Question about Asko Dishwashers
Asko f2 fault
Error
4 Suggested Answers
  • 641 Answers
SOURCE: Asko 1796 F2 problem
It sound like you have a blocked or a malfunction pump. Remove the pump from the machine and check whether you have a clogged inside the pump or in one of the pipes connected to it. In case all is clean, you should replace the pump.. Good luck !
Posted on Aug 27, 2007
Rotu
  • 175 Answers
SOURCE: Asko D3330 F2
there is water in the pan below the unit. You will need to take apart the lower section of the dishwasher behind the toe kick and suck out the water, or just wait for it to evaporate (few days) Good Luck!
Posted on Nov 06, 2007
  • 351 Answers
SOURCE: Asko 3350 F2 fault meassage keeps flashing
you have a blockage try the drain spigot under the sink or the pump may be blocked.
Posted on Jun 17, 2010
Message is Service call error 00010014 I have an Epson Stylus pro 9800 and I am getting a message saying: Service call error 00010004 error 00010004 SERVICE CALL 00010004DescriptionFailure of ...
Epson Stylus Pro 4400/4800/4880 Error Codes
Maintenance Request Codes:
• 0002 - CR Motor near end of life - Replace carriage return motor ASAP
• 0006 - Battery shut off - Replace RTC back-up battery
• 0040 - Cleaning unit near end of life - Replace cleaning unit ASAP
• 0080 - Date not set - Set the date through the printer control panel
• 0088 - RTC backup battery not installed - Install RTCbackup battery
• 0100 - RTC backup battery pressure is temporally low - wait for a while
• 0200 - The number of ASF paper feeding has reached predetermined value
• Service Call Codes
• 00000101 - CR Motor reached end of life - Replace carriage return motor
• 00010000 - PF encoder check error
• 00010001 - PF motor is out of step
• 00010002 - PF motor overcurrent has occured - Replace PF motor
• 00010003 - PF motor out of postion time-out error
00010004 - CR encoder check error - ensure enoder strip is clean & dust free
• 00010005 - CR motor out of step - click here for more info
• 00010006 - CR motor over current
• 00010007 - CR motor out of position time-out error - Replace the board assembley, main
• 00010008 - Servo interupt watchdog time-out error - Replace the board assembley, main
• 0001000A - Carriage home position detection error
• 0001000C - PG home position detection error
• 0001000F - CR motor PWM output faulty
• 00010010 - PF motor PWM output faulty
• 00010012 - CR overload (high sensitivity) error
• 00010013 - PF overload (high sensitivity) error
• 0001001B - Head Driver (TG) temperature error
• 0001001D - CR servo parameter error
• 0001001E - PF servo parameter error
• 00010020 - CSIC reading/writing error
• 00010022 - Ink type error (setting on printer body side)
• 00010023 - RTC analyzing error
• 00010025 - SCIS ROM communication error
• 00010026 - RTC communication error - click here for more info
• 00010028 - Head error - replace print head
• 00010029 - Unidentified NMI
• 0001002A - CR ASIC ECU error - Reinstall/update firmware
• 0001002B - PF ASIC ECU error
• 0001002D - Cleaning unit has reached end of life - replace cleaning unit
• 0001002F - 360 DPI writing time-out error
• 00010030 - Multi sensor error
• 00010031 - ASF phase detection error
• 00010032 - ASF drive switch error
• 00010033 - Eject phase detection error
• 00010034 - Eject movement error
• 00010035 - Pump phase detection error
• 00010036 - Type-B board installation error
• 00010037 - Head thermistor error - Replace print head
• 00010038 - Transistor thermistor error - Replace board assembley, main
• 00010039 - PG adjustment value incorrect overwrite error
• 0001003A - PG adjustment value outside range error
• 0001003B - Cutter installation error 1
• 0001003C - Cutter installation error 2
• 0001003D - Cutter installation error 3
• 00020000 - NVRAM error - Replace board assembley, main
• 00020002 - SDRAM error - Replace board assembley, main
• 00020003 - Boot program SUM error - click here for more info
• 00020009 - Flash memory SUM error
• 0002000A - Program load error
• 0002000B - The internal memory is insufficient
• 100000E0 - CPU address error (load)
• 10000100 - CPU address error (store)
• 10000180 - CPU reserved command code exception error
• 100001A0 - CPU slot undefined command exception error
• 100001C0 - The AC power is shut off
• 100005C0 - CPU DMA address error
• 10000xxx - CPU error
• 0003xxxx - Debug orode
