Hank Farrah - Computers & Internet
Does help me hank help people in new hampshire
no idea what HELP ME HANK is , here on fixya .
Sep 12, 2017 | Building Materials
Dean Cain played Kara's Earth-father? If so, that's a neat easter egg.
Yes, thats confirmed already he appered as Jeremiah Danvers on the First Supergirl Episode "Pilot" and in Flashbacks from Episode 6 Red Faced, as Jeremiah Danvers was recruted for the DEO by Hank Henshaw, also in this Episode it was discovered that Hank Henshaw was the last to see Jeremiah Danvers alive, means he is dead already and the Martian Manhunter promised the dying Jeremiah Danvers to look over his two Girls Alex and Kara, thats why the Manhunter poses as Hank Henshaw.
Sep 04, 2016 | Supergirl (2015)
Changed my ignition switch now showing a c42 code... help...
Hi, Farrah I would love to help you but the batteries in my crystal ball are dead and my mental telepathy headset is broken so sorry, I need the year, make, and model of your motorcycle please ask your question again and provide this information in the details box or comment section or edit your original question. Good luck and have a nice day.
May 27, 2016 | Motorcycles
Washing machine stops mid cycle
Farrah, this is commonly a supply problem. Here is how it goes: Hoses get hooked up backwards, no one notices, ...dad gets large hot water bill and shuts off the hot water (which is actually connected to the cold water inlet on the machine), then the machine needs cold water and stops until enough water is in the tub (measured by pressure, NOT time). the machine will wait forever...
clogged inlet valves can cause the same issue, but this is where you can start.
Jan 23, 2015 | Washing Machines
My truck was working fine then when I turned it off and I tried to start it again it wouldnt start and there was a clicking sound when i turned the key and the dash lights were flicking. do you know what...
Yes farrah I do know what is wrong with your car.
My name is Tom and I will work hard to make sure your problem is solved.
If you turn your car off, It is still very hot and things that get hotter expand. When the engine gets hot every part gets hot according to its metal make up. Therefore, the engines starter requires more current to turn the car over.
I would suggest getting the highest cold amperage battery that fits your car. Then I would invest in a "high torque" starter. You can call up any parts store and you can find out if they make one for your car or not. Install both and your problems should be solved.
If I can be of further help do not hesitate to call. If you did get the help you needed please reply
Tom(karatebb2)
Jun 29, 2010 | 2005 Chevrolet TrailBlazer
Perdi el cd de instalacion de mi labtec, como puedo descargar el software para instalarla es AWM E167925 STYLE 2725 VW-1 30V HANK
perdi el cd de instalacion de mi labtec, como puedo descargar el software para instalarla es AWM E167925 STYLE 2725 VW-1 30V HANK
Jan 01, 2010 | Labtec 961307-0914 Webcam
MOBILE HANK
re install active sync to fix problem - ensure all connection settings are active.
also...
buy an NEW battery
charge while OFF!
LED goes off when charging is done
Apr 18, 2009 | HTC P3300 Smartphone
Farrah again
1st You download Webcam Driver.
Farrah again
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jun 08, 2008 | MSI Starcam 370i Webcam
My cam is blurry
Hi Farrah from Trinidad. What country is this??? Any way I want you to take your cam in one hand and with the other one I want you to turn the lens with your finger. The black ring around the clear part. Now turn on your camera and do it again but real slowwwww. Hope I could help...PS send us a picture sometime James Jessee
Jan 12, 2008 | MSI Starcam 370i Webcam
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
