Question about Braun Home
How to change farenheit to celcius on braun forehead thermometer
SOURCE: Changing the temp. from Celcius to Farenheit
Use the mode button to cycle through the screens till the temp is shown. Then use the minute buttons to change between F and C.
Will
Posted on Sep 02, 2008
aborcass
  • 2651 Answers
SOURCE: How do I change my whirlpool oven back to Farenheit instead of celcius...
its in your manual, did not give model number so i looked up anyone. if this does not work you can enter your model number here for a copy of user manual
http://shared.whirlpoolcorp.com/product_literature/search.jsp
To Change:
Press and hold CUSTOM BROIL for 5 seconds. A
tone will sound and “C” will appear on the display. Repeat to
change back to Fahrenheit.
Posted on Nov 07, 2008
wayneard
  • 1901 Answers
SOURCE: convert temp control from celcius to farenheit
Yo can do it the long way:
°F to °C Deduct 32, then multiply by 5, then divide by 9 °C to °F Multiply by 9, then divide by 5, then add 32
Or you can do it the easy way and go to:
http://www.wbuf.noaa.gov/tempfc.htm and use the converter.
Thanks for using Fixya.
Posted on Mar 28, 2009
  • 17 Answers
SOURCE: celcius to farenheit
If you take the control assembly out of the dash and look behind it, the connector has a black wire in position D7 (little letters and numbers are printed on the connector). This wire will have a connector on it, pull this connector apart and your display will now be in *F
Posted on Apr 12, 2009
  • 1739 Answers
You did not provide a model number however the Instruction Manuals for the various Braun Thermometers can be found here:
http://braun.kaz.com/kaz/service/prodResult/
Not sure if this procedure is common to all but this may work otherwise find the manual specific to your model number.
Changing the temperature scale
This thermometer is shipped with the Celsius temperature scale activated. If you wish to switch to Fahrenheit ( °F), proceed as follows:
Turn on the thermometer. ( If it is already turned on, make sure it is not in memory mode.)
Press the /mem button and keep it pressed. Then press and release the activation button to switch over to the «change temperature scale» mode.
By pressing the activation button again, the Fahrenheit scale is activated, «°F» is displayed on the LCD. Each further pressing of the activation button toggles the scale between °C and °F.
Release the /mem button to return to the ready symbol . The temperature stored in memory will automatically be converted to the selected scale when displayed on the LCD.
Posted on Apr 25, 2011
How do i change from farenheit to celcius on the braun thermoscan
1. Make sure the thermometer is turned off.
2. Press and hold down the > button. After about 3 seconds, the display will show this sequence: <<°F>> / <<SET>> / <<°C>> / <<SET>>...
3. Release the > button when the desired scale is shown.
There will be a short beep to confirm the new setting then the thermometer is turned off automatically. When turned on again, the temperature will be shown in the selected scale until the above procedure is repeated.
Feb 20, 2015 | Thermoscan Home
Change temperature setting on Forehead Thermometer
no I contacted customer service, this thermometer reading ONLY in F, there is no option to change it to C
Jan 25, 2014 | Braun Home
HOW TO SELECT CELSIUS IN FHT 1000
Contacted customer service, the FHT 1000 forehead thermometer reading ONLY in F, there is no option to change it to C
Dec 09, 2013 | Braun Home
Forehead thermometer
hold down the button the top until it beeps then push the top button on the reverse side
Oct 27, 2013 | Braun Home
Forehead thermometer fht1000
hola, quisiera saber como le puedo cambiar a mi termometro para q mida en celsius, es el termometro forehead de braun FHT1000 gracias
Sep 29, 2013 | Braun Home
Need to change the farenheit
Here is a link to the manual:
http://braun.kaz.com/files/IRT3020GB,%20F,%20E%20%28USA,%20CDN,%20MEX%29.pdf
Or just follow these steps:
• Turn on the thermometer.
(If it is already turned on, make sure it is not in memory mode.)
• Press the /mem button and keep it pressed. Then press and
• By pressing the activation button again, the Celsius scale is
activated, «°C» is displayed on the LCD. Each further pressing
• Release the /mem button to return to the ready symbol .
All temperatures stored in memory will automatically be converted
Mar 16, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
Can you change the temp reading from F to Celcius on a Braun Thermoscan 6014?
Turn off the thermometer
Press and Hold the L/O Button
Continue to hold the start button when the F or C display appears. Watch for these displays to cycle over the display window.
Release the start button when the F display appears on the screen.
5
Listen for a beep and watch for the Braun ThermoScan ear thermometer to shut itself off, indicating that you changed the temperature scale to Fahrenheit successfully.
6
Follow the same procedure but release the start button when C shows on the display to switch from Fahrenheit to Celsius.
Feb 28, 2011 | Braun Health & Beauty
Home Logo
Top Braun Home Experts
 Adam D
Adam D
Level 1 Expert
Are you a Braun Home Expert? Answer questions, earn points and help others
