Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a craftsman riding lawn mover 42" model #917270812
I need to know how to adjust the tension on the belt the belt is to loose when I engage the mower function there is not enough tension to move the blades I followed the belt diagram to a T. Is there a way to adjust the tension to make it tighter? thanks Paul
  • 10,865 Answers
Hi Paul It sounds like the belt is worn, stretched, or possibly just two long for your machine. Save yourself a lot of aggrivation by checking your operator manual and getting exactly the right belt for your mower.
You don't say how old your machine is but if it has been mowing for many, many hours, the tensioning spring may need to be replaced. If that is the case you can order a new one at Sears.com
Posted on May 20, 2009
Why belt dont engage when in gear and clutch is released
Either belt is not on right or one of the tension springs needs to be adjusted or it has come loose...
Jun 28, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Clutch chatter - Replacing the drive belt helped a little. Is there a way to adjust the clutch?
there is no clutch as far as I know on ride on mowers, there is just a tensioner pulley that works off the brake/clutch, to adjust it you have to depress the brake/clutch to take the tension off the belt then adjust the belt tensioner to apply more pressure on the belt. Also check the tensioner pulley as I have found that they split in two and the belt becomes loose as a result.
Hope this helps
Oct 20, 2013 | Craftsman YT 4000 42" Briggs Stratton 24...
Fitting new drive blet
just loosen the adjuster and when it loose pull-out the loosen belt and replace with the new one and retight the adjuster at exact belt tension
Jul 13, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman riding mower vibrates so bad when I engage the mower. How do I stop vibration?
Things you need to check, loose blades, blades out off balance, bad belt or loose belt, bearings in the blade mandrels worn.
Jun 29, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
HOW TO ADJUST THE CUTTING BLADE TENSION OF THE MOWER BELT.
There is no adjustment on the Craftsman mower belt tension. The tension is maintained by a spring. If the belt is to loose you either have the wrong belt or something is broken like a mandrel housing that holds the fixed pulleys in place.
Oct 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 42 inch 18.5 hp craftsman riding mower that has started jerking when in a pull .The belt is very loose and has never been changed. could this be the problem.Also can you ck trans fluid on this...
look under unit and check the pulleys may need an adjustment on the engagement pulley which is connected to the foot brake pedal if adjustment good than also check rear pulley unbolt rear cover to access sometimes bolt becomes loose if good and belt is damaged or stretched than replace belt
Aug 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I can't disingage the lever to cut grass on my craftsman riding lawn mover. Now because of this I can't start the mover.
the lever moves an arm on the deck connected to a pivoting plate holding the idler pulley. when you push up the lever, it pulls the pivot [and idler pulley] back and puts tension on the belt. if this pivot gets rusted, it sticks and won't release tension on the belt. find the pivot point and lubricate it thoroughly with oil, wd-40, or liquid wrench, then work it back and forth by hand until it is freed up
Aug 02, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
May 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
Apr 23, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,018 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
