Projects pink display
My projector has abrand new bulb unit but when I run my computer thru the projector is display everything in a pink color
    Scholar:
  • 134 Answers
Change the settings.
go to the signal menu and change computer input to rgb.
Posted on May 21, 2009
Pink/burgandy dots or shadow on display screen Our church has a new PLC-XU48 - has 70 hours on the lamp life. we use for both video and text display. Last night when we switched from video to text; we...
Does it go away when you switch back to Video? if so then the issue appears to be related to the text mode. Text mode is usually for showing microsoft office documents from your PC, that kinda thing. If you have text within a video then you should leave it on video. It is normal to get the odd pixel burn out and the colors change and look pink or bright, in your manual it will say what the acceptable limit is usually less than 1% i forget what the norm is but a possibility some of the pixels have burnt out, i doubt this is a bulb issue as the bulb just projects what is sees on the small display screen inside. Check the lens is clean, if the item is under 2yrs old you are actually covered regardless of what warranty came with it, more so if you purchased this using a credit card, see martins money shop website for details of how to make a claim via your bank to get full refund, all electrical items are covered for 2yrs against manufacturing faults. You can try resetting everything to default and see if this helps.... another tip, never turn the projector off at the wall straight away after using, you must let the bulb slowly cool otherwise it can break, so always power off with remote or power button then wait until the bulb and fan has stopped before turning off at the wall to prolong the life of the machine. If the issue was the bulk you would not be seeing anything, sounds more like an issue with the mode and media your using but if the spots appear all the time in all modes then it points more towards a manufacturing fault, the display being burnt out in parts, thats my guess.... although if this is the case the fault will show in all modes.
Apr 07, 2014 | SanDisk Sanyo Plc Wxu700 - Lcd Projector
Epson Powerlite 84+ has pink screen
the Green Lcd panel was break, you need a new one
We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jan 30, 2014 | Epson Corporati PROJECTOR, EPSON,...
Less than 1 year old Projector squeals and projects green screen (ceiling mounted). Filter not blocked - no warning lights lit. Should the fan run after the unit is turned off to cool the lamp? Other...
84+, the fan will stop while you trun off the projector ,at the same time
it is no problem
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Jan 25, 2011 | Epson Corporati PROJECTOR, EPSON,...
Projects a pink background image. Have tried resetting to factory defaults and replacing bulb.
try a brand new cable. if that doesn't fix it then your red lcd panel is probably burnt or the lcd cable isn't plugged in all the way.
Jun 21, 2010 | InFocus LP640 Projector Multimedia...
Duplicate image in pink displays on the screen.
From your description, it sounds like an alignment problem. There are 3 LCD panels in the projector. Each one displays an exact duplicate image of the others except it's either red, green, or blue. Under normal conditions, the images precisely overlay one another so you get a sharp image. Due to age, heat, or vibration/shock(impact) it would appear that the red LCD panel has shifted a little, giving the "ghosting" effect. You'll have to have the unit repaired by a qualified tech. He'll have the special electronic equipment needed to align the panels properly. Before sending the unit in, try a reset in the menu. Sometimes, the projectors can shift the image electronically, using math algorithms which will try to auto-sharpen the display. Hope I was able to help!---Rick
Aug 11, 2009 | Sanyo PLC XU35 Multimedia Projector
Faded color display
replace the colorwheel.
Jan 27, 2009 | Eiki EIP-3500 DLP Projector
LP70+ projects a dark rose/pink tint upon the screen
The pink tint produced by my LP70+ projector was not a lamp issue but a connectivity issue. I swapped the old cable with a good known cable and the tint went away.
Aug 14, 2008 | InFocus LP70+ Multimedia Projector
Bulb light projects red
Hi there
I guarantee you 100% that this not a bulb problem but rather a Mainboard failure.
This can unfortunately only be resolved by having it repaired or replaced.
And it is expensive incase you were wondering.
Mar 26, 2008 | Toshiba TDP-S20U Multimedia Projector
Dell 2300 projects verticle stripes accross the projector screen.
this is due to improper power supply or a loose connection inside. the symptoms are of power supply unit inside projector. check out the current and amperes inside the projector on board. sometime the current stable but the ampears are down.also check the switching transistors & filters inside.......
Feb 12, 2008 | Dell 2300MP Multimedia Projector
Permanent Coloured tint
When the image turns pink, we find that replacing the cable between the projector and the lap top fixes the problem.
Sep 10, 2007 | Sanyo PLC-XU47 Multimedia Projector
1,179 people viewed this question
k24674
