Question about JVC KD-AVX33 Car DVD Player
Connecting an External Portable Hard Drive?
I have bought a Maxtor Basics External Portable Hard Drive and have downloaded all my music cd's onto it, how do i get the system to play the music from the Hard Drive?
  • 3,267 Answers
You are connecting it to a car DVD player, but how many types of music format is it capable of playing? It should be in the Manual, however it will be able to play mp3. *.flac, *.wmv, *.wav, *.cda. But how ere you going to power your external hard disk? If it has provision for use of 12V DC voltage, same as that of the car. After its powered, only then will it work, but the USB connector will provide the output into the DVD players USB slot(just like attaching a flas drive like pen drive which uses the USB slot for power too....sodeep
Posted on May 20, 2009
I need to know the power rating for a Maxtor 160GB external Hard Drive for use with a Yamaha PSRs-900 keyboard. Yamaha requires the rating to be not greater than 500-600mA
The Maxtor STM901601EHD301-RK is part of the Maxtor Basics Portable family.
It uses a 2.5 inch Internal harddrive inside. (2 and a half inches across the Width. Same size used for a laptop. Desktop's use 3.5)
It connects with a USB Style A male plug, via the USB cable.
It's has a 160GB storage capacity, has an 8MB Buffer, (Cache), and an External Data Transfer Rate of 60 MegaBytes per Second.
Other than that, I find no more information from Seagate, (Seagate bought out Maxtor, and has the data base for Maxtor products)
http://hddlist.com/maxtor/all/maxtor_basics_portable
What I do know in reference to your question.
I know that the USB 2.0 technology uses 5 Volts DC. The Positive pin on the USB plug will support up to 5 Volts.
http://en.wikipedia.org/wiki/File:USB.svg
[Viewing a USB-A style plug, view it with the white plastic spacer at the bottom. Open part at top. The Positive pin is all the way to the right. The Negative pin all the way to the left. The Data + pin is on the left next to the Negative pin. The Data - pin is on the right, next to the Positive pin]
The Maximum current draw is 500 mA for a USB 2.0 port.
[ Current is rated in Amperes, or Amp's. You are looking at Millionths of an Amp.
Milliamp, or abbreviated as mA]
This would lead me to believe that the Maxtor Basics Portable external harddrives will not use more than 500 Milliamp's.
However I do not feel comfortable, telling you that it is okay to use your Maxtor STM901601EHD301-RK, on your Yamaha PSR2-900 keyboard. Would hate to be mistaken, and have you burn out the finals of your keyboard.
I do feel comfortable with the following suggestion.
What about transferring as much data as you can from the Maxtor Basics Portable, to a USB thumb drive? They have large thumb drives now, and hold a lot of data.
Most programs will fit on a large USB thumb drive.
Or am I missing the point somewhere?
Oct 20, 2009 | Seagate Maxtor OneTouch 4 Mini 120GB...
Maxtor basics 160gb portable hard drive is showing error performi
go to my computer p[roperty then hardware -> device amnager then uninstall usb drivers from it then install aagain.
then connect your harddisk then it found.
Jun 23, 2009 | Fantom Drives Titanium II (TFD160U2) 160...
Maxtor Basics 320 GB external harddrive cant be recognized
There's a good chance the shop you bought the drive from didn't have SP3 installed. For some reason, SP3 has an issue with USB peripheral devices. Windows has created a patch to rectify the problem. Click on the link below and install the "Fixit" patch to enable your PC to recognize your HD. Best of luck.
Greg
http://support.microsoft.com/kb/925196#fixit4me
Jun 18, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Maxtor Basics external portable hard drive not getting detected
Right Click on My Computer, click on Manage, go to Disk Managment, if the drive is available you will see it there. Check to see if it has a drive letter assigned to it, if not right click on it and choose Change Drive letters. Make sure you are on the external drive though, you don't want to change your C drive accidentally. It should pop up in My Computer.
May 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
External hard drive not recognised on my ps3??
Ok. Well this is easy! your hard drive is formatted in NTFS, ps3 wont recognize that. it needs to be fat32 find an XP machine not a vista machine.
download Swiss Army Knife and format the drive in fat32. you will loose ALL information in your external. you will need to back up anything you want to save and put it back after the format.
good luck!
Feb 09, 2009 | Maxtor Hard Drive
Reformatting external Hard Drive
click on the hard drive and use the disc manager to format
or right click on the hard drive properties and use the format tab
May 11, 2017 | Maxtor BASICS Personal Storage 3200...
Maxtor basics hard drive and my xbox 360
Does your drive make any sounds similar to these? If yes you have a mechanical problem and you should get a specialist to work on it if you need that data.
If not - try to remove the drive from the enclosure and connect it directly to the computer to recover your files.
Oct 03, 2008 | Western Digital Caviar SE16 (WD5000KS)...
I have bought a maxtor basics external hard drive today and am having problems using it
The drive is working. Since it is set for auto play its scanning your drive for photos. If you cancel out of it and go to my computer you should see the hard drive.
Jul 05, 2008 | Maxtor Hard Drive
I have a Western digital model wd2500b007-rnn
and I cannot get either my PC or my laptop to recognize the drive. I isolated the drive to another computer with the same error. It says USB device not reognized. I also tried a different port. I have not tried different cables. Can I retrieve the old data on the drive?
Did you find a resolution for this? I am having the same problem. None of my PCs can recognize the drive. Formatting seems to be the only choice but I need to recover my old data first.
Jun 06, 2008 | Computers & Internet
JVC KD-AVX33 Car DVD Player Logo
411 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
