Question about Bushnell Yardage Pro 800 Compact Rangefinder
Not picking flag up - Bushnell Yardage Pro 800 Compact Rangefinder
Scanner continues to search for a page after all pages have been scanned.
Usually the "paper empty" sensor flag gets stuck and does not return or "fall" to the empty position when the paper ends.
The flag is right next to the pad assembly.
Use a compressed air can to remove any dust-debris from the flag housing.
Because this flag uses gravity to return to empty position it might be usefull to use a spring to force it. Let me know if you need further assistance.
Feb 13, 2015 | Fujitsu fi-5120C
I have a Laserjet p4014dn printer. it warms normally but once it picks up paper, it jams. i have dried clearing jam several times but on starting to print it jams
Three areas you need to check.1.Pick up area: While pick up roller picking up the paper,delay pick or no pick causes paper jam..
2.Registration assembly area: Once paper picked from the tray, paper leading edge registered by the paper sensor located under the registration assembly.. In case this sensor dusty malfunction or flag damage, paper wont sense. result paper damage..
3.Fusing area. If the paper travels up to fuser area, check paper jammed before entering in fuser(Teflon not rotating properly, replace teflon sleeve) or just crossed?(check paper sensors in fuser unit, clean the sensors & check flags,flag springs.
Aug 31, 2012 | HP P4014DN Laserjet Printer
Printer says tray 1 low, but paper is not low
Most likely has something to do with the sensor the pick arm's flag. Try to check if the flag is moving freely. If it is, the sensor may need replacement.
Jun 23, 2010 | Lexmark T520 Laser Printer
How do i change the language back to english
Hit centre of screen select"change preference" Hit across arrow three times, top left hand corner are 3 flags. tap this to change language. then pick union flag.
Jan 11, 2010 | Tomtom ONE GPS Receiver
The printer will not pick up the paper
With injet/lower cost printers, a mechanical flag or lever is actuated by the paper. It can be an optical sensor as well, more likely in a laser.
The optical sensor can be gummed up with dust, or paper fragments. A mechanical flag or lever can be dislodged or bent by overloading or pulling jammed paper out, backwards to the paper path.
Your best tool is a bright light and a carefull visual inspection to see if anything is dislodged or dusty in the paper tray or in the receiver for the tray.
Dustoff will clean the dust, care should be used in readjusting the flag or lever.
Aug 24, 2009 | Office Equipment & Supplies
Will not pick up the flag over 150 yards.
You need an alignment. The transmitter and receiver are not pointing at the same spot. The farther the distance the bigger the gap between the two. Dropping the rangefinder and vibration are killers to Pinseekers. Bushnell will fix ya.....
Mar 12, 2009 | Bushnell Pinseeker 1500 Rangefinder
Unexpected message: 6B22
That is a pre heater fault.
Preheater exit sensor in unexpected state during fault.
Preheater exit sensor in unexpected state during stage.
  1. Check system grounds.
  2. Check the Drum Maintenance Kit NVRAM contacts during oiling for continuity.
  3. Check the waste tray.
  4. Replace the Preheater ( REP 2.0.17).
B2M
B2N
B2P
B2Q
The preheat flag tripped unexpectedly while picking paper from Tray 2.
The preheat flag tripped unexpectedly while picking paper from Tray 3.
The preheat flag tripped unexpectedly while picking paper from Tray 4.
The preheat flag tripped unexpectedly while picking paper from Tray 1.
  1. Test the Preheater Sensor using Service Diagnostics.
  2. Check system grounds.
B3M
B3N
B3P
B3Q
B3S
B3T
The preheat flag timed out waiting for the paper picked from Tray 2.
The preheat flag timed out waiting for the paper picked from Tray 3.
The preheat flag timed out waiting for the paper picked from Tray 4.
The preheat flag timed out waiting for the paper picked from Tray 1.
Preheater sensor timed out during stage.
Apr 17, 2008 | Xerox Phaser 8200 Laser Printer
Bushnell Yardage Pro 800 Compact Rangefinder Logo
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
