Question about Maytag Refrigerators
Refrigerator manual model no. GT 1527 PACW where do i access the overflow line, so i can clear it?
2 Suggested Answers
miket756
  • 2702 Answers
SOURCE: water in bottom of refrigerator
get a lenth of plastic pipe and stick it into the drain inside the fridge then blow down it very hard,,,
dont **** on it its full of"""yuck""" you will here air coming out the other end when you get it clear start off looking just under the ice box for the drain pipe
Posted on Oct 26, 2009
How do i unblock the drain hole of my Miele kfn12823sd fridge freezer
Water is supposed to drain down a small drain line to a pan down near the compressor where warm air from the condenser fan will blow warm air over the water and evaporate the water again an put it back into the air inside your home, office or wherever your refrigerator is located. Over time that little drain tube gets slime, algae and a gooey white paste gunk that fills the drain line sides up like If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers. Gunk is an accumulation of algae slime and just crud that appears from nowhere in a refrigerators defrost condensate drain lines. This is not always the same with every model as you may see frozen ice flowing down the rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian. TechnicianBrian.com. And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Jun 11, 2013 | Refrigerators
Kenmore elite refrigerator
Leaking Refrigerators I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers. Gunk is an accumulation of algae slime and just crud that appears from nowhere in a refrigerators defrost condensate drain lines. This is not always the same with every model as you may see frozen ice flowing down the rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more simple in clip below. TechnicianBrian.com. And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
What is your model number? Kenmore model numbers look like this example=> 321.12345678
Jun 06, 2013 | Refrigerators
Icemaker overflows problem is worse when arm is in off position
All you need to do is turn water off until someone can replace the dual water control valve found on floor and back side of your refrigerator. You are going to need your model number so you can find the correct parts. Most Whirlpool Refrigerator model numbers are found inside the fresh food compartment and around the door. Whirlpool refrigerators made in the U. S. will find the parts manuals by going here=> User Manuals
A pace to find parts is by entering your model number=> HERE am not sure why many places have the dual water control valve with the photo of your ice maker. If you have questions I will be here so please ask. Thank You Sea Breeze
Feb 15, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Need a product user's manual for Maytage side by side bottom freezer refrigerator Model no. is 12670XEB3. Can't seem to find it on line ( model no. that is)?
If you ever need a Maytag user manual Click Here=> Manuals & Literature
Having your model number is very importatnt as having a serial number will not work, Thank You, Sea Breeze
Sep 12, 2011 | Maytag MSD2756G Side by Side Refrigerator
Water dispenser in not flowing as freely as before. What can I do?
There are only a few reasons your refrigerators water supply will cause this. Click Here=> ASD2624HES They are the water filter (If Applicable) Here=> UKF8001 water control valve=> 67005154 or water freezing before water gets to dispenser. Click here=> ASD2624HEW Use and Care Manual Then scroll down to page 18 in your PDF If you have not already downloaded Adobe Reader=> Adobe Reader X From there it is just easy to follow the user manual and instructions of how to check different components of your model. Check that someone has not crimped or folded your water supply line feeding your refrigerator. If you need more assistance I will be here to answer all questions, Thanks, Sea Breeze
May 18, 2011 | Amana ASD 2624 Side by Side Refrigerator
Our Kenmore Side by Side refrigerator ice maker is not working- I'm not sure I found the correct tag inside the refrigerator side of my side by side that said: model #596-526-79202 ... Serial#...
Well that is better model numbers than most people give! The first three numbers say the refrigerator is an Amana. Sometimes the Kenmore and the OEM number gets lost in the translation and it makes it a little more difficult to pick the exact model number by Amana. Sears Parts Direct you will need to put the numbers together like this=> 596.52679202 Repair Clinic can also convert model number to parts here=> 596.52679202 You can also go to Amana and begin your search by features=> sea_breeze_118.jpg Click Logo This is where Sears drops the ball and you will need to compare => side by side's French Door and then=> Literature again until you see your model number
Then=> Once you see your model click=> Literature
That breaks your model number into Use and Care (1616.87 KB), Warranty (126.21 KB), Dimension Guide (78.58 KB), Energy Guide (97.01 KB), Specifications Sheet (434.26 KB) Once you find the exact Amana Model Number I will pull the Service Manual up and need to contact you a different way because they will not let me post their Service Manuals here. Sea Breeze
I hope I have not confused you but that is the way you will need to get the answers once Sears changes the model number. Your model uses a=> 67003153 Ice Maker Assembly That ice maker is made up of components that sometimes fail. Here I leave you with a short tutorial. If you have further questions please contact me here or Fixya, Thanks, Sea Breeze
Mar 18, 2011 | Refrigerators
Drain Pan overflowing and water is leaking in refrigerator I can see drip pan overflowing but I do not know how to get to it
remove the back panel inside the freezer,then defrost the pan,then take a length of stiff wire and clear out the drain line from there down to the pan in the lower area near the compressor,as theres probably lime,mold growth build up in the drain line plugging the hose restricting draining of defrost water
Mar 03, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Water in bottom of refrigerator
Firs make sure that the drain exit in ur fridge and its receptacle are clear
Oct 26, 2009 | Refrigerators
Ice maker overflows from the back of the bin, water runs down and freezes into the entire compartment. I have cleaned it out, shut it down, checked that the water line is clear, checked the fittings. This...
depending on the model of the icemaker if you pop the front cover off there should be a screw with - and + symbols. Just turn it about half a turn towards the - symbol and that should take care of the problem
Sep 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore colspot freezer drain line keeps freezing
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Jul 17, 2009 | Refrigerators
Refrigerators Logo
56 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
