How to cook prawns - Computers & Internet
ANYONE Help?? Have rented a Holden Malibu. My stuff is in the boot. Some genious at Holden has hidden the boot release. The ice cream is melting and the prawns are .... Its been a long day.
There is a small button on the underside of the chrome trim above the numberplate which you use to open the boot from outside the vehicle. No internal button.
Aug 16, 2017 | Ice Cream Makers
2003biuick crv I cant read the computer.what can I do ?
You have to be able to test for power going to the scanner off of the OBD II plug ur missing positive or ground u can test it by using digital meter that is computer safe or test light that is computer safe one of the prawn should show positive and one should show negative see what is missing and supply to operate and test. Don't forget to test the fuses.
Good Luck
Dec 22, 2016 | Cars & Trucks
Moss ball, snails, and some water in a food bag, and put it in the freezer, had a look at the filter, and found 3 baby snails, in the feed pipe. after cleaning and putting new filter in the device.
shrimps are crustaceans like prawns , cr***bs , lobsters etc and they are the carrion ( dead flesh) eaters of the water world
If you want to make your own shrimp food you will have to research on google to get a good balanced recipe
you may talk with operators as to what food they feed their farm prawns , shrimps
only takes a phone call
of course you can always buy a packet of shrimp food and see what the ingredients are to start you off
Dec 13, 2016 | The Toys
I have 1998 che y s10,if i change computer do l have todo reset the one i puting one?
Normally you have to change the prawn which is a plug in to the computer to Identify you vehicle and its features to the computer. Check with the computer supplier for application and it should come with instructions so you don't short it out and how to ground it before you plug it in. Static is not your friend when it comes to this process.
May 31, 2016 | Chevrolet S 10 Cars & Trucks
How can I get access to pornografy sites on my iPhone4s
www dot you prawn dot com
Also prawn hub dot com
Change PRAWN for the correct word.
Oct 10, 2015 | Cell Phones
Just bought a dryer and it has 4 prawns I changed the cord to a three prawn as that is what my house is wired for. After I replaced the 4 prawn with the three prawn then the dryer wont heat up?
disregard the colors of the wires of the appliance as the dont respect any of regulation nor commun sense, do as follow red wire from the new wire to one side of the terninal bloc of the appliance it doesnt matter right of left, white to the middle of the same terminal block and the black to the other side of the terminal block, the green wire goes to the body of the appliance
Feb 27, 2015 | Maytag Dryers
How long do you boil prawns for
Depending on the size, prawns and shrimp should be cooked in a matter of minutes. Larger prawns will take a few more minutes.
You can tell when prawns and shrimp are cooked, as they will turn a pink colour.
As a guide, small - medium sized shrimp will take 3 - 4 minutes, large shrimp will take 5 - 8 minutes and jumbo shrimp or prawn will need 7 - 8 minutes cooking time.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 24, 2011 | Computers & Internet
How to wire 4 prawn 250 volt plug
The 2 wires coming off the double breaker should go to the x & y of the plug. The ground should go to ground (green or bare) and the other prawn left over is the neutral wire, it goes to the buss bar in the breaker box with the grounds ( usually with a bunch of white wires )
Apr 05, 2009 | Cooper Wiring Devices ACE AC-DC...
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
