just click that offline option it will turn in to online option.if u find it hard just uninstall the printer drivers and reinstall it again from the printer driver installation cd.it will work properly.
thanks.
Dec 15, 2008 | Brother HL-2170W Laser Printer
Printer offline
Apr 13, 2008 | Brother HL-2070N Laser Printer
How to switch from "offline" status to "online" status
Oct 12, 2007 | Brother MFC-8860DN Printer
Brother HL-2170W Laser Printer Logo
24 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
