Question about Oster 76076-040 Hair Trimmer
My oster classic 76 clipper pushes the blade out and won't cut
When I place the blade on the clipper and start cutting the blade lifts up and stops cutting. Even when the blades are moving I have to press down on the blade to get it to engage fully and cut properly.
  • 22 Answers
SOURCE: oster 76 clippers
Here is schematic and instructions for service and repair. The model in the picture is the A5 however it is the animal version of the classic 76.
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
Posted on Feb 02, 2009
  • 22 Answers
SOURCE: Oster clipper blades get red hot and won't cut.
see this link, its for the A5. The A5 is the animal version of the 76.
I dont know what model you have, but if you need schematics for YOUR model see this link.
http://www.clipperrepair.com/parts.htm?brand=8
  • 9 Answers
SOURCE: Oster Golden A5 Clippers will not cut
YOU MIGHT NEED TO CLEAN THE HAIR OUT OF THE CLIPPERS. AND OIL IT
Posted on Jun 06, 2009
  • 9 Answers
SOURCE: Clippers jam and won't cut when trying to use attachments
OIL THE CLIPPERS AND CLEAN THE HAIR OUT REALLY GOOD.
SOURCE: pet hair clippers blades move but dont cut.
Do not use regular oil on the clippers.
Instead use OSTER KOOL-LUBE.
We were told the blades become to hot with regular lubricating oil such as 3 & 1.
We bought some KOOL-LUBE from our neighborhood PetsMart and it corrected the problem on both sets of our clippers (one heavy duty clipper for dogs, one regular clipper for humans).
Here is a link to KOOL-LUBE on the PetsMart web site:
http://www.petsmart.com/product/index.jsp?productId=2752831&utm_source=googleproduct&utm_campaign=2011235&utm_medium=cse&mr:trackingCode=A9C8D151-4519-DE11-B0EA-001422107090&mr:referralID=NA
Jan
Posted on Jul 25, 2009
Want to use plastic attachment. What blade do I need to use with theses?
Oster 76 clippers can be used with a variety of blade sizes and combs. shaveroutlet.com has many in stock. When using comb attachments, you should use one of the following size blades; 000, 0000, 1, 10, 15, 30
ShaverOutlet com Search results for oster 76
Feb 25, 2016 | Oster Classic 76 Clipper w/ Detachable...
What blade do I use with attachments?
In general, Oster 76 clipper combs are compatible with blade sizes 10, 15, 30, 00000, 0000, 000, 1. Many are available at shaveroutlet.com
Oster Blade 918-306 Size Texturing Fits Oster Classic 76 Clipper, Power Pro, Power-teq And Star-te: Oster class 76 clippers....had them for a week and...
70ca16d.jpg Hope this helps, this is a tongue guide, you hopefully recognise it on your blade. If they are not paralell, then adjust them with pliers, both need to be perfectly vertical. When you put it on the clippers push the latch in as you close the hinge.
If it still wobbles then the next fe wthings need checking
1. The hinge screws on the clipper are tight, located either side of the hinge on the clipper.
2. The drive lever may be worn, thats the maroon peice of plastic sticking up at the top of the clippers, it moves from side to side when clippers are running.
3. If all seems fine up to now, your clipper should be fixed under warranty as it will involve changing parts covered by the warranty.
www.sheareaseltd.com
May 17, 2010 | Sunbeam Oster Blade 918-306 Size Texturing...
The metal blade fell off my O classic 76 shaver, how can i put it back on? it is the metal changing part
The part that holds the blades on came loose on my Classic 76 clipper. It turns out that the two holes for the inserts are too big. I fixed the problem by removing the inserts from the clipper body (easy since that is the problem), cleaned the inserts and holes in the clipper body and super glued the inserts back into the holes. Be careful not to use too much glue! It only takes a little.
Oct 31, 2009 | Sunbeam Oster Blade 918-306 Size Texturing...
If the clippers are new, it is not likely that the problem is internal. Sometimes, when the blade is put on the clipper, it needs an extra little push to clip firmly behind the blade catch (you can hear a little click). Try that.
Aug 23, 2009 | Oster Golden A5 1-Speed Universal Motor...
My electric dog clippers don't cut well
if the problem arrears to be with one blade on several clippers it sounds like you need to send the clipper blades for sharpening.
Aug 15, 2009 | Oster Health & Beauty
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Jun 10, 2009 | Andis Outliner II Hair Trimmer
Newbie Clipper needing advice
This is from the Oster book:
Changing Blades
To Remove: IMPORTANT- stop motor; push latch with thumb while lifting blade away from clipper and slide off tongue.
To Replace: turn motor on; insert blade on tongue fully and then snap blade into place.
Note: if the hinge is flush against clipper, lift it up with a screwdriver.
From me - Never take your blades apart to clean them. You can slide them one side to the other to get the hair out. (One little hair, can stop them from cutting.) You need to buy a can of clipper blade cool from oster or andis both are good, and it really helps to lubricate the blade and keep them cool while clipping. If you live near a dog groomer, petsmart or something of the like. Ask them to show you how to remove the blade and I know they will be happy to show you. I tried to submit an image from the book, but I don't know if it will get here or not.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Jan 10, 2009 | Oster 76076-010 Hair Trimmer
Oster 76 clippers
Oct 10, 2008 | Oster 76076-010 Hair Trimmer
Oster 76076-040 Hair Trimmer Logo
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
