Question about Pride Health & Beauty
Gc3 controller Chair joystick
  • Pride Master
  • 10,263 Answers
If you're having trouble with that controller, there are repair centers for them. Repairs are much cheaper than buying a new one. https://www.pridemobility.com/.../GC3_Controller_BOI.pdf This may help with troubleshooting.
Posted on Sep 03, 2017
2 Suggested Answers
  • 347 Answers
SOURCE: We replaced brushes on motors
GOD I LOVE BEING HERE FOR PEOPLE LIKE YOU,PLEASE DOWNLOAD :SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 THAT WILL GIVE YOU WHAT YOU NEED,COLIN.
Posted on Mar 14, 2011
Push power button wont go but all the adjustments legs back tilt works
quantum 600 wheelchair troubleshooting Questions ... - Fixya
www.fixya.com > Forum > Tags
quantum 600 wheelchair troubleshooting chair won't go all i get form joystick is a picture of a ... around in a square there should be a rest button on the rear of the chair ,push ... Question about 600 E Electric Wheelchair - Used Power Chair.
[PDF]Pride Quantum 600 Owners's Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600%20Owner's%20M...
Quantum 600 .... The symbols below are used on the power chair to identify warnings, mandatory actions ... Pride will not be held responsible for injuries and/or property ...complete stop by releasing the joystick, then push the joystick forward slightly to .....breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600E Owners Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600E%20Owner's%20...
Quantum 600E .... The symbols below are used on the power chair to identify warnings, mandatory ... chair. Pride will not be held responsible for injuries and/or property ... complete stop by releasing the joystick, then push the joystick forward slightly to ..... breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600 Series - Pride Mobility Products
Dec 30, 2015 | Quantum 600 E Electric Wheelchair - Used...
It won't power off or move
If nothing looks broken on the joystick the batteries may have become disconnected when the chair hit the ground. Check all wiring connections on the chair. You can test to see if there is voltage getting to the joystick with a voltmeter.
Oct 02, 2015 | Health & Beauty
I have a Quickie S646SE wheelchair with a Qtronics Pilot+ romote controller. I charged the chair last night. When I turned it on today the profile lights scroll left to right and the chair does not move. I...
Press and hold power button til beep then push joystick forward and hold joystick til beep then pull the joystick back and hold joystick til beeps. turn power off then on. should be unlocked now
Mar 17, 2014 | Quickie Wheelchairs Quickie S-646 Power...
Rebuilt motor installed in Pronto m50 power chair, now joystick forward, takes chair to right, joystick right takes chair forward, joystick to left, taks chair back, joystick back takes chair left, HELP
u need a programer o reset that joystick to the new motor,so call the dealer have them send out a qualified tech with a programer to check error codes and reprogram
Sep 26, 2013 | Health & Beauty
Jazzy select contol panel all leds flash 7 times. what does that indicate?
This problem may depend on which main controller your chair has fitted. It should be a Penny & Giles GC controller. US versions should have a GC3 whilst here in the UK, it would be fitted with a GC2. However, the diagnostic flash codes for these two controllers should be the same. The reason im slightly confused is that you say 5 flashes mean your charger is connected at power up, when in fact it should be a Right Motor Wiring Fault. 9 flashes is indeed a Solenoid Brake Fault, or in other words, the wheelchair is in 'Free Wheel' as you have described. Therefore, IF your controller is in fact a Penny & Giles GC, 7 flashes would mean a Joystick fault. There is not much you can do to diagnose this other than checking connections between the Joystick and main controller. If these are OK, it is likely that a new Joystick controller will be required as having these fixed is usually not cost affective. Hope this is of some help to you.
Jan 27, 2013 | Pride Jazzy Select 6 Indoor Power...
I JUST PURCHASED A JAZZY WHEEL CHAIR AND IT IS I THINK 2003 MODEL WHEN TURNED ON THERE ARE 3 RED LIGHTS AND 4 YELLOW LIGHTS FLASHING AND NOTHING HAPPENS
the 7 lights indicate a joystick problem which means the joystick/controller will have to be replaced since there is no self repair fix Unless you can locate a good used joystick/controller for cheap (around $600.00 rebuilt) I would return the chair and get my money back Hope this helps
Jun 20, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Yellow light blinks 9 times and chair won't move. how do i fix it?
The problem is bad communication between the joystick and the conroller or power module. By replacing the jostick cables you will see if that fixes the problem. Check with your provider (where you got your chair) to see if they have an extra joystick cable or can loan you one from a chair that they might have. Now there are 2 cables one from the joystick to the base of the chair and one from the base to the controller either could be bad but try the one to the joystick first Hope this helps
May 03, 2011 | Invacare Pronto M51 Power Wheelchair
When I turn on controller power the speed lights flash slowly. Joystick does nothing and chair is dead. Chair is Pride Jet 3 Ultra.
Do all of the speed lights flash at the same time or do they ripple from left to right? If they ripple from left to right the chair is in lock mode and you can use the unlock procedures from my tips to unlock. If they are all flashing at the same time you have an internal joystick problem and the joystick needs to be replaced Hope this helps
Apr 27, 2011 | Pride Mobility Products New Pride Mobility...
The chair suddenly lost power and now the lights flash continuously. The chair won't take a charge. A repairman tried fixing it at a local shop and said he put a new battery in and it sizzled. Now he is...
If he put in the batteries (2) properly, they should never sizzle. Some will emit a very minute spark when the final connection is made, but that is normal. There are fuses coming off of each battery to the power controller that will blow at 40 to 100 amps or so, depending on the chair; these will blow before the chair frying, or the circuit breaker will trip, or the controller will fry and all will be quiet on the chair, so I am going to say that the batteries weren't properly hooked up, otherwise on of the above items would have shut everything down. Continuous flashes indicate trying to start the chair while it is still on the charger, or with the joystick off-center. Make sure it is unplugged and notohing is resting against the joystick. If it's still a no-go, then you have either a joystick issue or controller issue. You will need to test those by replacing with known good controller/joystick, which a dealer should be able to do for you. Good luck.
Jul 17, 2009 | Jet 3 Ultra Power Chair
How do I lock up my Hoveround MPV5? The tech that delivered my chair shown me a way to lock up the joy stick & wheels, I don't remember how he did it and can't find my manual.
1. Turn the controller on.
2. To lock the chair, depress and hold the ON/OFF button. After one second the controller will beep. Release the ON/OFF button. Move the joystick forward until the control beeps. Move the joystick in reverse until the control beeps. Release the joystick. There will be a long beep that indicates the controller is locked.
3. To unlock, turn the control system on. The speed/response indicator will be rippling up and down. Move the joystick forward until the control beeps. Then move the joystick in reverse until the control beeps. Release the joystick. There will be a long beep that indicates the controller is unlocked.
This is from the manual, I hope it helps you.
May 06, 2009 | NRS Hoveround MPV 5 - Used Power...
Health & Beauty Logo
177 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
