Question about Philips 43P8341 43" Rear Projection Television
Turning off and on
The TV keeps shutting off. The TV can stay on for as little as two minutes to as long as 2 hours. The TV was purchased in 2002 . The light  on the front blinks on and off. I am a technician and can fix it if you have any suggestions.
Thanks SeaWillie
Same problem here, any help?
Posted on Nov 15, 2007
Keeps shutting Down
Have to start at the beginning---Lamp? Ballast? Color wheel?
Jun 07, 2012 | Samsung HL-R6167W 61" HDTV
TV has good picture sound and picture keep going off up to 2 minutes then returns. Its a sony LCD projection TV 65"
The tv "LAMP" LED light indication staying on or blinking on the front tv bazel frame?The tv projection lamp been inside this tv like 1 1/2 or 2 years?Tv been on and watches like 4 or 5 hours daily?Yes to all of these,mean the tv projection lamp life are ending.Require a new projection lamp for the tv.
Jan 14, 2011 | Sony Televison & Video
Tv comes on for about two minutes then shuts down. The lights stay lit.
Any LED light indicators on the screen panel said "LAMP"stay lit or blinking?The projection lamp life is over,require a new lamp,if "LAMP" LED light lite or blinking?The projection lamp in the tv now,been in use for at leat 2 years and tv on about 4 to 5 hours a day?The Lamp life span is over,require a new lamp.
Jun 11, 2010 | Samsung SP 56 K 3 HV 56" Projection...
02 harley fxdwg brake light stays on
Make sure your rear brake pedal has freeplay in it. when you slowly push the lever down by hand you should be able to feel some freeplay. if not the the reason it keeps staying on is because the vibration of the motor is actually pumping up your brake ( light too ) and not releasing it until it bleeds off the pressure.
Jun 23, 2009 | 2002 Harley Davidson FXDWG Dyna Wide Glide
Is my lamp out on my LG?
Most likely you can have 1 or 2 problems.
1! the light is busted and you will have to replace that. You might also need to check your cooler fan bearing as you indicate it makes noise.
Please open following link( you need acrobat reader)
this is the service manual for your TV
ru-44sz61d
Apr 30, 2008 | LG RU-44SZ61D 44" TV
TV shutting off
try this part first 5600110347 you can get it at www.vancebaldwin.com
Jan 31, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
VS-60111 turns off on its own after few hours
Did you repair the two leads? Ao check near the Convergence ICs for an open resistor or two, although that shouldn't effect your audio. Yu most likely have a low voltage regulator or bad capacitor. You will probably need the service manual to actually track it down. I will post a link where you can ge one for 12.99 and the include free unlimited support. They will also email it instantly to you if you return to the site and send them an email requesting they email it to you. You sound like you could fx it with the service manual and some guidance. Here is the link.
http://servicemanuals.vstore.ca/
Jan 25, 2008 | Mitsubishi VS-60111 60" Rear Projection...
On / Off problem
YOUR ON/OFF BUTTON ON THE FRONT PANNEL IS STUCK
SOME HOW (PRESSED IN ) TY SOME WD40 ON IT . SEE IF THAT WORKS.
Dec 12, 2007 | Samsung TXP3275H 32" TV
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
Philips 43P8341 43" Rear Projection Television Logo
43 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
