Question about Home at Five Vertigenius Digital Rotisserie by Cuizen - Black
Vertigenius rotisserie wont rotate
Motor is not rotating
Ck rotation motor
Controller sensing wrong rotation of compressor. The 220 volt 1 Phase motor rotation can be changed. If this is a new compressor check to make sure all vacuum lines are tight and not cracked. The rotation error is caused by the lack of vacuum to the avpt transducer. The transducer may also be bad or not connected properly. check the connections to the transducer. Wiring and plastic vacuum line. If this is a unit that has had the motor replaced visually verify rotation of the motor. Rotation arrows should be on the unit. I believe rotation should be clock wise. If it is indeed motor rotation incorrect the motor tag should show the correct internal motor connections to make the motor rotation change> If not comfortable take it to a trusted motor shop.
Apr 28, 2014 | Ingersoll Rand Compressor, 5Hp 80 Vert...
DRYER MAKES HUMMING NOISE BUT WONT START
Sounds like the capacitor on the motor is faulty
Mar 21, 2014 | Kenmore Series 70 80 90 PN281798 Dryer...
My silver bullet helicopter wont take off, the top blade is spinning but the bottom one isnt
Kindly check the rotor carefuly.. there is one white/black color rotor fixed on the bar of Motor rotates whith motor and there is anoter rotator which attached parally with its i.e once motor rotator moves the another ones also moves (which connected with the rod of Blades) some times these rotators gets loose by time and makes the rotation of Blades weak. kindly connect the same tightly and check....
Jan 01, 2014 | Shuttle 9094 Emax Remote Control...
E3 code appears and unit wont operate Domain Air CSR5300
E-3 Indoor unit blower motor mechanism. Rotate blower motor manually. If rotate, check power to motor. If power is there, replace only fan-capacitor.
If hard to rotate, replace bearings or motor itself. If no power to motor, defective in PCB. Repair/replace PCB. Thanks and hope it's helpful.
Jan 22, 2011 | Heating & Cooling
All the sudden 3 Lights started blinking all together (Green,Yellow,Red) and the vents wont open aswell
Check indoor motor mechanism locked. Rotate manually. If hard to rotate, replace motor. If free to rotate, check for power to motor. If no power to motor,PCB problem. Helpful?
Jan 19, 2011 | Sharp CV10NH Air Conditioner
My new Dacor rotisserie motor quit working after several minutes.
You will have a difficult time with some parts but if it is the motor then an electric motor repair place can help, it should not be that bad of a repair bill. I am answering this, this way because I am assuming that you rotisserie item is balanced correctly and is not am odd shape that would be difficult to rotate.....or to large to hit the lid or shelves when rotating.
Jan 16, 2011 | Dacor 52'' Builtin Outdoor Grill Cover...
Whirlpool Ultimate care ii Dryer wont tumble
If your dryer doesn't tumble, check these:
Belt,
Motor,
Door switch.
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
Remove the belt,
Check for obstructions in the blower fan housing,
Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
Go here to see a diagram for your model:
one of two types. "H" or "J"
http://www.repairclinic.com/0079.asp#DiagramH
Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Dryer will not move but power good
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Oct 05, 2008 | Samsung 7.3 Cu. Ft. Super Capacity...
Cuisinart mini prep processor blade not rotating
Replace work bowl and blade - see if it resolves the issue.
Oct 29, 2007 | Cuisinart DLC-8S Pro Custom Food Processor
Home at Five Vertigenius Digital Rotisserie by Cuizen - Black Logo
101 people viewed this question
Top Home at Five Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Home at Five Kitchen Appliances - Other Expert? Answer questions, earn points and help others
