Question about Koolatron 1.7cuft Thermoelectric Fridge
Does not get cold
I plug it in my truck or in my home and does not cool!
Not Cooling and Evap Fan Not Running
Two things come to mind. 1. Something got pulled loose or bent during the move. 2. Mice have made a home (binding up the works) or chewed something important.
R-134 is OK with the cold.
Apr 14, 2013 | Amana Refrigerators
Just got home maytag side by side refrigerator is hot doesnt get cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 30, 2011 | Refrigerators
My 2002 Trailblazer is blowing cold air when I want heat.
well it could be several problems. first could be a bad thermostat that is stuck open or a possibly your heater core is plugged. also could be the switch that changes it from cold to hot. hope this helps but if your not mechanically inclined take to a shop
Dec 28, 2010 | 2002 Chevrolet TrailBlazer
REFRIGERATER SIDE IS NOT COOLING BUT THE FREEZER IS WORKING
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
qreq
May 10, 2010 | Maytag MSD2756G Side by Side Refrigerator
Used Kenmore freezer won't get cold enough
If it is running but not cooling enough the problem is in the sealed system.
If you started it up just after hauling it home it may have be moved around enough to get oil in the systems smaller tubing causing problems. Unplug the unit for 24 hours and let it sit. Try it again for 24 hours and see if it cools.
If not this means either there is a refrigerant (freon) leak in the system or a restriction causing the refrigerant to not flow properly.
Either one are an expensive repair. and will require a professional to look at.
May 09, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
We move my refrigerator and it was laid down for about 2 hours we plug it up when we got home now it won't get cold, how long will it take to start getting cold it been about 2 days now
It shuld never be layed down for transport or storage. 2 Hours is not a long time but you should have left it upright overnight before plugging in. turn it off for 24 hours. When you restart it it should be cooling in a few hours and at normal temp in 24-48. If not you may have damaged the compressor. (Assuming you hear it running)
Eric
Dec 23, 2009 | Kenmore Refrigerators
Refrigerator-lights on not cold
If has a electronil controlboard i would say it is faulty.Cheak on warranty.
May 11, 2009 | GE PSC23NGS Side by Side Refrigerator
95 Ford Windstar Vechile is running and warmed ,no heat
I had this problem recently too. Have the cooling system flushed and it will probably fix it. (heater core plugged)
Jan 27, 2009 | 2000 Ford Windstar
Koolatron 1.7cuft Thermoelectric Fridge Logo
50 people viewed this question
Top Koolatron Refrigerators Experts
Ilia Bichin
richie46
Jerry Kramer
Jerry Kramer
Are you a Koolatron Refrigerator Expert? Answer questions, earn points and help others
