Question about Car Audio & Video
Road noise How do I get rid of road noise (high pitch whining) only through front channel?
  • Anonymous Nov 09, 2008
    Hey, when i drive with my car i hear a real high noise about my speaker.
    Ostensible it comes from the electric generator.
    And when i throw the windscreen wiper i hear a sound at my woofer!!!
    What can i do?
Sounds like your ground is to long (shorter the beter) or positive lead is to close to the speaker wires/other cable (try to take different paths for each cable reduces interferance)
Posted on Jun 06, 2010
  • 631 Answers
Can you post more information about your system?
Posted on Oct 18, 2007
Why is there a high pitched whine coming from rear of 2003 yamaha roadstar
Hi, Anonymous I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Chains---RATTLE
5. Clutches---CHATTER
6. Shifting Trans---CLUNK
7. Gears---WHINE
8. Front Forks---PLUNK
9. Rear Shocks---SQUEAK
10. Starters---CLICK
11. Solid Lifters---TICK
12. Hydraulic Lifters---TAP
13. Pistons---SLAP
14. Connecting Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Re Chirp and High Pitched Whine Road Star Forum Yamaha Road Star
weird noise whine
http://www.werder.ee/Manual/XV1600.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-44_361.pdf
Jul 02, 2014 | 2002 Yamaha XV 1600 Wild Star
2007 Yamaha vstar 1300 14000 miles recently I've noticed a noise which sounds like high pitched chain noise. This seems to be getting worse. Only happens when engine is warmed up. Only when decelerating....
2. Belts---CHIRP
4. Chains---RATTLE
7. Gears---WHINE
13. Pistons---SLAP
Re high pitched whining noise Road Star Forum Yamaha Road Star
How to diagnose problem by the noises your bike makes
http://vstar1300.pbworks.com/w/file/fetch/94628933/1300VStarServiceManual.pdf
http://www.starmotorcycles.com/assets/service/manuals/2008/lit-11626-21-30_vstar1300tourer_1476.pdf
Sep 16, 2013 | 2011 Yamaha V Star 1300
Whining noise on 2002 chevy tracker, comes and goes
Could be your alternator or a bad idler pulley. Is the transmission good? It may be the tranny or your differential whining.
Feb 18, 2013 | 2002 Chevrolet Tracker
High pitch whine from belt area on 03 roadstar
2. Belts---CHIRP
4. Chains---RATTLE
7. Gears---WHINE
13. Pistons---SLAP
High pitched squeal Video included
http://www.starmotorcycles.com/assets/service/manuals/2003/lit-11626-16-44_361.pdf
Jun 05, 2012 | 2003 Yamaha Road Star Silverado
On my 2000 Audi A4 1.8T when i am accelerating in the higher RPM aroung 4000 is when it starts. But their is a vary high pitch squeling noise i can hear.
Whining high pitched sound from front end...left front wheel bearing or right it could be hope this helps tell me if it does
Dec 03, 2010 | 2000 Audi A4
High pitch whine
sounds like your one of your hubs on the front axle are staying engaged when you turn off the 4wd. By reselecting the 4wd high and back to 2wd hi it is causing it to release. Get it looked at these can get expensive if damage is done.
Jun 18, 2009 | 2004 Chevrolet S-10
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
High pitched electronic/dentist drill sound when accelerating.
Probably the front differential, your probably hearing the famous differential gear whine. Change the oil, put Lucas for gears in it. You can get a hand operated oil pump to **** it out through the dip stick if it has one. Then fill it with the recommended amount.
May 06, 2009 | 2007 Nissan Xterra Off Road
A high pitched whining noise in the engine.
This Noise Description sounds Indicative of the Sounds that come from the Serpentine Belt Or Related parts such as Belt Idler Pulley or Belt Tentioner witch also has a Pulley, but if Tensioner itself is Literally BROKE I've replaced a number like this it will cause a Whining noise . Best case scenario its just the Belt, and if any of the other Problems turn out to be the Culprit the Belt MUST be Replaced Anyhow as Damage is Being caused By the Very Whining you hear.
PLEASE Spend the Extras $ for the BEST BELT as this Drives your Water pump, Alternator, A/C Compressor, Power Steering Pump All Crucial to Control of, easy Steering ,All Electrical-Power Distribution, The COOLING of Engine << VERY CRITICAL Component
The Pulleys usually have a more Hum type Whining. So I would say at Best The BELT , And WORST Belt Tentioner is Broke
Jan 14, 2009 | 2002 Dodge Caravan
Car Audio & Video Logo
128 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