• 0Dxxxxxx - An error code for debugging
• 0Exxxxxx - A time-lag of the RTC timer
Mar 24, 2018 | Epson Office Equipment & Supplies
Tip
Error codes related to Canon ir 2200/2800/3300
E000 Heater temperature fault
(fails to increase)
E001 Overheating detection error
E002 Heater temperature error (fails to reach
specific level; inadequate increase)
E003 Heater temperature error (abnormal
drop; low-temperature detection)
E007 Fixing film rotation error
E010 Main motor rotation error
E014 Fixing motor rotation error
E019 Waste toner case full, sensor error
E032 DA unit communication error
E051 Horizontal registration HP
detention error
E064 Power supply voltage error
(high-voltage error)
E100 Laser BD error
E110 Polygon motor rotation error
E202 No. 1 mirror base HP detecting error
E204 ADF image leading edge signal
detection fault (absent)
E220 Lamp ON error
E225 Standard white plate/edge white
plate read error
E240 Mcon-Dcon communication error
E243 Mcon-control panel
communication error
E248 Backup (EEPROM) error
E261 Zero-cross signal error
E302 Shading error
E315 Image data processing error
E601 Image transfer error
E602 Hard disk error
E604 Image memory fault
E605 Image memory battery fault
E606 HDD error
E674 Fax board error
E677 PDL board mounting error
E710 IPC initialization error (Rcon)
E711 IPC register error (ctrl)
E712 Communication error (with ADF)
E713 Communication error (with sorter
finisher)
E716 Communication error (with pedestal)
E717 Communication error (with ASSIST)
E719 Card reader, coin vendor
communication error
E732 Reader communication error
E733 Printer communication error
E737 SDRAM error
E740 Ethernet board error
E741 PCI bus error
E742 RIP1 board error
E743 Mcon-Rcon communication error
(Rcon detection)
E744 Language error
E746 Resolution conversion board error
E803 MPWS power supply voltage error
(low voltage error)
E805 Fan rotation error
E901 Pedestal main motor rotation error
[ADF]
E420 Back-up data read error
E421 Back-up data write error
E422 IPC error
[Saddle Finisher-G1]
E501 Communication error (Punch unit)
E505 Back-up RAM
E510 Feed motor
E514 Delivery motor
E530 Width plate shift motor
E531 Stapler motor
E532 Stapler slide motor
E537 Alignment motor
E540 Tray ascent/descent motor
E577 Paddle motor
E590 Puncher motor
E592 Puncher sensor error
E593 Puncher shift motor
E5F1 Saddle folder motor
[Finisher-J1]
E500 Communication error
E514 Stack handling motor
E530 Rear alignment motor
E531 Stapler motor
E537 Front alignment motor
E577 Delivery motor
E580 Delivery tray ascent/descent motor
E585 Stack handling error
If the thermistor has a short circuit, the indication in service mode
(COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC=250°C
for the main thermistor; FIX-E=310°C for the sub thermistor.
Error codes from E000 to E003 can be in some cases reseted from service mode: PROCEDURE:
Press*
Press2
Press8
Press*
Navigate to: COPIER>FUNCTION>CLEAR>ERR.
Turn off and on.
on Aug 03, 2010 | Office Equipment & Supplies
Codigo de error
List of Error Codes for Precor Fitness Equipment
Error Code List for Precor Fitness Equipment
Feb 05, 2014 | Precor Exercise & Fitness
Need a error list for a Canon IR 600 imagerunner
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Aug 07, 2013 | Canon imageRUNNER 600 Printer
What does F2 mean
Hello, Welcome to FixYa. To answer your question..."What does F2 mean ?", the good news...It is likely nothing very serious, but the "resolve" requires some investigation on your part. F2 means the control has indicated a overfill. This is meaning the overfill switch is indicating an overfill has been detected. Whether the unit has actually overfilled or not remains to be seen. It may in fact have been caused by a long drain or backed up drain. I'm presently on my iphone so I can't post the pertinent info to resolve the error directly, however if you copy and paste this link to your browser all the info will be there and it will apply to your model Asko as well. http://www.fixya.com/support/t7832382-f2_mean Either that or visit my profile page and you'll see other post relating to the Asko F2 error, its meaning and remedy. Hope this helps, let me know and good luck. Regards, Macmarkus :)
Jan 17, 2011 | Asko 24 in. D3250 Built-in Dishwasher
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
Dishwashers Logo
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
