Magnavox flat screen
Menu is stuck on the screen, blocks the picture
pazman
  • 81 Answers
SOURCE: Connecting a converter box to my flat screen tv
converter box for what? cable? it sound like the converter box is bad.
Posted on Apr 08, 2008
SOURCE: magnavox 42 inch flat panel cannot get a picture
TV may need software upgrade. Go to menu, find instalation, find software upgrade, find. If version is bellow FL2D-r23 (#23) TV needs upgrade.
Get upgrade on the internet onto a USB flash drive. The file may be a ZIP file, if so, unzip to a folder in PC then put the file to the USB drive.
Turn TV on, plug in the USB drive, wait til the upgrade is finished. Unplug USB drive, turn TV off w/remote.
The TV will then turn on by its self and the upgrade is complete.
Hope this works
Posted on Nov 28, 2009
welcomejee
  • 10594 Answers
SOURCE: I HAVE MAGNAVOX 42" FLAT
Problem seems with power supply board of tv that is not working properly so you hear relay clicking sound. Replace power supply board in tv to solve its issue.
Local tv repairman will help you if you are not familiar with electronics stuff repair.
Hope these info will help you.
Let me know tv model number if you have additional question.
Thanks.
Posted on Dec 06, 2010
  • 608 Answers
SOURCE: Magnavox 42" flat screen clicks
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Kaufman605
Posted on Dec 13, 2010
vindicatedne
SOURCE: Magnavox 19MF338B/F7 TV fine yesterday, today no picture
A capacitor needs replacing, I fixed one I found in someones trash that had the same problem, A 330 microfarad capacitor (uf) rated at 16v (the damamaged cap just had a bubble shaped foil top that indicated it went bad. replaced it with another cap (high voltage rated for tv replacement cap) cost 1.99 and it all works Great!
Posted on Sep 07, 2013
I have a Magnavox TV with a gray box blocking the screen. HELP!
It may be in the captions menu of either the set or a box if used----look for in both TEXT and turn it off
Apr 01, 2012 | Philips Televison & Video
Picture Size
Keep in mind that not all programs and show are in widescreen format. When set to normal, you will get those black bars on the sides because the program is sized for the older TV's. Some TV's will have a zoom option, but that will cut off some of the top and the bottom of your picture.
Until everything goes widescreen, you are stuck in normal with those black bars or widescreen with the fat people.
I hate distortion in my TV image, so I am perfectly fine with my TV on normal.
Good luck.
Jul 14, 2010 | Philips Magnavox 42MF521D/37 Television
Magnavox 32MF321D no audio
Hi my name is Roety,
I can help you with your issue ,
You can check the setting for stereo/sap must be set to stereo
If all connections are good and the problem is inside the Tv you will need a new mainboard (or SSB, scaler), ck encompassparts.com
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Jan 29, 2010 | Toymax Magnavox 37MF231D 37 in. LCD TV
Magnavox 42 inch flat panel cannot get a picture
Hope this works
Sep 27, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
Picture will go out but audio stays on.if i turn it off and back on picture will return for about a minute and then the problem repeats itself. This is a Magnavox Model 15MF605T/17 flat screen tv
When the picture goes out, are you able to bring up the TV's onscreen menu?  If not, you have a problem with one of the video boards.  If the menu does come up, you may have a problem with the input/output board/cable you are using.  Does the picture dissapear when viewing another device as well?  If not, it could just be that one input or the cable connected into it.
Mar 23, 2009 | Televison & Video
No Cable Picture
Call the cable co. If your getting the cable setup screen from the tv...Its getting that signal from the box...The tv is fine.
Sep 14, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Lcd tv magnavox
You might have a timer set on the options menu. look under the sleep mode.
Mar 20, 2008 | Polaroid FLM-323B Television
Magnavox Mod. # HD 2715 C 202
Your set in in closed caption mode text 1....Go into your menu and un-do the closed caption mode.
Feb 18, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
