Question about Samsung HL-R5656W 56" DLP HDTV
When you first turn on tv it makes buzzing sound even after picture come on and then it will stop and won't make noise again until next day when first turn on
Then makes noise again and will stop after a few min.but picture and sound seem ok
  • 1694 Answers
SOURCE: No picture or sound after replacing lamp
Possible bad color wheel...
Pull the lamp out & look inside where the lamp sends the light-
does the color wheel look defective? If so,replace it.
Or, the lamp ballast may be bad.After that,usually replace
complete engine.
Posted on Oct 19, 2007
  • 49 Answers
SOURCE: Samsung DLP HL-R4266W..no sound or picture. TV is completely dead
Assuming the noise is a high-pitched whine, then yes, it is the color wheel.  If the color wheel goes out, the TV will turn on for a while, then turn off when it can't establish color wheel sync.  The color wheel has to be in sync with the mirrors on the DLP, so if sync can't be established, the TV turns off.
You can order a new color wheel from Sears or partstore.com (among other places) and replace it yourself, if you are so inclined.
Posted on Jan 24, 2009
  • 98 Answers
SOURCE: Repetitive Buzz
Need to check the cooling fan.
-- open the back cover & unplugg two of cooling fan socket(black & red wires or yellow & red wires)
If the noise still remaining, need to exchange the color wheel.
Posted on Feb 11, 2009
NRITORTO
  • 5 Answers
SOURCE: Buzzing noise
COLOR WHEEL OR COOLING FANS
Posted on Aug 09, 2009
  • 336 Answers
SOURCE: Constant buzzing even when muted
Hi,It sounds like you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Your part # is BP96-00674A you can find it here: http://www.discount-merchant.com/product-p/samsung-bp96-00674a-cw-enc.htm?1=1&CartID=0?Click=48173 and here's how to replace it: http://www.fixyourdlp.com/guides/samsung/bp96-01579a.php Have a blessed one and go girl power!
Posted on Apr 27, 2010
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
The TV just started making a loud buzzing noise last week, the buzzing sounds begins after the TV has been turned on for 15 or so minutes- the sound stops about 15 seconds after the TV is turned off. The...
This tv have a colors wheel. The tv colors wheel is dead.The buzzing noise is the cause of the colors wheel is spinning of is axis and rubbing sides of the motor.Hire a tv tech. for the job.Colors wheel is hard to replaced,because have to take out many other machanical parts,even before can change the colors wheel it self.
Aug 31, 2010 | Samsung HL-P6163W 61" TV
My RCA projection tv makes a loud buzzing, humming noise. Does as soon as turned on even before picture comes on, does not stop till tv is turned off.
buzzing noise is cause by small electrical arc inside the unit or a problem in your audio circuit.if you can open the unit up and check if its an electrical arc.
Jun 21, 2009 | RCA HD52W59 HDTV Projection Television
NO PICTUR JUST A BEEP SOUND
Shorted Horizontal output transistor caused by bad horiz
transformer....parts to replace = Asti 2078 ( 257805 ) xformer
and 237470 RCA xistor..............................T.
Mar 03, 2008 | RCA F36450 36" TV
Vizio Speaker Making a Buzzing Noise
My 32" vizio I bought a week ago does the same things.
Buy an external sound system for the tv. Turn the speakers off in the TV menu. Hook the sound system up to the out speaker hookups on the tv.
You will not only have better found, you will fix the speaker buzz problem.
Feb 19, 2008 | Vizio L32 32 in. LCD HDTV
Buzzing/Fizzing noise at the back of TV.
Sounds like arcing from the high voltage transformer. i don't not recommend using it until you have it looked at.
Jan 30, 2008 | Televison & Video
Loud buzzing noise
Yes,it sounds like the color wheel motor is going,and yes it satais on untill lamp cools down
Oct 13, 2007 | Toshiba 62HM95 62" HDTV
Freezer works fine...refrigerator section
Have you noticed more frost in the freezer than usual? It sounds like you may have moisture building up and freezing around evaporator fan. The fan blade hitting ice will cause the buzzing until it stops it completely or the evaporator clogs with frost and blocks airflow. If you have frost on food in freezer, check the door seals and make sure nothing is keeping doors from closing completely if you release them about 6" from cabinet.
Oct 07, 2007 | Amana ABB1927DE Bottom Freezer...
High Pitch buzz noise when plugged in and it doesn't turn on
The tv has a shorted component and that is why is making the noise,call a qualified technician to find it and dont try to use it anymore.Is not a fuse.
Sep 12, 2006 | RCA F25649 25" TV
Samsung HL-R5656W 56" DLP HDTV Logo
15 people viewed this question
Henry  Thomas
Henry Thomas
