Question about Hasbro Furreal Friends Butterscotch Pony
Repair jaw butterscotch pony - Hasbro Furreal Friends Butterscotch Pony
2 Suggested Answers
  • 8 Answers
SOURCE: Looking to repair the tail on Butterscotch pony
Had the same problem and the fix is easy. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of CLEAR plastic tubing with 3/16" inner diameter and 5/16" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the holes. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. You will probably need to twist the tube gently while applying firm pressure on it to make it slide over the stub. The end of the tube with the holes should be about even with the outside top of the white plastic hole and the tube holes should be level, looking at it from side to side. This makes the alignment of the screw hole to the tail correct. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully twist and remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right if you cut it too short! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
Posted on Jul 23, 2010
Can I buy carrot and brush for furreal butterscotch pony
Hey, replacement parts for Butterscotch can still be found on ebay, here's one: https://www.ebay.com/itm/263543016418
Sep 13, 2014 | Hasbro Furreal Friends Butterscotch Pony
I need an ear for Butterscotch pony 76471
Hey, replacement parts for Butterscotch can still be found on ebay, here's a left one: https://www.ebay.com/itm/263517990851
May 04, 2014 | Hasbro Furreal Friends Butterscotch Pony
Butterscotch pony head not working
First, calling poor Grace at Hasbro will provide fruitless. Hasbro does not make any parts for the full size FurReal Ponies, they have nothing in stock and cannot help you. I, however, can. I am going to post a link to a distressing site that turns the normal FurReal Pony into a fire breathing demon. However, in the process, you can see the diagram of the skeleton of the pony and head. You can search for other links but this is pretty comprehensive. Just don't open when kids are around.
Lisa
http://www.instructables.com/id/Make-a-Fire-Breathing-Animetronic-Pony-from-FurRea/
Dec 08, 2013 | Hasbro Furreal Friends Butterscotch Pony
Butterscotch pony makes gallop sound but very loud whirring noise at same time and head doesn't move side to side
Hey, that sounds like something in your pony's neck mechanism broke. Sadly Hasbro doesn't repair these ponies anymore and you have to investigate it yourself. You can follow this tutorial on removing the head: Hasbro FurReal Friends Smores Butterscotch Pony Head Removal How To...
Mar 17, 2013 | Hasbro Furreal Friends Butterscotch Pony
Furreal freinds butterscotch pony doesnt have gallop noise
Hey, are you sure you are applying enough pressure in the pony's back? It needs to compress fully in order for the 'Riding mode' to activate.
Sep 24, 2012 | Hasbro Furreal Friends Butterscotch Pony
Hasbro Furreal Friends Butterscotch Pony Logo
Top Hasbro Toys Experts
Jesse Walters
Jesse Walters
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
