Question about Drills
My new bright rc lithium ion battery wont charge
2 Suggested Answers
  • 66 Answers
SOURCE: makita lithium ion battery wont charge
does it have green blinking light when you plug it to mains w/o battery in it ?
Posted on Apr 12, 2010
Why does my light not charging
Lithium ION batteries are ususally rechargeable. The use mode for these batteries is that there
are a set number of recharges that equate to the life of the battery. Usually that life is
approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the
battery is used up, the maximum charge lessens which means where you may have had 8
hours of play time when the battery was new, you will only have 6 hours as the battery life is
used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge
left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never
recharge again or the max charge will be reduced to an insignificant amount of the original full
charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries
cannot have their batteries replaced.
Jun 05, 2014 | American DJ megapixel led high powered led...
18 v lithium-ion battery will not charge
The batteries were discharged too low. A lithium battery should be recharged as soon as you see a loss of power.
Jan 12, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
I bought 2 P103 lithium batteries and they will not take a charge from my one + (p110) charger. I was informed that these components are all interchangeable. Will the P103s work with the blue 18v ryobi...
That is true the One+ 18V Li-Ion battery packs will work in any One+ 18V Ryobi tool. However the Lithium ion batteries will not charge in the original P110 NiCd charger. You will need one of the the new series Ryobi One+ 18V "dual chemistry" chargers for that. The will charge both types of battery packs.
Feb 18, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
What Ryobi batteries p103 or p104 will a battery charger that came with my p100 batteries charge? Or will the charger work with these batteries?
If you have a P100 NiCad battery, the charger for that will not charge the new Lithium Ion P103 or P104 batteries. You need a specialised Ryobi Lithium Ion battery charger like this one
Jan 11, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Can you charge ryobi lithium batteries in a regular ryobi charger?
NO! Never charge lithium batteries in a charger designed for nickle based batteries like the NiHi your old charger was meant for. Ryobi did design the new Lithium charger to be backwards compatible so you can charge your older 18V NiHi batteries in the Lithium 18V charger.
Also note, NEVER miss-match the voltage, for example, make sure you are not trying to charge 12V batteries in an 18V charger unless the manufacturer has specifically stated that the charger is capable of multiple voltages.
Dec 25, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
My new 18v lithium batteries run out of charge after about 10 mins of continuous use is this about roght as my old Nicad batteries would go for about 20 mins this is using them with a drill driver with a...
This is not right. They should last much longer then that. I have one of the more expensive 18V lithium batteries (the one with the button on it that tells you if it needs charging or not) and I can use mine almost all day before it needs to be recharged. I do construction work and I use my Ryobi products almost all day. Either both batteries are bad (I don't believe that is the case) or the charger is not charging them all the way to a full charge. With this charger, you do need to make sure that you remove the batteries as soon as the green light comes on. It is not good on these batteries to stay charging after they are fully charged. You also should not leave the charger plugged in without any batteries charging.Please tell me more about the charger. When you plug in the charger, does the red light come on? When you plug in a battery, does the red light stay bright and the green light blink? Does the red light go off and the green light stay on bright when you remove it from the charger?
If the charger is not working correctly, then return it for a new one.
Nov 26, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Will a nicd charger work to charge lithium-ion batteries?
no, I would not try this. You can charge a nicd battery on a lithium-ion charger but not the other way around.
Nov 25, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Battery wont charge green light and orange light come on but no charging happens, i have 3 other of the same batteries and they charge and work fine.
Is this an old battery? Batteries can fail and not charge after a lot of use. If it's new, run it all the way dead, then try to recharge .
Jul 03, 2009 | Ryobi Two 18V Lithium-Ion Batteries +...
I'm trying to find out if the new 19.2v C3 Cordless drills batteries are interchangable with the original 19.2v cordless battery. Also the new ion lithium batteries, Can the be used in old 19.2v drill?
I "m 99% sure Milwalkee is the only company that is interchangable..lithium ion and Ni cad ......... the new Milwalkee Lithiom ion chargers will chare both lithium and nicad, but the ni cad chargers will not charge lithium ion. Thanks Hope this is helpful!
Dec 10, 2008 | Drills
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
