Question about Sony Rm-adp053 Remote Control
Rm-adp053 want to program the one touch play button for a sharp tv an my direct tv and sony blue ray
SOURCE: Samsung LCD tv and PS3
the problem is with the frames per second that the ps3 is putting out. i wound up calling both samsung and sony and the problem was in the settings. the ps3 allows you the option of playing in 24hz and for some reason if the option isn't turned off our tvs won't display frames at that rate. just go to the dvd settings and deselect the 24hz option, changing it from AUTO to OFF... the only problem i have with this is that this should effect the picture quality, becasue if it isn't displaying in 24hz that means it is downscaling the display and if it isn't upscaled by the tv's processor, then the display should be worse. i might be imagining it, but it does seem worse.. atleast they play now though. hope i helped.
Posted on Nov 10, 2007
SOURCE: Sony Rm-v202 remote the tv/video doesn't work
I need the code for operating an emerson television
Posted on Dec 25, 2007
  • 3 Answers
SOURCE: blue ray player wont play blue ray ''Kung Fu Panda'' disc.
i fixed this exactly as previous posted solutions, however a couple of points.
a) recordable CDs work if you don't have a DVD burner.
b) I didn't have a CD burner that would do an "image burn", I downloaded a free copy of "Express Burn" and that worked fine. The disk needs to be "finalised" or "fixated", it should do this automatically, or it may be a tick box selection.
c) I got a "No DWLD 09" when I put the disk into the player. I found this was an incompatibility with the CD-R (Maxwell) I was using. I changed to JVC and it worked fine.
Posted on Dec 29, 2008
  • 85 Answers
SOURCE: Need codes that will operate my ONKYO BLUE RAY DV-BD606 player
there is no sulution as far as codes are considered for blu rays. You have to do a manual learning mode for every button.you need to buy a learning remote this is where you point both remotes at each other and press each button to learn it. unfurtunately your sony remote does not have this funtion. i hope this clarifies your problem.
Posted on Feb 22, 2009
SOURCE: Have sony RM-AV3000 need code for direct tv Hr20-100s
how to program the remote control sony model RM-AV3000
Posted on Mar 16, 2009
I want to program this control remoto for blue ray and tv
go and download www.fitness.manualsonline.com or www.remotecodelist.com
God bless you
Jun 18, 2012 | Sony Rm-yd035 Remote Control
How do I program my Direct TV remote so my Apex ad-1200 dvd player works
How do I connect JVC DVD Video recorder RM-SDR107U remote to Sony TV?
Sep 11, 2011 | Apex Digital AD-1200 DVD Player
Hi i'm trying to programme my sharp stereo with a sony rm vz220 remote control. But can't get the correct code. The only code that i got was 60048. But it does not work.. Help plz..
According to the Sony Support site for this remote, receivers are NOT supported at all. Additionally, only a handful of codes are available for Sharp electronics. They are for the following devices:
Blu Ray, CD, DVD, DVD Recorder, TV and VCR.
All the codes used for the devices above are:
12250, 70034, 70037, 70180, 10630, 10675, 12250, 10675, 00818, 60048 and 60848.
You could try these codes one at a time and possibly gain some remote control capability - but that would only happen by chance. The codes above are the ONLY ones built into the RM-VZ320 remote for Sharp brand products, and if none work for your equipment, Sony says you should use your original equipment remote to control it. Not very helpful.
You can either do as they recommend, buy a pre-programmed remote that supports your device, or buy a pre-programmed remote that supports "learning". Learning remotes are universal in that the products not built in to the remote can be learned by holding the original so it points at the learning remote and pressing function buttons so that the learning remote "records" the buttons pressed on the original. It can take some time to do this, but you are assured that the remote will work with you device. Of course, you must have the original remote to do this though.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 25, 2011 | Sony RM-VZ320 Remote Control
I need the three digit code for my Sony BDV-E370 home theater remote controller.
The RM-ADP053 comes in the box with the BDV-370 and is preprogrammed with the codes to operate that unit. The manual can be found at Sony at this link.
To reset the remote control back to factory specifications, press the POWER , TV/VIDEO , and VOL- buttons simultaneously.
Jan 18, 2011 | Sony Rm-adp053 Remote Control
I'v got a sharp aquos and the blu-ray dont work on it the dvd's work? and dont no where to get it fixed can you help please?
The Sharp is not getting the go codes from the blue ray, or the blue ray is not sending them. Sony has a cool comcept to force you into buying Sony stuff. HDMI sends information down the cable that is caring the audio and video that tells the Sharp that its OK to allow the signal in. Some receivers, and or DAs do not pass this data, so the TV will not display the video and audio. Connect the blue ray player directly to the TV, and loop audio out to the receiver for the auio, and see whay happens.
Aug 30, 2010 | Audio Players & Recorders
Jan 10, 2009 | Sony RM-V302 Remote Control
Nov 19, 2008 | Sony RM-AAP001 Remote Control
Nov 19, 2007 | Sony RMT-V202 Remote Control
Sony Rm-adp053 Remote Control Logo
22 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
