Question about Maytag Washing Machines
I NEED TO REMOVE THE FRONT OF THE WASHING MACHINE T
IT IS A MAYTAG WASHING MACHINE, MODEL LAT 9400 AAE,
WE ARE HAVING A SLIGHT LEAK IN THE FRONT OF THE MACINE.
WE BOUGHT THIS MACHINE IN 1992. USED 4 TO 5 TIMES A WEEK . IT HAS NEVER MISSED A LICK. I NEED TO REMOVE THE FRONT OF THE WASHER TO SEE WHAT IS GOING ON
    Scholar:
  • 85 Answers
There are 2 screws down toward the bottom of the front of your washer. You remove these and grab the front panel and pull toward you and up and the 2 clips at the top will snap out. Hope this helps!
Posted on May 20, 2009
Maytag washer lat8600
That model doesnt come up on Matags web site?
Nov 25, 2013 | Whirlpool Washing Machines
Maytag clothes washer model 2500 aae leaks along bottom edge
Sounds like a hose leak inside the machine. Possibly remover front bottom cover then check all hose connections.
Nov 14, 2013 | Maytag Washing Machines
LAT 7793 ABL model number. Washer leaking during fill...? a seal or gasket but not sure how to remove the spin bars to access it
On Your washer to locate a leak, remove the front panel first. Should be two clips at the bottom of front panel, use a putty knife to pry them down while pulling lower of front panel forward (older models used two screws right through front panel on left and right sides). After getting both lower clips loose, pull bottom of front panel forward to remove from top.
Set front panel aside and then use a 3/8" socket or nut-driver to remove two screws (one each) in the front right and left corners that secure the top to the side panels of the washer (inside in front corners going upwards). After screws are removed slide machine away from the wall about 8-10" and lift front of top up. Will pivot up like the hood on a car. This will allow you to examine machine for leaks.
Let me know when you come up with leak location if you need any more help!!
Jun 30, 2010 | Maytag LAT3600A Top Load Washer
Maytag LAT 9614AA3 small leak
It is most likely to be a slight crack in an outlet hose to or from the pump.
To identify where exactly to start looking, dry under there, then slide a big piece of cardboard under and do a wash.
Keep pulling out the card to inspect for drips.
You will then identify the area to start looking.
Turn off and unplug before pulling out the machine and tipping it back to inspect underneath with a torch.
Have an assistant handy to prevent it falling and help.
Once you identify the problem area, order a spare part before removal - as it may be a while before it arrives.
Feb 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
LAT 9400 AAW no motorized funtions only fills up
The only other thing it would check is your pressure switch. This will case a no agitation issue. If you remove clear pressure switch tub from the tub and blow into it you should hear a click from the pressure switch. With power your motor may agitate. Also check to see if the tube is clogged. If the issue is not in your pressure switch then i would have to assume the problem is in the timer. If you can read the schematic (usually located behind the control panel you could check to see if you timer is sending 120v down to the motor.
Hope this helps _MJ_
Jan 29, 2010 | Maytag Washing Machines
How old is this machine
I have the lat 9334 aae washer and still have my sales slip from 12/20/1994. Still runs like a top! Hope that helps!
Nov 24, 2009 | Maytag Dryers
My model number is LAT 9593. The machine will fill, wash, but will not spin. I smell a slight electrical burning smell.
It sounds like your motor has failed. Let the washer sit unused for a day. then turn the washer to spin. Sometimes the motor will start cold. Replace motor.
Jul 01, 2009 | Maytag Washing Machines
When washer finishes there is a dripping of water inside unit
What has happened is you have sand in your water valve from your water. This pluggs the water valve and also sticks it open so when the water valve shuts of there is still a small trickle of water coming through the washer. Replace the water and it will fix the problem (no way of cleaning the inside of the valve.) Replace water valve.
Nov 24, 2008 | Maytag Washing Machines
I have a Maytag washer MOD # LAT 2300 AAE
If the machine does not start.
Make sure the circuit breakers or fuses are functional in the main electrical panel.
Try to turn them OFF and ON again.
You might need to check the thermal or non thermal fuses inside your washer.
If all appears in working order, you might have a burnt motor if no noise comes from it when you pull out the knob.
Apr 07, 2008 | Washing Machines
Washing Machines Logo
148 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
