Tv wont change source - Televison & Video
Toshiba smart tv stuck on one channel tried new remote wont change channel went back to old remote still the same
Did you try changing the source? It might be getting the channel from a source other than the TV.
Sep 09, 2016 | Toshiba Televison & Video
My tv wont change the source! how can I fix that?
What have you tried? The menu button on the TV itself? Have you powered it off and removed plug and plug back in? Is there a parental lock on this? Have you reset the tv to factory defaults?
Oct 11, 2014 | Westinghouse Televison & Video
My vizio smart tv wont work with my playstation 3 its keeps saying retriving data but then it says no signal what i am i doing wrong
mmmm, i don't have one of those tv's, but here's a guess. try find the automatic search for source option.
if that didn't work your ps3 is probably sat to HDMI or SCART, to change this: turn off your ps3 and hold the powerbutton when your turning it on. this will cause the ps3 to change between HDMI and scart, thats probably why it wont find a source.
Oct 12, 2013 | Televison & Video
Tv wont change the input on universal remote
Hello
Some sets wont respond to all functions with a universal remote contro. Try to set the remote control to TV with and other code. sometimes it may help you.
Feb 29, 2012 | Televison & Video
I have a 6" plasma
Keep pushing the tv input button. This will allow you to cycle back through the other inputs and get you back to your source. When you pushed the button, you changed the source input.
Jul 09, 2011 | Televison & Video
I hook up my ps3 and it wont come throu it says ( please change source resolution ) i tyed eveything i know it just wont give me a pic.
My brother had this problem too I think it happen when u have been using the pa3 with a non hd tv and then switch to a hd tv, try hooking it up to a normal (older) tv to change the resolution to sd (standard definition) then hook it back up to a hd tv and it should put up a message saying it's detected a hd source and prompts u to change it. Hope this helps mate Bogsy
Feb 23, 2011 | Televison & Video
Cant change channels?
What is your antenna source? Cable or antenna? Try keying in a certain channel on your remote. see if you get that channel. Tv will not auto program if you do not have channel source coming in to antenna input.
Nov 03, 2009 | Sony FD Trinitron WEGA KV-20FV300 20" TV
Can't change output source and tv sensor wont work
souns like the ir sensor board is gone, shopjimmie.com may have one ,they are probably around 15 bucks and real easy to change ,its one connector i believe ,i have not found any universal remotes that work with ilo yet either,good luck i hope i was of help
Apr 23, 2008 | iLO 3200 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
