Question about Fuji TC-30 PRO VHS-C Tape
Broken 8mm I do not know where to put the pins.
Hie, is there a picture to show the position to lock the crankshaft at tdc on a tata 2l tdi
on your right hand side just next to starter there is hole to lock ring gear put 8mm bolt or pin in hole to lock crank
Oct 14, 2016 | Tata Cars & Trucks
Hi.i need to know how to set timming on my citroen c5 v6 24 valve exclusive 2007 model.im wondering if the cams have to be aligned to the holes behind them on the heads and then a 8mm tool inserted.
looking at the diagram on autodata and reading the instructions
yes alighn pulleys with holes then insert pins
confirm the pins are inserted all the way
Aug 19, 2016 | Citroen Cars & Trucks
How do I change rear axle seal on 1991 dodge Dakota 4×4?
Remove the wheel and tire.
Remove the drum.
Drain the rear and remove the cover.
Locate the 8mm bolt locking in the center pin and remove it.
Slide the pin out 1/2 way. DO NOT SPIN EITHER AXLE WHILE THE PIN IS OUT.
Push the axle in from the outside. You will hear the "c" clip fall in the rear. Put the center pin back in the rear and thread the bolt a couple turns.
Slide the axle out.
Remove the outer seal and install the new one.
Reverse the procedure REMEMBERING to put the "C" clip back in.
(Slide the center pin 1/2 way out. Install the axle FULLY. install the "C" clip and pull the axle from the outside to insure the clip is in. DO NOT SPIN THE AXLE until the center pin is reinstalled and the retaining bolt is in.)
May 31, 2015 | Dodge Cars & Trucks
8mm JVC tapes put into a VHS tape that will play on a combined TV and VCR. Please, please, I need your help! Found tapes from 15 years ago.
You need an 8mm player or the camera that recorded the tapes. Connect the video and audio from the 8mm player/camera to a VHS recorder. Put the 8mm on play and the VHS on record.
Jan 08, 2015 | JVC P-6120JDU Video Cassette, 8mm 120...
How do you replace the chain tensioner on a Razor E300
Theres an 8mm nut holding it onto the pin that goes thru the frame.
Take that nut off and remove the tensioner. Put some grease on the new pin where the tensioner goes. Put the end of the new spring into the hole in the frame next to the pin hole. Hold the tensioner in place and put the pin thru and the nut back on. You should be able to get the chain back on the sprocket without loosening the axle nuts. Hope this helps.
Aug 03, 2014 | Razor E300 Scooter
Kodak m67 8mm movie projector struck in rev lever can be move to forward but miss run backwards
it is hard to explain but there is a metal pin on one of the mechanisms it can become bent out of place. you need to remove it and heat it up and put back straight. dont try to bend it straight as it will snap or the pin will come out of the metal part.
Oct 13, 2013 | Kodak 1950s/60s Brownie 500 8mm Movie...
Bell+Howell FILMO 8mm Projector
Hello
Thank you for using FixYa for your problem
sounds like the takeup belt is wrong or the speed motor
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | Bell & Howell Photography
Remove and replace rear wheel bearing on 1997 f150
REMOVE DIFF COVER ON 3rd MEMBER THERE WILL BE A SMALL 8mm BOLT REMOVE BOLT SLID PIN OUT PUSH AXLE IN AND REMOVE HORSE CLIP DO SAME FOR OTHER SIDE PUSH AXLE IN REMOVE CLIP. YOU'LL NEED A BEARING PULLER TO REMOVE BEARING INSTALL NEW BEARINGS WITH NEW SEAL, INSTALL BOTH AXLE WITH HORSE CLIPS INSTALL PIN AND 8mm BOLT, COVER AND REFILL.
Nov 04, 2009 | 1997 Ford F150 Regular Cab
How to replace hinge lid pins
At the back of the washer just below the control panel there are two 8mm metal screws remove them there are 2 clips they will alow you to lift the top up in the front of the washer the top cover has 2 spring type holders if you slide a small screw driver in the opening and push gentle on the spring clips they will release and you can lift the top off the washer there is a screw on each hinge this will remove the old hinge then replace with new ones hope this will help
Jan 24, 2009 | Maytag PAV2300 Top Load Washer
Fuji TC-30 PRO VHS-C Tape Logo
Top Fuji Electronics - Others Experts
Are you a Fuji Electronics - Other Expert? Answer questions, earn points and help others
