Question about Drills
My new bright lithium ion battery wont charge the green light just blinks
2 Suggested Answers
  • 66 Answers
SOURCE: makita lithium ion battery wont charge
does it have green blinking light when you plug it to mains w/o battery in it ?
Posted on Apr 12, 2010
Are all the Lithium batteries working like this. Mine work for a short time then stop dead. Wait a while then they will work again. Really a pain when you are working trying to do somthing and have to run...
I use the Ryobi Li-Ion tools the L-I batteries will cut off when they get to a low charge level this is to protect the batteries Li-Ion batteries life span is shortened when fullt discharged so when the tool suddenly stops put the battery on charge,also if the battery has a charge indicator light for a more accurite idea of the charge (green is charged,red discharged) hold the test button on then run the tool the light may go from green to red if it does that shows the the charge is about depleted if the light stays green you have a little run time left.
Oct 25, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Is the green light supposed to flash while charging lithium batteries> just got the p113 charger but no instructions in the dang box
I have used alot of battery type drills and other action tools . Ryobi is on the lower end of the market as opposed to Milwaulkee and Dewalt . But my experience with battery operated tool charging equipment is that if the light is green and it's blinking , I would say it's charging . When the light goes off or stays on . I would say it's charged . Leaving the battery or batteries in the charging unit for 24 hours will not hurt the battery . My solution here is put it in the charger , and check it 12 hours later !
Electrician by Trade
Feb 20, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
My new 18v lithium batteries run out of charge after about 10 mins of continuous use is this about roght as my old Nicad batteries would go for about 20 mins this is using them with a drill driver with a...
This is not right. They should last much longer then that. I have one of the more expensive 18V lithium batteries (the one with the button on it that tells you if it needs charging or not) and I can use mine almost all day before it needs to be recharged. I do construction work and I use my Ryobi products almost all day. Either both batteries are bad (I don't believe that is the case) or the charger is not charging them all the way to a full charge. With this charger, you do need to make sure that you remove the batteries as soon as the green light comes on. It is not good on these batteries to stay charging after they are fully charged. You also should not leave the charger plugged in without any batteries charging.Please tell me more about the charger. When you plug in the charger, does the red light come on? When you plug in a battery, does the red light stay bright and the green light blink? Does the red light go off and the green light stay on bright when you remove it from the charger?
If the charger is not working correctly, then return it for a new one.
Nov 26, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
I have a digipower lithium power charger TC-U100 and cannot get my Casio NP-60 battery to charge in it. Am I inserting it wrong?
Maybe. This unit charges all different kinds of batteries, but that requires you to make sure that you have set the prongs in the right position to connect with the particular battery you are charging. You move two pins to align with the outer contacts on your battery (not the middle one) and then a spring door holds the battery against them. The unit sets the polarity automatically. 4 lights blink green until the battery is fully charged at 4 solid lights, i.e. 1 blinking light is a quarter charged.
Nov 22, 2010 | Mizco Digipower Lithium Ion Digital Camera...
Makita lithium ion battery wont charge
Apr 06, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Battery wont charge green light and orange light come on but no charging happens, i have 3 other of the same batteries and they charge and work fine.
Is this an old battery? Batteries can fail and not charge after a lot of use. If it's new, run it all the way dead, then try to recharge .
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 03, 2009 | Ryobi Two 18V Lithium-Ion Batteries +...
I put my battery on the charger and it wont charge it gives me a blinking red light
the lithium ion battery is bad there is not much you can do but buy a new one .
Apr 14, 2009 | Casio Exilim EXZ75 Digital Camera
Ryobi battery charger with a solid yellow and solid green light
I was recently told that the lithium ion does not like cold temperatures so you may need to bring the batteries and charge into a warm location and wait until they reach a warm temperature and then charge them.
Feb 25, 2009 | Ryobi Two 18V Lithium-Ion Batteries +...
Drills Logo
108 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
