Question about Kitchen Ranges
Frigidaire how to
I replaced bottom element on frididaire model#cfef 312gsb electric range and it does not work. does it need a reset if so where is it
  • 833 Answers
SOURCE: My Frigidaire range display has gone out and the oven doesn't work.
sun, first test is to power the unit down. Find the pair of breakers which are generally 40 or more amperes. Turn them both off and back on. If this doesn't fix it, you will probably need a circuit board.
Posted on Dec 13, 2007
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
SOURCE: Frigidaire Electric flat top Range
My range will not hold the heat for either the convection or regular heat. the model number is CGLEF385AS2
Posted on Dec 24, 2008
ethelpilgrim
SOURCE: bottom element needs replacing
the side right side panel comes off three screws hod it on the back pullout
Posted on Feb 08, 2009
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
Frididaire electric stove the oven has stopped working
Good Afternoon Friend, thank you for allowing me to assist you!
I understand you are experiencing an issue with the oven of your Frigidaire range. May I have your model number please? You can normally locate the serial tag (which provides your model number) in the storage drawer, on the right side. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? Do the burners/elements work? With this information I can assist you better in pinpointing the problem.
Meanwhile, let's try resetting your range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn your range on. If resetting the power does not correct the issue, could you please advise me if the issue continues or provides an error code. Thank you! -Z
Sep 05, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
Top and bottom heating element does not work on Frigidaire electric range ES300
Usually when both elements are not working and everything else is working fine, the problem is your OCU (oven control unit), commonly known to consumers as the clock.
The clock controls the oven and most times does not produce an error code when it fails.
You will need the actual model number from a sticker located on the oven frame when you open the bottom drawer, the sticker will have the model and serial number clearly listed.
Do a Google search for that model number and find the clock.
I've provided a link for what probably is the proper clock but without the full model number I can't say for sure:
http://www.appliancepartspros.com/frigidaire-clock-316207529-ap3764682.html
Apr 05, 2013 | Frigidaire PLEF398AC Electric Kitchen...
HOW DO I TAKE BOOTOM BURNER OUT FRIDIDAIRE GALLERY CFES 388REB1
Hello rdbal - Most bake and broiler elements are typically held into place with 4-6 screws or fit(s) in a bracket like connection and then needs to be screwed down. However every unit is different so please contact a professional to move accurately for more information due to safety and liability reasons.
Nov 11, 2012 | Frigidaire Gallery GLEFM397DS Electric...
Cfef 372ec4 Frigidaire f 30 problem
Hi - Typically error code F30 for Frigidaire range indicates an issue with the sensor probe or the wiring harness between sensor probe and EOC. If you have already changed the sensor, I suggest checking the wiring or contacting a professional to move forward accurately. You can try resetting the unit and see if the error code will clear. You can either unplug the unit or flip the household circuit breaker off. Wait approximately ten minutes and turn on the range. If issue continues, once again contact a professional to properly diagnose the unit.
Oct 14, 2012 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I have a TAPPAN oven, the bottom element does not work. I think I need to replace it. The model#MEF303PGWC serial#VFO1539095 How do i do this, can you send me a diagram and instructions. Do you know where...
You can do this repair yourself and you can save a lot of money by making the repair. We have parts for Frigidaire Ranges.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service when you are ready to repair and we will send you all the instructions you need to get it working again.
We answer our customers calls from 7 AM until 9 PM CST so call us when tou are ready and we will get your part to you asap.
Thanks, Ella
Nov 10, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
No heat on range or oven
The heating element is called Magnetone.You need to replace that.
Jun 13, 2009 | Frigidaire FEF366 Electric Kitchen Range
Oven does not come on
First, reset your circuit breakers. This is generally a pair of breakers with at least a 30 ampere rating. It is not your kitchen breaker. Turn them both off and back on. If this doesn't do it, you've got to look at the heat element. Does it look damaged, deformed, discolored? If so, remove it and bring it to the appliance guy to get it tested. Generally this is a couple of screws. Make sure power is off when dealing with this. Not the element? Then you've got the control board.
Nov 22, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Ranges Logo
234 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
