Question about Sewing Machines
Free sewing machine manuals
Feed dogs won't stay up
I'm trying to rewind my bobbin and its been so long since I've even got my machine out for anything. So please post me something that tells and shows me how to rewind a bobbin.
Posted on Sep 23, 2014
  • 8 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Posted on Jan 01, 2008
SewTechWayne
  • 186 Answers
SOURCE: Kenmore Sewing Machine Model #158.18032
You probably have a bind in the feed dog mechanism. If you can remove the covers and manually force them down you will see the hinge points that need to be oiled.
Unplug first!
Good luck.
Posted on Jan 30, 2009
  • 3 Answers
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
SOURCE: feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Posted on May 01, 2009
  • 13 Answers
SOURCE: How to Drop Feed Dogs on Sewing Machine...
On many machines you tilt the machine back on its hinges to see the underside and there you will find a thumbscrew to lower the feed dogs...you also need to be sure that your machine is capable of having its feed dogs lowered...not all machines can do this!
Posted on Aug 28, 2009
Yesterday, while machine quilting, I heard a clank. Now the feed dogs won't feed the fabric. The feed dogs seem to move back when I start sewing; it seems as if they stayed forward before...
Did you check to make sure the feed dogs weren't inadvertently dropped. Most sewists drop the feed dogs for free motion quilting or darning.
Oct 10, 2016 | Singer 4210 Inspiration Sewing Machine
How do i lower the feed dog for free motion sewing??
Oooh, consult your owner's manual. Frequently, industrial machines are limited in their capabilities so your machine may not have the feed dog lowering ability. Some other domestic machines without the capability can use a plate to cover the feed dogs while free motion quilting, but that probably wouldn't be a good thing to try if your machine is not made for sewing without the feed dogs in use.
Nov 05, 2015 | Juki DDL-5550 Industrial Straight Stitch...
I have an Elna 2730. the feed dog is not transporting the fabric anymore and the needle just keeps stitching in the same place. is it broken or just needs adjusting?
if you have a manual, look to see where the feed dogs are, if the lever for the feed dogs is in the up position then the machine will sew a straigh stitch
if the feed dog lever is in the down position then it will only stay in one spot,
if you try to push the lever up and it will not stay or stays and will not sew then the feed dogs need to be checked
Oct 09, 2013 | Elna Quilter's Dream 6003Q
The feed dogs are not moving. First time use
here are 2 links for a manual, just incase you don't have one
http://www.singerco.com/uploads/download/1287_1507.pdf
http://www.singerco.com/uploads/download/36952a1312a6d8436174ef874f3662471a946b64.pdf
check in the manual to see where the feed dogs are, see if the lever for the feed dog are in the up position so the machine will sew, it the lever is down,try pushing it the other way,if it will not go up and stay in position then the sewing machine needs to be checked to see if what's wrong with the feed dogs.
if it's a new sewing machine and the feed dogs won't work then take it back and get another one.
Oct 07, 2013 | Singer 1507
Machine sewing in one spot won't move and cotton jamming up
sounds like the feed dogs are in the down position, do you have a
manual for the machine that you can look at to see where the
feed dog lever is at and move it in the opposite direction,
if you don't have a manual, send me a commment with the name
and model number of the machine and I'll try to help you find a manual
Jan 25, 2013 | Sewing Machines
The machine won't stitch anything...
check the feed dogs in the needle plate area to see if there up,
if you can see them & touch them with your finger, I'm putting in a link
for a free manual, so you can see where the lever is to the feed dogs, just
incase they are not up. if they are up then they may need to be checked
to see why they aren't moving the fabric.
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
Jun 27, 2012 | Singer Curvy 8770 Electronic Sewing...
Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Apr 04, 2012 | Singer 4423 Sewing Machine
Can you tell me how to lower the feed dogs on my Brother XR-52 for free motion sewing?
You use your feed dog cover, it is a plastic cover you put over your feed dogs. Your manual will show you, if you do not have your manual go to www.brother-usa.com and select support, home sewing & embroidery group, then select your manual, you can then download your manual for free
Apr 23, 2011 | Brother XL-5130 Mechanical Sewing Machine
Dec 31, 2007 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
840 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
