Question about SVA-USA Televison & Video
Tv error message
SVA FLAT SCREEN T.V. WITH HOOK UP VIA SATELITE DIRECT T.V. HAS AN ERROR MESSAGE ON THE T.V. OF "OUT OF RANGE" CALLED DIRECT T.V. AND THEY SAID IT IS A T.V. ERROR?
  • 290 Answers
SOURCE: remote control codes
The only remote that works is the one 4 all. Call ONE 4 ALL for the right model number. They then can program the remote on the phone to operate the SVA tv. It worked for me until the set died this week. Guess why I am looking on this site.
Posted on Jul 26, 2007
  • 231 Answers
SOURCE: hooking up game system to flat screen tv
you should have several kinds of inputs options on TV .If you have a surround audio receiver .Simply go direct to receiver on any available input .If using diect to TV , use any available input on TV .More likely VIDEO 1 or 2 (game or camera input)on front or side of flat panel
Posted on Nov 29, 2007
SOURCE: Hisense flat screen has locked
Try turning the main power switch on the back of the tv off.
Then hold the menu button and push that switch back on while still holding the menu button.
Keep holding the menu button until the setup menu pops up.
Next, be sure your input is set correctly(air or cable).
Next, do an auto channel search.
That did it for me. After I shut it off I had to do it one more time but it did the job. A friend of mine gave me the tv for free because nobody he new could figure it out. I took it home, got lucky, and figured it out in about ten minutes.
jb
Posted on Sep 03, 2008
SOURCE: how do i hook up my ILO TV to direct TV satelite?
i have a ilo 32 in hdmi hdtv and i have mine hook up to direct tv .on the back of the receiver plug your red,white and yellow into the audio 1 of the direct receiver. on the back of your ilo tv plug the other end to the av1 and use S-VIDEO ALSO. plug the sat cord to the ant.in. on the tv set remote hit video and go down to s-video and hit ok. you need to plug all three plugs into their color ans the s-video too in the AUDIO section. mine works great !
Posted on Dec 30, 2008
SOURCE: 42 INCH SVA FLAT SCREEN WONT WORK WITH UNIVERSAL REMOTE
Have found that this $45 remote from this site works: http://shopsva.com/svauunreco.html
Posted on Mar 28, 2009
Error message on screen that says PO 1.15 V100
The error is likely to be from the satellite as the set model listed does not have that kind of error.
Nov 29, 2012 | RCA P52926 52" Rear Projection Television
I have a flat screen monitor sva but it keeps saying it is out of range
This means your video card is set to a frequency that is too high for the monitor to match. Lower the switching speed via the properties window on the computer. Try 800x600 @ 60hz for starters. You can reboot into safe mode by pressing and holding F8 as you reboot. This will allow you to boot in a low resolution mode which should allow you access to these settings.
Aug 29, 2011 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
''Out of range'' message on an older SVA monitor
This usually means the display resolution settings on your PC are set too high for the monitor to display the signal. Try lowering the resolution on your PC.
Mar 16, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
New Sharp Aquos LCD 46 TV
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
Dec 28, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Can't get picture
Hello matthew95765,
The TV is working, the message is coming from the dish box. What you need to do is to determine if the dish box is connected to the dish and that it has signal at the box, because the message it is delivering to the TV is that it is not receiving signal from the satellite. so you have to check the connection at the satellite and at the box because those are the only point that can generate the error you are getting.
I hope this helps,
Thank you,
Shuttle83
Jul 23, 2008 | SVA-USA SVA HD4208TIIIBU 42" Plasma...
Ev tv
have a new remote can not program it
Feb 25, 2008 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
Remote control codes
Apr 07, 2007 | SVA-USA HD4208TIII-VR 42 in. Plasma...
SVA TV
If you had this problem from Day one, you should go directly who you bought it from and see what they can do for you for the company info or service agent.
Sep 26, 2006 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Televison & Video Logo
Top SVA-USA Televison & Video Experts
Michael Galve
Michael Galve
Adorjani Laszlo
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
