Question about Samsung DVD-V5500 DVD Player/VCR
Probleme with diode SHG2D SHS.
I replace it by UF 4007 disponible. When we play DVD or CD it's ok,
but when we try to rebobine the tape the diode UF 4007 HS again.
Can you help me please.
2 Suggested Answers
  • 85 Answers
SOURCE: SGH2D SHS can relace it by UF 4007?
Hi All,
The SGH2D diode is rated at 200 volts 2 amps so so a replacement must match or exceed these ratings, I used a BY299 at 800 volts 2 amps i know its a bit overkill with the voltage but its working,
Thanks, John Porter.
Posted on Nov 04, 2009
My Samsung combo drive does not read or write CD but it plays DVD. It does not have DVD writer only CD writer is there.
It is likely that the laser diode for CD reading and writing has burned out. DVDs use a different laser diode. If this functionality is important to you, replacement is the only option.
Mar 13, 2011 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
I can no longer play dvd movies or play dvd games on my xbox. but it will play music cd,s.
This is probably due to the DVD laser diode being faulty. The CD laser diode is a separate diode (within the same unit). If this is the case then you need a replacement laser unit.
Mar 03, 2011 | Microsoft Xbox 360 Console
Hi All,
May 18, 2009 | Samsung DVD-V5500 DVD Player/VCR
DVD VCR combo has no power
I found out what the issue was with my Samsung DVD-V5500. It was the rectifier diode on the 15V tap of the high frequency transformer. This is the same issue that someone else with a later model V5600 had talked about. The diode had shorted and behaved like a piece of wire.
Seems to be a bit of weak point in the power supply. The issue can be diagnosed by using a multimeter to measure the resistance between the diode cathode and ground. If the meter is measuring 1 Ohm between the cathode and ground, your diode needs replacing. I just replaced it with a UF4003 diode from Jaycar, which is basically an Ultra Fast 200V 1A diode suitable for switching the high frequency (20-30kHz) output from the transformer.
The diode is located at the rear right hand corner of the board on the output of the power supply section. A picture below shows the new diode between orientated east-west between the large capacitors. The original diode that failed was an SHG2D SHS.
Sep 04, 2008 | Samsung DVD-V5500 DVD Player/VCR
Samsung dvd v5600
Check D1SS16, a diode in secondary supply near the transformer. It's probably short circuit. Replace it with an SF-26, 400V, 2A rectifier diode, or equivalent.
Feb 10, 2008 | Televison & Video
Samsung DVD/VCR Recorder
Unit dead.
Local repair shop said it's un-econimical to repair.
Admitted they had no service manual.
Said they could 'have a look' but likely repair cost would be over $300. Charged me $50 for quote. Useless Gits.
My opinion & findings.
Power supply sensative to spikes.
I Suggest a power filter in-line with unit.
Disconnected all sub-boards from main.
Hiccuping PSU (5v wobbles between 2&3V).
Replace switchmode IC & feedback IC. No change.
Eventualy identified short-cct diode as listed below.
0402-001194 Diode is a Gen-purpose 200V 2A diode. I used a 1n4007 (1A), so I expect to have to replace it in future. It's "D1S35" located very close to right rear corner of main board, part of 15V and 12V rails. Next time I'll use a 'faster', higher rated diode.
I also had no clock progression. Time could be set but would not advance. Been like that for ages - I thought it was a user clock-setting error. Identified Dead 32.768 khz crystal (XT601).
Hired manual $10 +postage
Non-faulty parts + postage $40
1 diode $1
Satisfaction, plenty.
Jan 07, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
Need owners manual.
some dvd players have two emitting diodes. one for the play back of the dvd and the other for mp3 and cd's. the emitting diode that plays the dvd need to be either calibrated, cleaned or replaced. try to clean the emitting diode with a cd lens cleaner. if it did not work, then try to calibrate it. there is a small tiny knob near the emitting diode. mark the original position of the knob then try to play with it. if nothing happens, the emiiting diode need to be replaced.good luck
Feb 28, 2007 | Pioneer HTD-330DV System
Samsung DVD-V5500 DVD Player/VCR Logo
2,048 people viewed this question
Jerry Greenberg
Jerry Greenberg
