Question about OKI B2540 MFP Printer
Fuser temp error on OKI B2500 MFP - OKI B2540 MFP Printer
4 Suggested Answers
SOURCE: I have a OKI B2500 Series. When Print Says Printer Error FuserTem
If you have not fixed this by now, I have the fix.
Turn the printer on, hit the following keys on your printer:
down arrow, *, #, ok, 1, ok
After that, hit the down arrow until you see T>Printer and then hit ok.
Next turn off the printer, count to 5, and then turn back on.
Repeat the first step, but in place of the number one, insert the number 0.
These were the steps given to me by the oki customer service and it fixed my printer. If you have problems, the number is 800-654-3282.
Posted on Nov 11, 2009
SOURCE: I have an OKI B2520
This is a common error especially if you have power surges or outages, before calling in follow the following steps:
  1. Press Down Arrow
  2. Press *
  3. press #
  4. select SOS1
  5. switch the first digit from a 0 to a 1
  6. press OK
  7. Press the Red Stop button
Now you need to clear the error
  1. press the down arrow
  2. Press #
  3. press the letter T ( on the keyboard of the printer)
It should reboot itself although it may not, if it doesn't then turn off the switch then back on. you should see some black bars flashing on teh screen. This clears the error and wil help determine if the fuser is actually broken. Before you print and start using it you have to set it back to operational mode by doing the following steps
  1. Press the Down Arrow
  2. Press *
  3. Press #
  4. select "SOS1"
  5. Change first digit from 1 back to 0
  6. press OK
  7. Press the red stop button
Those are the steps required to clear the fuser temp error from the okidata support desk
Posted on Dec 30, 2009
SOURCE: OKI B2540 MFP IS GETTING A FUSER TEMP ERROR, DO
OKI B2540 MFP IS GETTING A FUSER TEMP ERROR, DO YOU KNOW HOW TO FIX
Posted on Feb 12, 2010
Printer error fuser temp
  1. Press Down Arrow
  2. Press *
  3. press #
  4. select SOS1
  6. press OK
  2. Press #
  2. Press *
  3. Press #
  4. select "SOS1"
  6. press OK
* Please rate this solution and provide comment
Nov 12, 2010 | Okidata B2500 MFP Printer Laser
When we turn on the printer it starts beeping and it says error fuser temp.
Hi
Usually this means the fuser bulb has failed. This will take an experienced tech to replace the bulb. You might be able to get a fuser unit from www.katun.com
Aug 18, 2010 | OKI B2500 Black and White Copier
What is fuser temp error
The fuser is not heating up to fuse your toner to the paper. You may have had a bad paper jam that damaged something? Make sure there is no torn paper at fusing unit that has been missed.
Jun 08, 2010 | OKI B2500 Black and White Copier
OKI B2540 MFP IS GETTING A FUSER TEMP ERROR, DO YOU KNOW HOW TO FIX THIS ERROR?
Sep 04, 2009 | OKI B2540 MFP Printer
PRINTER NOT WORKING
That is a fuser code. Turn off and take out fuser(the part that gets hot) and inspect it. Put it back in and turn back on. If code is still there replace fuser.
Aug 02, 2009 | OKI Electric Industry C3520 Laser Printer
Jun 07, 2009 | OKI B2500 Black and White Copier
Fuser temp error
Good day All
I had the same problem as i posted eralier. Replaced the fuser unit from another same machine- same problem. Contacted the dealres and As per there advice replaced the main board and the probelm is solved
I could not belive it The main board has to be replaced for solving this issue ? No there should be a reset Code or procedure any body knows . Pls post
Thanks and regards
Feb 20, 2009 | OKI B2500 Black and White Copier
Error Code 155: Fatal Error
Looks like a fuser error-
re-seat fuser
check for paper scraps, etc in fuser and printer.
Service call
155: Error
Defective fuse
cutting of fuser
Is the fuser installed correctly?
Does the error recur?
Reinstall the fuser after its
connection connector is cleaned
if error still exists-
Turn on the power supply again
Replace M32 board after check
the cable connection.
Jul 29, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
OKI C3530 MFP
Looks like a fuser problem.
Re-saet the fuser.
Check for pieces of paper, etc. in the path.
Service call 155: Error
Defective fuse
cutting of fuser
Yes
If error still exists_
OKI B2540 MFP Printer Logo
77 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
