Question about Kyocera Mita FS-3820N Laser Printer
Error code 4200-002678 call for service
I have Kyocera FS-3820N that show message Call for Service 4200-002678. I turn of the unit for a day and turn back on the next day and it will work for hours and then message with come back.
  • 622 Answers
Best case scenario... laser scanner harness or cable loose or bad... medium case scenario... laser scanner unit is bad... worst case scenario main board is bad...
Posted on Dec 26, 2009
Kyocera call service 4200:040797
Means that the laser unit is off. You should check the cables for the laser unit
Jun 27, 2014 | Kyocera Mita FS-3820N Laser Printer
Kyocera FS-3920DN call service 2000:0011742
The call service 2000 is about the main motor. Pull the Developer Unit and then the drum unit out of the printer and check if the gears on both units are moving freely. Then turn the printer on without the 2 units and see if the motor is functioning. If your the motor moving then the message displays on printer will be 7410 (because you have the drum unit outside). There is a possibility that the transfer roller is damaged.
Mar 26, 2014 | Kyocera Fs-3920dn Laser Printer
Error code 7001:0014607
Hello, This error code (7001) refers to a Toner motor error.
• Toner motor is overloaded. TNMOC is detected by sampling every other
100 ms in 2 seconds since the main and toner motors are activated following
the Replace toner Clean printer, message after the "Toner low" is detected.
Recommended action is to change the toner pack.
If this does not resolve the issue then the developer should be changed.
If neither of those resolve the issue, then likely the internal circuit board called the engine controller may be bad.
If this is the case the printer will need to go to an Kyocera Repair Depot.
I hope this has been of assistance.
http://www.fixya.com/uploads/images/prefab_21.jpg
Jan 18, 2011 | Kyocera Mita FS-3820N Laser Printer
Printer is showing an error message call service
Take out and reinstall drum unit. You will need to remove toner assy and waste ink bottle to do this. 7410 is the error, 98681 is the page count.
Nov 16, 2010 | Kyocera FS-4000DN Laser Printer
Check waste toner box
We have a Kyocera Mita FS-3820N and sometimes when the toner box message does not go away, even after emptying the box, we simply hit it a few times in the area of the box. Works every time!
Jun 02, 2010 | Kyocera Mita FS-3820N Laser Printer
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
Getting a E2 error on Kyocera FS-1700+. Any ideas?
this service code belongs to Laser scanner unit (Polygon motor) error
check the connection between scanner unit and engine board .....
Oct 06, 2009 | Office Equipment & Supplies
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera Mita FS-3820N Laser Printer Logo
1,411 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
