Home | GE | WJSR2070B Top Load Washer | How to lift the lid on ...
GE WJSR2070B Top Load Washer
Problem for GE WJSR2070B Top Load Washer
How to lift the lid on our top loading GE washer
By carlaking22 on May 20, 2009
We have a very basic GE top loading washer that sounds like a jet plane when in the spin cycle. Today it was making a rubbing noise while agitating and my husband wanted to take a look inside to see if he could spot a problem. Is there a trick to lifting the top of this washer. He thinks it should just lift up but can't seem to do it on this machine?????
Comments:
May 20, 2009
- Thanks
Best Solution
posted on May 20, 2009
Very Helpful)
justaskjoe
Rank: Guru  GE Expert
Rating: 85%, 1863 votes
It does just lift up but it is held in place with clips that are forced into openings so you have to use some force to separate the two.
slide a putty knife in the crack and work it around. as you do so it will start to open for you.
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
frcs68
Rank: Wiz
Rating: 82%, 973 votes
to get into the GE washer. you nee to unscrews the back and the control panel. left the whole machine sides of the washer and push toward the front. (The sides of the washer is clip into the button of the rail, there isnothing in the front).
Was this helpful?
Yes
No
Popular Solutions for GE WJSR2070B Top Load Washer
Questions and Unsolved Problems for GE WJSR2070B Top Load Washer
Do you recommend GE WJSR2070B Top Load Washer?
Answer
Answer
Wash doesn't seem to drain all the way, some of the time. I need to re-spin and re-rinse alot.
Answer
how to remove the front panel for a GE upright washing machine? Model: WJSR2070b. I have a leak from... (More)
Answer
Good Morning: my Ge washing machine won't spin
Answer
Would like to Find out HOW to Adjust the Leveling Legs on this Machine. They have a Machine Thread,... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE WJSR2070B Top Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14104
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
