Question about Bose Audio Players & Recorders
I had to replace the fuse in the tower unit and now the bass unit does not work when I plug it into the base unit on the tower.
2 Suggested Answers
SOURCE: The bass speaker doesnt work
OK, Bose owners out there listen up and listen good. Here's the real scoop on 1.(getting access to the inside of most bose subwoofers, 2.( repairing said subwoofer.
Follow these steps in removing the cover of your subwoofer. Unscrew the two screws from the cover. (They are on the input/output side of the cover) Remove the two knobs (Bass and treble volume).
On the opposite side of the cover, (put those damn shoes back in the closet) there is a lockout tab that needs to be swung out, it moves 90 degrees in a counter-clockwise direction and is located under the center of the cover.
A small flat blade screwdriver works great for swinging this tab out and will be necessary for the next step (the screwdriver that is).
On the same side (opposite the input/output side) there are two small tabs near the edges of the cover, one on the right and it's counterpart on the left. If you look closely in the gap between the cover and the sub itself, you will see these 3/8" wide tabs near the edges and towards the top of the cover.
With the flat blade screwdriver, put the blade between the cover and on the tab and pull down. Then with your hand balled into a fist, gently hit that side of the cover towards the input/output side. the cover will move only slightly but the tab should remain depressed.
Do the same procedure on the opposite side of the cover and it will slide about a 1/2 to 3/4" towards the input/output side and can then be removed by pulling it straight up and off of the cabinet.
Yay! If you get this far without incident then you are ready to implement repairs. In the case of the AM15's, normally what happens is a resistor will open up and prevent the triac (turn-on device) from firing.
The fuse is on the underside of the PC board and this above mentioned resistor is a 100 ohm, surface mount "chip" resistor on the top side of the PC board. It will not appear to be bad but trust me, if the fuse is good and the sub will not turn on... replace it!
You don't have to use a chip resistor since as a consumer you may have a rough time finding one but a 1/8 watt or 1/4 watt resistor you can find at any Radio Shack will work just dandy in this application.
Cut the leads short and solder the two cut leads to the pads on the circuit board where the chip resistor is currently sitting. The chip resistor will be black, about 1/4" long, 1/8" wide and have "101" printed on it's surface. On some models they used two 200 ohm resistors in parallel but the result is the same. One 1/4w axial lead resistor will do just fine. Plug it up and give it a try. (Before you replace the cover).
Secondly, if the fuse is blown on a "Lifestyle" Bose subwoofer, contrary to popular belief, it blew for a reason. The speaker outputs and the subwoofer output devices are TDA7294 IC's with TIP142 and TIP147 Motorola transistors used as current supplements to these said output devices. If the fuse is blown and replacing it only results in another blown fuse then chances are good that one or more of these are blown. In some cases it's very easy to tell, the front of these IC's will be blown off and/or you will see burn marks on the board where they are mounted. These devices are located inside the amp portion of the subwoofer. (The black metal heatsink underneath the input/preamp PCB. As a consumer, if the fuse is blown, unless you are familiar with soldering techniques and troubleshooting electronics, leave this to the pro's. It isn't as easy as you might think and you can destroy the PCB in your attempts to repair it.
 This was from a Guru of Bose systems at ecoustics.com: Mark Burgess
Posted on May 11, 2008
Repair parts for a base that broke
I'm not to sure but what you can do is buy a junk unit and use the bottom from that one to put on the good one, and who knows if another part breaks the junk unit most likely has that part to, usually it cheaper to buy a junk one than buy all the new parts separately
Jun 27, 2014 | Craig Tower Speaker System For iPod,...
Gigaset a420 has stopped making or receiving calls
You mean unplugged it from the power outlet or the RG45 wall jack? OK so if the battery is fine and you unplugged the power from the source, then the issue is with either the cord itself or the charging unit. Just because the little red light comes on does not mean it is working properly. Put a multi-meter on the charging tabs to double check for continuity. Sometimes and as weird as this sounds, it just takes unplugging a nearly spent power pack/inverter to finish the job so to speak. If you unplugged it from the RG45 then you need to look at the pins in the RG45 wall jack to see if you inadvertently bent one out of shape.Phone won't work if there's no signal. Wish I could help more. Good luck with that issue.
Dec 20, 2013 | Panasonic KX-TGA101S Cordless Handset
95 yamaha 90 outboard 2 stroke keeps blowing fuses
Motor should run with blown fuse,maybe faulty ign switch or short in harness plugs
Oct 12, 2011 | Light Outboard Motor Boat Bass Fishing...
This problem has to do with a Hartke 3500 bass amp. I recently purchased a replacement UCISC (the part with the female plug and fuse box) and replaced it. I tried to be very careful putting all of the...
Easiest way to check is to measure the resistance between the ground pin of your cord and the chasis of the unit. It should be very low. That is the only critical one... Look at a receptacle. See one bllade is wide? That is the neutral. The other one is the HOT side. The HOT SIDE should go to either the fuse or the switch first in your unit. If you have those right the third wire will be right.
When powering up an amp there often is a noise until the amplifiers balance out. Very high quality and high power amps have a relay that disconnects the speaker until balance is reached... but the smaller amps do noot have this feature.
May 02, 2011 | Hartke Bass Amplifier Half Stack with...
My Emachines computer switches on fine but the screen goes into hibernation mode and says "no Signal" as if the base unit isn't switched on (but it is). It's only 2 years old and has a Acer...
If the machine switches on fine then it means it passed the POST process. try to unplug it from the outlet and press and hold the power button for about 20 sec to drain the flea power see if that will take the computer out of hibernation. If that doesn't work you might have to reseat the memory from it's place.
I don't think there's something wrong with the screen the fact that it displays No Signal tells that the screen is active but gets no Valid signal from the tower.
Hope this helps!
Apr 17, 2011 | E-Machines eMachines Desktop PC
Samsung bottom mount refrigerator RB2055SW/XAC Canada. Symptom: Freezer temperature fluctuates between -5 and -20 degrees centigrade, regardless of temp setting. No ice buildup visible. Fridge is fine,...
The crisper can freeze when air leaks around the base of the duct assembly. To prevent this, the air tower will need to be removed. Disconnect power to the unit first. All the shelves and drawers will need to be removed, to access the tower. With the air tower out, now run a bead of silicone on the floor of the refrigerator where the tower sits. Now replace the duct on top of the sealant to make a tight seal and prevent the air leakage.
Jan 07, 2011 | Refrigerators
Kenwood vr-806 broke?
check your speaker balance and check that the bass isn't turned all the way down.
Mar 29, 2010 | Kenwood VR-806 Receiver
Force 90 outboard locked in forward gear after impeller replaced
i have fought with mine in the past also.
put lower unit and the control in neutral
remove all spark plugs and have a helper turn the fly wheel clockwise while you install the lower unit i had to use channel locks to put the lower unit to neutral
good luck i hope this helps
Apr 09, 2009 | Light Outboard Motor Boat Bass Fishing...
BassCube 12 Startup Problem
same here. happened after moving residences
Jun 30, 2008 | Cambridge Soundworks BassCube 12 Speaker
16 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
