Question about Garden
Greenfield EIII 32 MK2 clunks and wont drive belt is ok.do they have a clutch type system for it is trying to drive but wont.it will drive in reverse though.
Nathan
5 Suggested Answers
moretons
  • 155 Answers
SOURCE: We mow 2 acres with a Greenfield ride-on.
Hi i have seen this with most greenfield models The only way to fix this problem is to replace the drive clutch assy as it ends up to costly to replace the worn parts : shaft,clutch plates & drive pulleys.
In most cases replacing these parts has led to a new assy six months later.
Mark.
Posted on Jul 23, 2009
vincob
  • 718 Answers
SOURCE: I need a diagrahm of a belt drive greenfield ride
Go to this website, upper right hand corner and do a parts look up. Search for your model and that good stuff they ask of you and then choose mower housing should be there, browse the site it's really cool and has a lot of info.
http://www.jackssmallengines.com
I did a sample search for generic riding mower deck and found great diagram of belt routing. Give it a try you will find same results Good Luck! Don't forget the thumbs!
Posted on Nov 10, 2010
SOURCE: Have a Greenfield Evolution 2000
The Greenfield clutch (drive belt) is adjusted by spring pressure pulling a long rod that has serations on it. Either the belt has run out of adjustment (= new belt needed) or the adjuster has stuck. Lift up the seat and push the adjusting rod that has a big spring attached to see if you can move it towards the front. Look at the pulley beside the rod, if the belt has stretched too far, the pulley will be hard up against its slot. The pulley moves towards the front to tighten the belt. I just push with my leg to get another "click" out of the adjusting rod. New belts are cheap too.
Posted on May 03, 2011
  • 6468 Answers
SOURCE: craftsman 20.5hp briggs and stratton will not go forward or reverse when I let off the clutch it starts to squeal and smokes fronm the drive belt
could be as simple as a worn out belt but look to see if there is a oil leak getting onto the belt
Posted on May 11, 2012
Have greenfield fast cut 34 mower replace drive belt but have problem going forward up hills clutch is worn half mm could clutch be glazed
Are you sure your new belt is the proper length A quarter inch too long could make it slip. Something to try is spray your belt with belt dressing and see if that helps That will help stop it from slipping.I had to do that with one of mine when my belt was not the right size. I shot spray about once a week one summer.
Dec 07, 2014 | Garden
Clunking noise in rear of my 2006 yamaha rhino
Look into drive system. out put shaft, U joints, tranfer case, differntrals.
Mar 28, 2013 | Yamaha 2006 Rhino 660 Auto 4x4 Special...
Fiesta started making noises either gearbox or clutch? clunks going in to reverse, shudders driving off in 1st gear
sounds like your clutch is going out, is it hard to put in gear with clutch all the way depressed? could also be the sinkronyzer going out, could be the gears in the transmission also going bad. need to check the fluid in the transmission.
Feb 11, 2011 | Ford Fiesta Cars & Trucks
Have a Greenfield Evolution 2000 mower , the forward drive clutch is slipping badly on hills is ok on the flat, what is required to fix this problem. Can the clutch pads be replaced or are complete clutch...
Oct 31, 2010 | Garden
I have a ford ka, and when trying to put it into reverse it made a weird clunking noise. And then wouldn't come out of reverse. I had to really push at the gear stick to get it out. I can't select any...
If the Gear is truck into unless the clutch disengages it wont shift. So start the car move slightly- if no space is a avialable jack up and let the drive wheel move- now shift the gear after depressing clutch. It must shift over now. If not repeat while the drive moves. You can now shift the car to forward gear .
Sep 14, 2010 | 1999 Mercury Sable
Engine problems with mk2 fiat punto elx
that sounds like a clutch problem. get it checked asap because if that goes you may get stuck in netural and not go anywhere happened to me and it has not nice. if you start smelling a burning smell. that is defo your clutch
Nov 17, 2009 | 2006 Fiat 124
Cutting deck on greenfield evolution mower will not disengage
Usually this is caused by badly worn belt or incorrect type of belt fitted, check allignment, tension, belt size should be marked as A... not 13A..... if marked as the latter it is an "automotive" type belt not suited to "slipping" when belt loosened to disengage cutter. Check also for the belt has not rolled over in the groove.
Oct 31, 2009 | Greenfield Industries Disston #752980 Mm...
We mow 2 acres with a Greenfield ride-on. Sometimes have to cut long grass by slipping the clutch to get slow forward speed. Problem is that the clutch system occasionally locks into forward or (worse...
Mark.
Jul 18, 2009 | Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
