Question about John Deere Garden
John deere ct322 keeps using water but no leaks
  • 246 Answers
SOURCE: john deere 2020 water pump repair?
Hello:
From your Description it Sounds like a Bad Water Pump Bearing and Seal.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 11, 2009
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere 445 lawn tractor is leaking coolant
This model has a weap hole just under water pump.If it leaks enough it will stain front cover just to the side of crankshaft.Do not buy the rebuild kit,just replace pump.
Posted on Nov 14, 2009
  • 10 Answers
SOURCE: John Deere 1520 bought used over heated wheN I
The thermostat is there to help cool the engine by slowing the flow enough to let the radiator cool the fluid. I would install a new one, but flush the engine and radiator first. Also are you losing any coolant? Could be a head gasket.
Posted on Jul 25, 2010
snowghost1
  • 784 Answers
SOURCE: 322 John Deere Overheating. New
one thing that you did not list in your list of replacements that could be the cause of your over heat problem is the thermostat.
relace the thermostat.
now as far as the full strength antifreeze goes, it all depends on what part of the world you live in ( hot or cold ). since you will need to drain part of the antifreeze to replace the thermostat - when you go to refill the radiator use a 50/50 mix and you should be pretty close to the correct ratio.
c...
Posted on Jan 04, 2011
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
I have a john Deere 445 garden tractor with a coolant leak up by water pump. Would this just be a gasket or does it have a weap hole
Check hoses before you tear anything apart. The water pump could be bad as I don't think there should be any moisture around anything. Bad hose will leak some times where they fasten on the pump or could just need to be tightened.
Good luck.
Apr 15, 2015 | John Deere Garden
Where is the fuel pump located on a john deere ct322
Follow fuel lines from top of engine to pump
Mar 22, 2015 | John Deere Garden
Ct322 john deere skid steer bucket and lift arms quit working as i was using it.
Either low on fluid or the pump quit...not much else to it
Nov 18, 2014 | Garden
Wiring diagram ct322 john deere
John Deere wiring diagram are not usually in the public domain. Suggest you contact your local JD dealer's service department for a copy.
John deere ct322
check fuel filters,air intake ,if deisel,rebleed injectors
Sep 13, 2013 | Garden
How do i fix flat tires for the 36" john deere stake wagon?
It should have innertubes like a bicycle. Just take the wheel off and use a flathead screwdriver to pry one side of the tire off the rim. Be careful to not damage the tube when doing this. Once u have one side of the tire over the rim you can pull the tube out. You can use any bicycle tube repair kit to fix any leaks you find. Easiest way for small tubes like this is just fill a sink with water, air up the tube and put it under the water to find any leaks.
Mar 04, 2013 | John Deere 36 Stake Wagon from Learning...
Need to siphon gas from gas tank of a John Deere
Go to the store and buy a siphon you would use for a kerosene heater.
You can get the fuel out with this item. When you fill it back up add some "Seafoam" fuel additive. It will help keeps it running better.
Good Day.
Oct 12, 2009 | John Deere Garden
Garden Logo
60 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
