Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Sony FD Trinitron WEGA KV-32FS120 32" TV
I can not find my manual for this tv. Can you tell me if the TV is high definition ready?
I want to upgrade my satellite receiver to HD.
  • 110 Answers
This is a Standard Televisions.
Posted on May 20, 2009
Dx-L321-10A: M-B315AA on direct tv. Can't get HD. Says restricted. Tried comp. No good, haven't used HDMI. Do I need Digital? Thanks for your time.
These are directly from your users manual:
  • Built-in HDTV tuner: Add HD-capable antenna to receive over-the-air high-definition broadcasts, where available. Optional set-top box required for high-definition cable or satellite programming
  • 2 HDMI inputs: Provide an uncompressed all-digital audio/video link for the highest quality connection and support copy-protected HD broadcast content.
  • you need to do one of 2 things to get HDTV on your device. Either attach an HD- capable antenna or attach an HDMI cable from your satellite tv providers box. Good luck.
Aug 03, 2015 | Televison & Video
How can I get high definition on the tv? I have it set to receive the signal from my cable tv company but it transmits only a regular signal.
Check these things to solve this problem:
Do you have an High Definition TV? If you bough it recently, then you probably do. If you are unsure, look on the back of the TV for the model numbe and search on Google to read find information about he model of TV you have. If you don't have an HD TV, you will need to upgrade if you want High Definition.
Is the TV connected to the cable box with an HDMI or Composite cable?
You can order a cheap HDMI cable at Monoprice.com.
If you are using old style AV cables (red, yellow, white) then you will not get an HD signal from the cable box.
Check the TV settings to make sure it is set to display in HD. Look in the manual for help here. It is probably in the Input Settings.
You will need to call your cable company and make sure you are getting HD service. If you are not the you will only get Standard Definition. You may have to pay more or upgrade your cable box.
Mar 05, 2011 | Televison & Video
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
How to Hook Up a Receiver to an HDTV
Things You'll Need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
I have a 50" hitachi rear projection tv, do i need
rozmyers,
You do not need a high def receiver, your unit has an ATSC tuner which is the same thing. You do need to hook it up to a high definition signal. You mentioned that you have satellite. Call your supplier and order the high definition channels if you do not already have them on the downlink. They should be able to tell you if you have them or not. They should also be able to tell you which channels they are (normally the higher ones). Once you have a high definition feed you will have the best picture you are going to get with todays technology.
Thanks for using FixYa and for the great rating. Please consider a testimonial.
hardrocko
Jan 09, 2011 | Hitachi 57S715 57" Rear Projection HDTV
What does HD ready mean? Is my Sony Bravia LCD acctually an HD TV or not?
High definition ready is different to Full High defintion for the simple reason the software is different to prove play a HD play station game on both and you will immediately see the difference in picture quality however the difference is not so significant on your normal satellite HD channels depending on the resolution the TV can produce
Nov 23, 2010 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Cannot adjust picture size on vizio
If the picture size isn't changing with the television's picture size adjustment setting there could be a few things going on. Check to see that you're in the right input on the television i.e. if you are connected to a high definition receiver make sure you are not in the tv/tuner input (tv display would say analog channel 3 or 4). Make sure your tv is switched to the high definition input i.e. component 1 hdmi 1 and etc. If you are in the high definition input already check and see that your cable box or satellite tv receiver is set to the proper resolution. For example if you have a 720p television make sure the cable box is set to 720p not 1080i. Last but not least look for the hd zoom # button on the cable remote. The button may also say format or aspect.
Aug 19, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
I have ab Acer LCD TV AT3201W and in the manual it says that it is HDTV Ready. What does this mean?
HDTV ready means that your TV is capable of displaying a high definition picture. A standard television broadcast is shown in 480i. High definition starts at 720i. Only an HD ready TV is capable of showing a picture that is 720 or above. So, if a person wants to upgrade to high definition offered by their satellite or cable company, or they want to enjoy a new Blue Ray disk player, they have to have a TV that is HD ready.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 14, 2009 | Acer AL2671W 26 in. LCD Television
Do we need to buy an antenna to get this TV ready for Digital TV?
LCD TV refers to the substance that creates the picture quality (it would be either LCD or Plasma or Tube) and HD refers to a crisp clear picture that can be attained. So your TV is an LCD (Liquid Crystal Display) TV that is capable of receiving and displaying HD (High Definition) Picture.
What you need to check for is whether the TV has a built-in Tuner. This will either be SD (standard definition) TV Tuner or an HD TV Tuner. The box it came in will tell you or you may still have stickers on your TV.
If it has a built-in SD tuner you will be able to pick up HD channels but in a lower quality. In this case you will only need to plug the TV into a Wall-socket antenna or rabbit-ear antenna.
If it has a built-in HD Tuner you will be able to pick up HD Channels in full HD quaility picture. Simply by plugging the TV into a Wall-socket antenna or rabbit-ear antenna.
If your TV does NOT have a built-in TV-Tuner then this TV is clasified as "HD Ready". Which means that you have to purchase a Set Top Box (STB). you can get either HD or SD set top boxes. In this instance you will plug the cable from the wall socket into the STB then from the STB into the TV using either an HDMI cable (as long as your TV has an HDMI input) or through RCA cables which will be coloured Green, Blue and Red (i think red)
By the Way - best picture quality is from a wall-socket antenna.
HDMI = High Definition Multimedia Interface
STB = Set Top Box
High Definiton RCA cables will also be refered to as YPbPr/YCbCr (depending on equipment)
LCD = Liquid Crystal Display (the method used to make the picture on your TV screen)
If you have anymore questions, ask away.
May 26, 2009 | Philips Televison & Video
HD UPGRADE MITSUBISHI WS-55315
Check your manual, I have the same set and you need a
WD 5000 HD upgrade panel, I believe.
This TV is HD upgradeable, it is NOT HD ready, like you have
been told by other responder......
Jan 22, 2009 | Mitsubishi WS-55315 55" Rear Projection...
Hd ready?
On any High Def TV, the reciever you need for this set, which does not have a HD receiver in it, is half the equation. Most HD channels have some HD content mixed with SD content on the same channel. SD content on HD signal from cable or satellite tends to be slightly blocky due to the native signal resolution and the resolution of HD (1080i/p or 720i/p).
Apr 30, 2007 | Akai PTH5498 54" Rear Projection...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
355 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
