Question about StarTech.com StarView SV211K 2-port KVM Switch
EUROVOX NOT SHOWING PIC
CODES FROM 7/5/09 ENTERED BUT NO PIC COMING THROUGH.......FULL SCAN AND AUTO SCAN DONE, FINDING CHANNELS BUT STILL NO PICTURE........HELP!!!
  • 134 Answers
**UPDATED 7th May 2009*
These are what I've been told are the latest codes.
C/W 5c-01 May 7th 2009
key 00 = A7 B2 EE 5F 9D D8 69 0E
key 01 = 3D 82 E6 58 8E 0D B3 62
T/W 5a-01 May 7th 2009
key 00 = AA B7 D1 D9 CE 8E 83 AF
key 01 = 8E 80 D7 EF 44 93 02 2B
PURE (UK) NTL 54-01 May 7th 2009
key 00 = 5C 2C 26 36 CF 81 AB 66
key 01 = 2C 10 35 AC 06 57 BE 6F
IRELAND NTL 54-01
KEY 00 =B0 B8 4F 04 E6 5F 87 80
KEY 01 =A3 EB EC 07 D6 49 D2 EB
IRELAND CHORUS 5E-01
KEY 00 =CE 19 2E 87 80 61 74 90
KEY 01 =62 FA D9 F3 CE 05 FA 79
Posted on May 24, 2009
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Apr 24, 2011 | Curtis Televison & Video
HAVE LOST MOVIE CHANNELS, ANYONE HAVE LATEST CODES TO BRING THEM BACK PLEASE N*L (SEPT 2010)
There have been no new codes for a long time (2008 i think)
The latest firmware can be downloaded from afterdawn or techkings.
If a full re scan does not get your channels back, Virgin has started to introduce Nagravision 3 in your area. This is being rolled out all over the country, there is no fix available, and from what i have read, there is not going to be any for this generation of eurovox/starview/digivox/arnet receivers
Sep 03, 2010 | StarTech.com StarView SV411K 4-port KVM...
Nead latest key codes for ntl pure 00 + 01 codes
hi thanks for your help i put the nos into my eurovox then i pressed scan took a while but im now back on full channels so give this a try it has worked for me thanks again
N.T.L. PURE
54 01
A9 5D 4E FE 20 E1 2D 03
88 6B 69 7E 94 B6 BB 1E
then after this do a scan it works, dont no for how long tho good luck
Dec 25, 2009 | StarTech.com StarView 2-port KVM Switch
Can any tell me how to setup a eurovox its the 2007 version ive scanned the channels theyve all came up but skysports, movies and all the other channels you pay for wnt come on. i used to have a starview...
Dont know if it helps or not but this is the method i used to set up the eurovox max when i first got it - it may work for you.
EUROVOX MAX SETUP
This is the method I use for setting up the eurovox max box but I have been told that it works for versions 1 and 2 as well
PLEASE NOTE : IF YOU ARE USING A SPLITTER IN YOUR SETUP THIS MUST B E REMOVED for the initial POWERSCAN as the box needs to scan from a pure signal- this will ensure all channels being found. – scanning throught a splitter can result in the loss of 50+ channels.
Firstly before you start to scan the box you need to:-
PRESS MENU
GO TO CONFIG
GO TO CLEAR DATA – IF IT ASKSYOU FOR THE PIN PRESS 0000
SELECT – ERASE ALL CHANNELS
Then it will ask you are you sure so press OK
Then wait a few seconds then press EXIT and EXIT again
What you need to do now is a POWERSCAN.
The following is a step by sep method of carrying it out!
Press the MENU button
Go to INSTALLATION and arrow right to USER INSTALLATION
Type in your pin (normally 0000)
Press the YELLOW button for POWERSCAN and change the mode to FULL from Normal by arrowing right to reveal FULL
Now press OK, this will begin the BRUTEFORCE POWERSCAN which can take up to 40 minutes,but it is guaranteed to find every single channel on the network in your area.
Once done the box will switch to a random channel to indicate it has finished !
You will now have around 240 or more channels (in some cases regions can receive up to 330 channels!)
You now need to switch to a non free channel and let the box update the codes – this could take a minute or two, it will indicate on the screen “updating please wait” once finished all channels will now be unlocked.
That’s it you’re all done … HOWEVER …. If you find that you get no channels at all there is a further adjustment you can make to ensure you get the 250 plus channels that your area box will be able to receive and again it’s quite simple to do!
First press MENU
Then go to USER INSTALLATION
Type in your pin (0000)
Press YELLOW button to POWERSCAN
Then change the mode to NORMAL
Then arrow down to the SYMBOL RATE and if its on 6.952 then change it to 6.887 (or vice versa!!)
Then press OK and it will carry out a scan like the powerscan of before.
If after you have tried this and you still are channels short then keep the symbol rate at the new figure but adjust the scan to FULL and try again.
Sep 16, 2009 | StarTech.com StarView SV211K 2-port KVM...
Eurovox Max V -codes required for basic channels on Chorus Dublin
Then you don't need codes. It won't amplify the signal and if it's weak it won't receive all the channels.
Sep 15, 2009 | StarTech.com StarView SV211K 2-port KVM...
Lost certain channels on Eurovox
run auto scan......please make sure you dont run power scan.....once scan is done you should get all the missing channels back.
Jun 02, 2009 | StarTech.com StarView SV211K 2-port KVM...
Did power scan by mistake and now no channels
restore to factory defaults and than delete all the data ( all the channels ) once done . run power scan and your box should be up and running again..... :)
Codes for Eurovox MAX v BOX GONE TODAY.CAN ANYONE HELP
codes are
5A 01
Just entered into my box and it works
May 07, 2009 | Televison & Video
StarTech.com StarView SV211K 2-port KVM Switch Logo
285 people viewed this question
Top StarTech.com Computers & Internet Experts
loftys0504
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
