Question about Sharp Microwave Ovens
FAn wont stop running
Fan won't stop running
Can it be used without the fan?
If you want to get anymore useful life out of it, stop operating it without the fan.
Aug 18, 2015 | Whirlpool Microwave Ovens
Fan failure /Intermittent heating
quite likely your microwave is trying to prevent it self from self destruct, because if the fan is not keeping the electronics components cool enough while its running the high limit thermo will disconnect power from the heating circuit, if the fan is not working it should be replaced , that's a techs job.
Feb 12, 2014 | Microwave Ovens
Vent blower won't stop
I had the same problem with the fan not wanting to shut off after the repair. Once I set the clock though I was able to push the button to shut the fan off. So try setting your clock first and see if that helps.
May 07, 2013 | GE Profile Spacemaker Over-the-Range...
Ge microwave fan vent won't stop
Either a mechanical or electrical issue at the vent.
Dec 23, 2012 | Microwave Ovens
We have a kenmore ultra wave microwave and the fan has stopped working and now the microwave won't operate. Any suggestions?
see this causes and fix it .God bless you
Exhaust Fan Motor If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it does
Thermostat If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.
Oct 02, 2012 | Microwave Ovens
I have Amana Commercial microwave RFS12SW2 The fan keeps running even door is open , it wont stop.
These microwaves are designed to run the fan for a couple mins after the cook cycle to continue cooling the electrical components.
Oct 20, 2010 | Amana RFS12MPS Microwave Oven
The fan starts up and runs on its own and we are cooking
That is a normal safety feature.
That's only covered in a very subtle note in the hood fan section of your owner's manual:
NOTE:If the temperature gets too hot around the
microwave oven, the fan in the vent hood will
automatically turn on at the HIGH setting to cool the
oven. It may stay on up to an hour. When this
occurs, the fan can not be turned off.
If for some reason you don't have your owner's manual, you can download it here.
Enter your model number as MV1610ST with no spaces.
You will need the free DJVU viewer to view or print your manual.
Dec 14, 2008 | Goldstar MV-1615 Microwave Oven
Fan and light constantly on
which fan? the exhaust fan or the control board cooling fan? the cooling fan is controlled by a thermostat just behind the control panel. it turns the fan to protect the board from overheating.
Feb 18, 2008 | GE JVM1440 Microwave Oven
Microwave Ovens Logo
104 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
