Question about Singer Sewing Machines
Singer vivo machine bobbin cas came out dont know how to put it back
Just bought this machine sand know how to put the bobbin case back in.
3 Suggested Answers
  • 3 Answers
SOURCE: skipping stiches
1) It’s possible the machine is threaded incorrectly. Remove the thread completely and rethread the machine. Be sure to use good quality thread--don't buy the cheapest you can find. A good thread will help your machine perform better and your projects last longer.
2) Poor stitch quality can be caused by the needle. Make sure you're using a new needle that's right for the job. Many times machines are taken in for repairs and all they need is a new needle. If you can't remember the last time you changed the needle--it's past time. Needles should be changed at least every eight hours of sewing.
3) When inserting a new needle, make sure the flat side of the needle faces away from the bobbin area. For example, if your machine has a frontloading bobbin, the flat side of the needle faces the back of the machine. If your machine has a side-loading bobbin, the flat side faces the right side of the machine. Some older sergers require special needles that don't have a flat side. Refer to your owner's manual to properly install a serger needle.
4) Thread that shreds or breaks can be blamed on the needle. Use a good thread and make sure the needle eye is large enough for the thread type. Also use the right type of needle for the fabric;
5) The machine tension adjustments put stress on the thread so it doesn't simply flow through the machine. When the upper and lower tensions are balanced, the stitch forms correctly. Tension is easy to adjust--stitch on fabric samples with a different thread colour for the upper and lower threads. Observe the stitch, adjusting the tension until the stitch is formed correctly. As a general rule, adjust the upper tension first. If the stitch still isn't right, adjust the bobbin tension.
Posted on Feb 27, 2008
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
MY BOBBIN CASE HAS FALLEN APART AND I'M NOT SURE HOW TO PUT THE PIECES BACK TOGETHER.
Sounds like you are describing the hook. Perhaps the owner's manual would be assistance. We don't know the make/model of your machine so are really unable to help. There are some videos on YouTube that show how to install a shuttle and bobbin case, but machines differ.
Set up the shuttle race for RS2000 Series
Brother LS30 Inserting Bobbin Vertical Shuttle Hook
How to Clean and Maintain your Sewing Machine at Home Front Loading Bobbin
Mar 14, 2016 | Sewing Machines
How to fit my bobbing casing?
Use your hand wheel and turn it. Monitor under the throat plate. The part you see moving will eventually show an opening. Stop there and install your bobbin casing. If it has a little metal piece across you will have to lift it slightly. After it is snug you can install the bobbin.
Mar 20, 2015 | Sewing Machines
Hi, i bought a used singer 20u sewing machine, but i couldnt use it because the bobbin case does not lock into the hook, and the bobbin is not very stay firm on the case, the thread is hard to pull once I...
since the machine is used, I suggest having the machine serviced
they can check to see why the bobbin case doesn't lock into the hook, the bobbin case may have to be replaced or it could be the hook needs to be replaced, the sewing machine shop will be able to tell you for sure.
May 29, 2012 | Singer 20u Sewing Machine
My bobbin keeps bunching up. I've changed the tension to 2, taken the bobbin case out, used a different bobbin....I don't know what to do. My machine is a month old and I've used it, maybe 4...
Put the tension back up to about 5. Rethread the machine entirely, and make sure you have the pressure foot in the up position when you rethread. If your getting bunching on the bottom, it's probably your top thread that's bunching up. After you rethread, put a small piece of fabric under the pressure foot, lower the pressure foot, and turn the handwheel in the forward direction and watch the thread as it comes around the bobbin case. If it goes around smoothly, try it with the foot control. If it hangs up as it goes around the bobbin case, you might have a burr on the black plastic bobbin case. Take it out, check for any burrs, sand them down, and try again.
May 07, 2011 | Brother SE350 Mechanical Sewing Machine
Viking #1 not #1+ , experienced sewer, tension is off and even though I have tried at 0 and worked my way up it doesn't seem to ever look even on the bottom bobbin thread. New needle, rethreaded, made...
These machines have a carbon fiber hook that get burrs or cuts in them from breaking needles or bent needles. Take out the hook (4 black screws on the black plate that surround the bobbin case) Make sure you don't drop or loose the SPECIAL washers that usually stay in the black plate. Check for any burrs or cuts on the hook. If you see any, you can sand them down with about a 500 grit sand paper, 600 would be better. Make sure you line up the tab on the back of the hook with the groove in the driver (the gray round piece). When you put the screws back in tighten them a little at a time. If you notice the screws have a shoulder on them and you can easily mistake them for being tight when there not. Make sure you turn off the machine and back on to reset the tension.
Apr 21, 2011 | Husqvarna Viking 1
I have a CE-4000 model. In the middle of sewing,
When you put back in the bobbin case, there is a little "knub" that sticks out with a flat spot on the right (on the top side of it) that you need to ensure it rests gently to the left of the position finger bracket (silver metal piece, in the square of the bobbin case area its on the right closest to you).
When you put in initially, it was probably twisted clockwise and there was a gap between the knub and the position finger bracket and when you put the needle plate on in jams that bobbin case in that position and the needle just takes chunks out of it..
You might need a new bobbin case, try sanding out the needle marks with sandpaper.
-Chirs
Jun 04, 2010 | Brother CS-100-T Computerized Sewing...
Bobbin Case Spins - in Huskystar C20
I had this problem when I first bought my machine. I took it in and they told me it was a recall problem. All the machines were having the same problem. They fixed it and I have not had the problem since. I bought mine at a Joanne fabrics. Hope this helps.
Mar 21, 2009 | Husqvarna Viking 1
Thread is 'snagging' in the bobbin case
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes.
Mar 18, 2009 | Sewing Machines
The boobin holder came out. How do i out it back in?
Mar 17, 2009 | Singer 5417 Mechanical Sewing Machine
Bobbin case
Get in touch with the whoever sold you wrong one to start with. If you still don't get the right one, try a dealer who sells that brand of machine.
Oct 23, 2008 | Singer 6038 Mechanical Sewing Machine
Sewing Machines Logo
678 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
