Question about Watches
Set Isaac Mizrahi ceramic watch
I have a new Isaac watch. I cannot get the crown to go on to allow the watch to work.
5 Suggested Answers
SOURCE: seiko watch stuck crown
The crown maybe a screwdown type. Try unscrewing (like jar lid)them pulling out the crown.
Posted on May 04, 2007
escapement
  • 2334 Answers
SOURCE: Hamilton X-Copter Watch troubleshooting
Just pull it out to the second click/position and adjust time. When you unscrew the crown, it is in winding position, when you pull it out to the first click - it is in day/date adjusting position, when you pull it further out to the second click - it is in time setting position. In case if you do not have screw down crown, everything is the same, just you do not have to unscrew the crown. Rate me, plz.
Posted on Jan 27, 2010
mcdevito75
  • 1970 Answers
SOURCE: I bought an ISAAC MIZRAHI watch and I need to take
mcdevito75 here, Best Bet Barbara, find a small watch repair shop in your area to adjust the band for you, a small watch repair shop will also save on the cost over a big name shop. Expect approx. cost $15$30.00 most likely less.
Posted on Jun 27, 2010
Testimonial: "Thanks for reading and giving me an option. I'll start looking for a local small shop. Thanks again."
  • 44896 Answers
SOURCE: How do I change the battery on Isaac Mizrahi ceramic watch?
Take your Isaac Mizrahi watch to a jeweler who will open it, identify the battery, and perhaps replace it for a reasonable sum.
Posted on May 08, 2018
May 08, 2018 | The Watches
How to set new date of month on watch
How to change date on a watch?
Pull out the crown to the second click, and advance the hour and minute hands until the desired date and day appears. * If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock. 5. Adjust the time by turning the crown in the desired direction.
Instructions for Analogue Quartz and Mechanical Watches - Seiko
https://www.seikowatches.com/support/ib/pdf/Analogue_E.pdf Search for: How to change date on a watch?
How to set new date of month on watch Google Search
Dec 21, 2016 | Watches
How do I change the day, date etc on a GENEVA 7391 watch
read the instruction manual, Geneva Watches with Two or Three Hands
  1. Pull the crown out until you feel a click.
  2. Turn the crown counterclockwise until you have the correct time.
  3. Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the time.
  2. Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
  3. Pull the crown out until you feel one click. This first click position allows you to set the date.
  4. Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the day.
  2. Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
  3. Pull the crown out until you feel a second click to set the time or the 24-hour hand.
  4. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  5. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
  1. Pull the crown out two clicks. This second click position allows you to set the time.
  2. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  3. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
  4. Stop and start the chronograph by pressing the PA button, located above the crown.
  5. Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
  1. Wind the mainspring by turning the crown 15 to 20 times clockwise.
  2. Pull the crown out until it clicks.
  3. Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
  • Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
  • If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Read more : http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Jul 13, 2015 | Geneva Watches
I have a Victorinox ST1500. Since fitting a new battery when I reset the dials they no longer go back to the zero/12oclock position.
I can find no manual for this watch, so can only offer a general solution. With this type of watch there is usually a means of setting the dials to 'home' position. Reset the dials, then pull out the crown (this may have 1 or 2 different positions) and try pressing each of the top and bottom buttons and see if the 'dials' move. Sometimes, some are set with the crown in one position and others when it is in another position. Trial and error should allow you to set the dials to home position. Once you've done that, press the crown back in and retry the stopwatch.
Jul 12, 2010 | Watches
I'm tryng to set the date without changing the day and time. I've tried to just pull the pin out half way but its not working. How do I do this? My watch has three dials on the face - 1)date, 2) day and 3)...
mcdevito75 here, It takes practice, the crown does have 2 positions, slip a fingernail just under the crown and lift to it"s first position this will allow you to change the DATE (number) once you get the correct Date, push tje crown back in, NOW! pull the crown out to set the DAY itself and the time. On some watches the crowns first position allows both the day and date to be changed by turning the crown in it"s first position clock wise and counter clock wise.
Jul 04, 2010 | Bulova Watch
GB743 CHANGE DATE
mcdevito75 here, Your Bulova watch should have a 2 position crown (winder), carefully lift the crown to it"s first position, this should allow you to change the DAY, once done pull crown out to set the time, keep turning the hans till you get the right DATE (number) now set the correct time and your done.
Jul 01, 2010 | Bulova Watch
Citizen eco-drive BM8084-58H: I cannot change the date/day on the watch moving the crown.
mcdevito75 here, The crown should be a 2 position crown, try this, pull out the crown as if to set the hands, rotate the hands, (adjust the time) around the dial until you have the right day, Now! push the crown in, Now! slip your finger nail just under the crown and lift the crown to it"s first notch or position, this should allow you to turn the crown and adjust the date, when at the date push the crown back in and your done.
Jun 28, 2010 | Citizen Corso Eco-Drive BM8084-58H Wrist...
I bought an ISAAC MIZRAHI watch and I need to take out 2 links, as it is very loose on my wrist. How should I go about this? The watch did not come with any instructions. Can you help me? Thank you...
Jun 26, 2010 | Watches
Vextra men's watch
pull crown out once this allows you to set one of the functions by turning crown in one particular direction ..then pull out further to set next function by turning crown in one particular direction then push cronw all the way back to case side..if crown is of the screw down type you will have to unscrew it anti clockwise first then pull it out one click remember to screw it back when you finish
Mar 26, 2010 | Bulova Watch
Jan 27, 2010 | Hamilton Watches
Watches Logo
49 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
