Question about HP Photosmart C7280 Printer
Ink system error C7280 (0cx05d1281) rattle noise
Trying to find two noises in my 3ltr petrol 407 coupe, cold start rattle and rattle under acceleration especially from a slightly higher gear before kick down occurs. note diagnostics show anything.
Check the exhaust system from front to rear for torn or warn hangers, welds broken on any shields. That is if the noise is a metal noise or rattle. Please describe your noise if this doesn't match.
Feb 05, 2018 | Cars & Trucks
Rattling noise when exceleating
egr system not working causeing chain like rattle. nox gas to high.
Dec 16, 2012 | 1995 Ford Explorer
Rattling noise during operation
Often a rattling noise is because of a check valve in the system making noise...
heatman101
Jun 10, 2010 | Plumbing
Rattle noise when I let go of the accelerator. The faster I go and then slow down, the louder the rattle noise
Have a look at the shrouds around your exhaust system, they are prone to shaking loose and rattle on over run.
Try giving your exhaust a bang ( with your hand when it is cold) and see if it causes the noise . Follow the noise.
Sometimes the baffles fall off inside the muffler and rattle around inside too.
Happy hunting!!
Mar 31, 2010 | 2001 Toyota 4Runner
Engine Rattling
Try checking the heat shield on your exhaust system. You should have one over the manifold and one over your cat converter under the car.
Mar 25, 2009 | 1993 Oldsmobile Cutlass Ciera
Scanner is making a weird noise when printer gets switched on....
Have you looked at the paper to see if there is any stuck in the printer, other than that go and do the same thing as changing your Ink cartages but don't move any of them and set it up again and see if that works.
Rgs
The StickMan
Jan 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Rattle when accelerating
had the same issue, had someone look and it seems the noise was caused by heat shield being loose covering exhaust system. Have that checked out.
Jan 15, 2009 | 2005 Nissan Pathfinder
Service error 5C00
Service error 5C00 might indicate the purge system.
The "rattling sound " is probably coming from the (gears of-) socalled purge unit. May be one ( or both) of the ink tanks is not properly put back in again,or the printhead-lock is not locked. and the purge system is blocked.
Remove the ink tanks and remove the printhead, closw the printhead-lock, close the printhead cover, switch the printer of, switch the printer on again. If the rattling sound is still there, than you might have an expensive problem to be solved.
If the rattling sound is gone, there is probably something wrong with the printheadlock.
Mar 12, 2008 | Canon i80 InkJet Printer
HP Photosmart C7280 Printer Logo
50 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
