Question about Acer-Veriton-M410-US3800P AMD Desktop PC - AMD Sempron 2.2GHz, 1GB DDR2, 160GB SATAII, DVDRW, Gigabi
Wont boot up
Desktop computer has been unplugged for about a week, will not boot up. do i need a new internal battery?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 79 Answers
The internal battery will not prevent a computer from booting. More than likely if you get nothing when you press the power button, its your Power Supply. Power supplies are easy to replace, should you have some mechanics skills. Take machine to a repair shop and ask them to test your power supply. If bad ask them for a replacement cost, for this model you should not need more than a 400 watt. While your there ask them how much to install for you.
All in all, you'll be out 80-100 bucks.
Hope my solution helps. Please rate my solution
Posted on May 20, 2009
M1160n wont boot windows xp nor two internal fans
Step 1:
Lets try this...
Unplug the cpu
Step 2:
remove the battery from on the mainboard
Step 3:
press and hold the power button for 30 seconds
Step 4:
release it
Step 5:
put the battery back in, plug in and turn on , it should work fine..
Step 6:
If that fails replace the power supply..
Dec 28, 2012 | HP Media Center m1080n (PC099A#ABA) PC...
Alert! system battery voltage is low
Hello there and welcome to fixya
This is a very common issue with these desktop units the cmos battery will only last from 2 t0 5 years depending on how it is used.
This battery sits on the motherboard so you will want to first unplug the computer then remove the outer cover to expose the internal parts then look for a coin sized silver battery that looks like a watch battery then replace the battery with a new one
radio shack has these then power up the computer and you will have to reset the time and date ok you will get a error about this. here is what the battery looks like
Aug 16, 2011 | Dell Dimension C521 PC Desktop
I have been given an old computer with Windows XP installed on it from work. I cannot get into it as the computer is password protected. How do I overcome this problem without reformatting and installing...
Best and easiest way to reset the password is to remove the CMOS battery (resembles a watch battery but larger) for a period of 30min. Once the battery is replaced, boot up and it should boot without asking for a password.
Apr 27, 2010 | Dell OptiPlex GX620 PC Desktop
Computer won't turn on already replaced power
Try unplugging the PC for at least 10 mins. If that fails... it could be the BIOS failing to Boot. Leaving it unplugged my discharge the System and it may Boot, once it does it maybe best to update the BIOS. If the continues it will force you to replace the BIOS or the Motherboard. If the System is older than 3 years, I would replace the Motherboard and reinstall to a new hard drive and recover your data. Or buy a new system and recover your data by using a USB external HD Container.
Dec 30, 2009 | HP Media Center PC M260n (DF200A#ABA) PC...
Laptop was unplugged while still running ans now
This happens when the battery dies and there is insufficient detectable power to run the boot system. You must change out the battery with a fresh one, or plug in a good external power supply to get things started.
You may also need to let the internal battery charge a short time before the boot system sees enough available voltage to start all systems.
Dec 19, 2009 | Computers & Internet
MY PC WONT COME ON THE SCREEN IS BLACK
The mother board has a battery if thats the one you took out you reset the bios, Try pressing the delete simutanuosanly after turning on the computer then in the bios goto boot device priority and select your hard drive press f10 which is the save and exit. Try turning on your pc again and see if it boots off the hard drive make sure you give the computer time to re-boot itself after you change the setting in the bios.
Apr 08, 2009 | eMachines T3604 PC Desktop
Dell pc dimensio 5150 wont boot up
If the power light is blinking amber - The computer is receiving electrical power, but an internal power problem might exist.
Ensure that the voltage selection switch is set to match the AC power at your location (where power cord goes into unit).
Also try simply unplugging the unit from the wall outlet for a minute then plug it back in and boot it up.
Feb 14, 2009 | Dell Dimension 8400 PC Desktop
EMachine T1440 will no boot on
There is a battery inside the pc, remove it and replace it with a new one. Leaving it unplugged for that long taxes the battery too much. This should help and also plug everything in and reset the power switch on the back.
Aug 19, 2008 | E-Machines eMachines Desktop PC
Acer-Veriton-M410-US3800P AMD Desktop PC - AMD Sempron 2.2GHz, 1GB DDR2, 160GB SATAII, DVDRW, Gigabi Logo
199 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
