Question about JH Design Chicago White Sox Adult Wool Quilted Nylon Reversible Jacket
Wool coat treatment to not pick up lent
My wool coat wont stay clean and pick up lent and pet hair like a magnet
Y Shark "Professional" model 540 26 is making a terribly loud noise and not picking up dirt. t also gets HOT
Check( 'beater bar',suction tube to canister) for accumulation of hair,carpet fiber,pet hair,etc....cut hair,etc,with scissors,clean...might also be hair stuck in belt that drives beater bar
May 08, 2017 | Shark Vacuums
After having Matrix optismooth treatment done on my hair it won't hold hair color. Every time I shampoo I can see the color washing out. I am using permanent color? Why is this happening?
There are a lot of reasons that hair wont hold dye. One is what conditioner you are using before the dye. Some conditioners have silicon in them and coat the hair to the point that it wont allow any dye to penetrate. Another is the brand of dye, some dye is better than others, third is your hair type, this can be checked by a professional but some hair types respond to dye better than others and you have to keep trying to find a brand that works best for you,
Jul 09, 2016 | Matrix Health & Beauty
What's the best vacuum for pet hair?
Try a bagless vacuum cleaner as hair blocks up bags very quickly. One that is around 2000 watts should have enough power to do the job. As for the price check appliance stores for sales and deals.
May 31, 2013 | Vacuums
Grinding sound
You need to make a thorough inspection for debris and pet hair cloggin your vac. Could have ingested a load of kitty litter or....
Jan 20, 2013 | Bissell 1622 Powerlifter Powerbrush...
How often should I brush my dog?
I brush my own dog once a week and I got a short hair breed (American foxhound). Brushing loosens dirt and helps to keep the coat shiny and tangle-free. The brushing process also allows you to bond with your dog better.
Aug 15, 2012 | Pets - Others
What is the best pet grooming tool besides shampoo?
My favorite grooming tool is the mitt. It is a glove that you wear and swipe alongyour dog's coat. It is good for allkinds of dogs, big, small, and even smooth or wire haired. It is rubber so it collects stray hairswithout scratching your dog. Dependingon how much hair it collects, they tend to stay on the mitt and not to falloff.
May 15, 2012 | Pets - Others
How do I removes scratches from a stainless refrigerator door? It is magnetic
Not very easily.. if it is not coated with a lacquer or polyurethane clear coat, you can buff it like paint. If it has a 'texture' or appears to be brushed or matte, then you have to try to match the pattern, or change the entire door appearance..
steel wool is good to do the brushed look with.. I'd use 0000 (4 O or 4 ought) I'd contact the mfg if it is a matte finish or lacquered.
and no, SS is not very magnetic try a small magnet against it..probably wont work..
Dec 28, 2010 | Refrigerators
The brush is clean and spinning but it isnt picking up anything and just pushing pet hair around.
You mentioned pet hair. Remove the brush cover and check for a plug (possibly pet hair). Sounds as though you have a plug somewhere and it's not allow the suction to pull it through. Also check your filter and clean or replace as necessary. Hint; Never let you container get over half full, it reduces the suction.
Nov 02, 2010 | Bissell 6591 Power Trak Revolution Bagless...
My Hoover pet cyclonic is no longer picking up pet hair
You need to replace the belt that drives the beater bar.
Jim
Dec 01, 2009 | Hoover Vacuums
Vacuum doesn't vaccum!
Sounds like there is a clog near where the hose conects to the lower brush part.. Try to look up in there.. Under the brush there should be an opening that goes into the hose.. There might be a clog there..
Jul 08, 2009 | Bissell Upright Vacuum - The Pet Hair...
JH Design Chicago White Sox Adult Wool Quilted Nylon Reversible Jacket Logo
12 people viewed this question
Top JH Distributors Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a JH Distributors Vehicle Part and Accessory Expert? Answer questions, earn points and help others
