I researched your question regarding error code FSE1. I could not find a response regarding a self cleaning oven. If you will provide the model number on the below listed website under "cooking" you may get a detailed response. http://producthelp.whirlpool.com
It seems that a general "fix" for error codes is to got to your electrical panel and shut off the breaker controlling your device for 1 minute. This resets the device and will reset the error code. (May not fix your issue but will reset code.)
Your manual should have a list of error codes to help you resolve this issue. If you have misplaced the manual, you can also download one for your device from Whirlpool's website as well.
If all else fails here are the U.S. and Canadian telephone numbers under "Contact us". I do not know if this is a pay line or Whirlpool will answer your questions and attempt to resolve at no cost.
Hi! The F2 code means Oven Temperature Too High. When this code is present do the following: 1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC). 2. For SELF CLEAN models: check door lock operation. 3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
HI. This code is a good indication of a separated key pad ribbon or the actual key pad may be damaged. Use the procedure below to isolate the culprit.
1. Check keypad connector for firm connection (keypad connects to control board). 2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect. Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question @@@@
Same thing happened to me about 1 month ago... Did you get some kind of power outage or lightning strike??? I am pretty sure the stove part works but the oven doesn't right?!?! It might be 2 things.. Either the temperature sensor inside the oven doesn't work or it's the control board (where the clock is). I tried to chaned teh temp sensor but it did not work. I then changed the Control Board and oven works again...
