Question about Denon AVR-2800 Receiver
Denon Avr 2800 Sounds drops out - Denon AVR-2800 Receiver
5 Suggested Answers
Duncan
  • 218 Answers
SOURCE: Vinyl on Turntable sounds thin and trebley through Denon AVR-1603
You will need an adapter amp which converts the tiny tiny signal from a magnetic phono cartridge up to the line level that you need to feed into your AUX input jacks. They cost about $20 to $30 dollars and can be found at Radio Shack. Unless of course you have a phono input jack on the back of your Denon unit. Good luck.
Posted on Nov 28, 2008
SOURCE: Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Posted on Dec 24, 2008
  • 163 Answers
SOURCE: Display on Denon AVR-2307 won't work
1. Bad main transformer or
2. bad main fuse/ bad channel.
You need a repair shop.
Posted on Jan 22, 2009
petraman7
  • 1175 Answers
SOURCE: Manul denon avr-1601 en castellano
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-1601&imageField.x=15&imageField.y=13
Espagnol as well ...I think
Posted on Feb 16, 2009
I need an English user manual for my Denon AVR-2600.
Not sure if this will help or not, as Im not familiar with this model but if you visit the Denon site and download either the AVR-2500 or AVR-2800, they may be similar enough to get you what you need. Be sure to click the box that says "Search Archived Products"
Home Stereo System and Headphone Spec Sheet Downloads Denon
Jan 27, 2014 | Denon AVR-2600
Reset factory settings of my Denon avr 2800
From Denon support:
To reboot, turn receiver off using the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory default.
Sep 08, 2013 | Denon AVR-2800 Receiver
Requires operator manuel
You can download the manual on the link below. Just click on the PDF.
http://safemanuals.com/user-guide-instructions-owner-manual/DENON/AVR-2800-_E
Good Luck and please rate 4 thumbs up for the free answer
Apr 29, 2010 | Denon AVR-2800 Receiver
I have a Denon 2800 hooked up to a Pioneer DV-C302D and while DVD's thru the Denon, the sound will come on and off. At the same time the Denon will be switching between analog and digital mode. Is one of...
It's a cable or connection.
The Denon apparently has an automatic selector to choose the digital input over the analog input if both are present (my Pioneer does this). The random switching is telling you the digital input is intermittently dropping out and coming back. You don't say if you're using the optical or coaxial digital interface. Coaxial is less prone to connection problems. If you use optical, make sure the ends are clicked in and there are no small radius bends in the cable. Tight curves reduce the optical power. Either way, check the connections and wiggle them to see if you can cause the problem to return.
Jan 18, 2010 | Denon AVR-2800 Receiver
I have a denon AVR-2000 that has gone into protect mode how do i get this off?
power output short....or spk or spk wire short check and .need service...
Jan 07, 2010 | Denon AVR-2800 Receiver
My entire Denon AVR-2800 display is lit up.
For the entire display to be lit up you most likely have a shorted display driver IC. That type of IC is usually a surface mounted flat pack type that even an experienced technician often has a tough time replacing without damaging it. I would recommend that you get a shop to do that swap, or you could spend more money damaging replacement parts than most any shop would charge to make that repair.
Good luck.
Nov 28, 2009 | Denon AVR-2800 Receiver
Denon AVR-2800
I'm having the same problem.
Jul 31, 2007 | Denon AVR-2800 Receiver
AVR-2800
Unplug for 24 hours then try again
Denon AVR-2800
Hi, This is because your unit goes in to protection mode because of some bad connection in the input/output section .Disconnect your spkrs,inputs..turn the volume is Down all the way and power it up,Check your wiring for shorts at the inputs and outputs. at your service sreejith
Denon AVR-2800 Receiver Logo
23 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
