Question about Tascam CC-222mkIII CD Player / Recorder
Problem with tascam cd-rw901
Disc wont open
2 Suggested Answers
mjap
  • 107 Answers
SOURCE: cd player reads disc error
maybe you need to change the optical eye now.
but first try to adjust the variable resistor/trimpot resistor.
try this options to your player.
(TIP)
if using a cd/vcd/dvd products, we only should play a cd/vcd/dvd dics without a bad scratches. the scratches are making the optical eye worn-out easily.
Posted on Jan 30, 2008
Tascam 160 always read no disc
The reason it reads no disc, is because the Optical Pickup(laser) is worn out of specifications. If the pickup cannot read the TOC(table of contents) it thinks there is no disc in the drawer. Your will require a new pickup. If you require more assistance, or would like to inquire about repairing your Tascam(I used to be a factory service center), please visit my website at audioserviceclinic.com, and contact me there. Thank you.
Dec 22, 2014 | Tascam Audio Players & Recorders
Tascam CD-RW402
clean your cd lens or change other socket plese check your computer driver
May 26, 2012 | Tascam CD-RW402 Burner
Cd will not eject. Keeps giving message "Now OPC" but will not do anything and will not eject cd either.
To remove a stuck CD from Tascam CC222 MKII
This solved the "Now OPC" problem
1. Unplug unit
2. Remove the top cover, (3 screws on each side and 3 on the back, lift cover).
3. Plug in unit.
4. Power on the unit to observe the drive spindle spinning clockwise, (1" disc on top of drive).
5. Turn off unit, do not unplug at this time.
6. Use a small screwdriver to prevent the drive spindle from spinning.
7. Power on the unit preventing the spin.
8. In approximately 10 seconds the display will read "Disc Error" and the CD tray will open.
9. Remove the screwdriver and the disc.
10. Turn off the unit and unplug.
11. Replace the cover.
12. Use a better quality disc.
Sep 23, 2010 | Tascam CC-222mkIII CD Player / Recorder
Having trouble transfering my wav files from computer to tascam ( dp 02) even from cd to tascam . so i am unable to use .help? i have transfered my mp3 audio files to wav and tried to drag and drop from...
I had the same problem too but I figured it out. First you have to make sure your wav file is converted to (MONO) as opposed to Stereo, (which is the default channel setting). The best thing to do is to download a converter program, in my case I downloaded AVS Converter program which all I did was upload the wav file switch it to Mono 1.0 and that was that!! The Cons: for this program it costs money to download for your own keeping. I also suggest Audacity program my computer wont let me download it but a co-worker of mine has it and he said it's free to download.
Feb 02, 2010 | Tascam Dp-02cf Digital 8-track Recorder
CD player does not recognise some CDs. When placed in the drawer the deck displays "no disc" if another CD player is used the disc works fine
I have two of these Tascam CD-A500 players, and one more than the other has this problem of not reading some CDs that will play fine in other players. I'm starting to loose faith in this Tascam product. Anyway, seems the consensus is to open it up and check for dirty laser optics. If that doesn't fix the problem, then send it in for repair or scrap it and buy a different brand. I've not had this problem with any other brand CD player, but very suspicious that the same problem happens on BOTH of my Tascam CD-A500 units.
Nov 15, 2009 | Tascam CD-A500 CD Player
Drive wont read cd
Have you tried different CDs? Does the led come on when you put the disc in the drive? You can also try running a disc cleaner in the drive. It could be that the drive is bad and you'll need to replace it.
Jul 31, 2009 | Tascam Computers & Internet
I keep getting Disc read errors! when I put a CD-R in my Tascam CC-222. I thought the problem was with the discs so I bought more ... Sony CD-R. Still the same problem. Help
Either the player doesn't except this format which many don't read burnt discs. If it plays factory made discs, than it doesn't except burnt formats. If it doesn't read any discs, than the laser eye may need to be cleaned with rubbing alcohol and cotton swab
Apr 24, 2009 | Tascam CC-222mkIII CD Player / Recorder
Cd player reads disc error
(TIP)
Jan 28, 2008 | Tascam CD-A500 CD Player
Tascam CD-A500 'no disk' problem
try to listen to sound inside if the any motor is working through the disc tray. then try to open it (if you want though) then observe it.
after that if the motors are ok, try to adjust your optical lens variable risistor.
note if the optical lens is not emitting a red light your optical lens is the problem, changing it is the only solution.
Dec 24, 2007 | Tascam CD-A500 CD Player
Tascam CC-222mkIII CD Player / Recorder Logo
24 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
