Question about KDS Radius RAD-5c 15" Flat Panel LCD Monitor
No Sound Output on my Rad5-c
How can I get the speakers on my KDS Rad5-c monitor to work. I went through the help and it asks me to make sure the "speakers" are enabled. The problem is I don't see anything that says KDS or Rad5-c or anything similar to the monitor name. Suggestions please?
Thanks very much!
5 Suggested Answers
  • 205 Answers
SOURCE: Reinstall of windows xp
This won't have anything to do with the monitor in the control panel, you should be looking at "Sounds and Audio Devices". Did the sound ever work?
Posted on Dec 19, 2007
skotkolr
  • 558 Answers
SOURCE: Kds 700p monitor
The most common problem with LCD monitors is the capacitors that are on the power pack. the pack usually looses or pops as we say 2-6 of them after 3-5 years. its almost a certainty after 5 years. a component repair tech can replace these but unless you can find some one like me who will do it for cheap to save the landfill you most likely will buy a new one.
Posted on Apr 29, 2010
budmrtn
  • 11361 Answers
Power supply filter caps will be he first thing to check, look for leaking/bulging tops.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on May 13, 2010
budmrtn
  • 11361 Answers
SOURCE: K226WDB Monitor: I need to get the cover off my Kds K226wdb monitor...
You have to use thin flat blade screw driver to crack open the case, starting ta the bottom edge of the case and then work your way around. You can also look at YOUTUBE, just search for HOW TO OPEN LCD MONITOR.
Posted on May 18, 2010
I purchsed a new LG Monitor and installed it to my 4 year old Gateway Computer,now have no sound coming from my Bose speakers! HELP?
I answered this but the solution did not post (thanks to Verizon). When you installed the LG software, were you prompted to change any settings? The LG software may have hijacked your normal sound output to your Bose speakers
Nov 18, 2012 | LG E2242T-BN Black 21.5" 5ms Widescreen...
I have a MAG Innovision Model 468 LCD Monitor and a Compaq computer, how can I get the monitor speakers to work?
There should be a wire to connect between the speaker output of your soundcard (usually the green connector) to the monitor's speaker input. It should be a "mini" plug, 3.5mm diameter. Make sure your speakers are not muted in the audio/sound controls on the computer.
Aug 24, 2011 | Computers & Internet
I have a hp w19b moniter and everything is hooked up even the speakers. However the speakers have yet to work. I have made sure there plugged in and everything.
The speakers in this monitor require a powered speaker output, and most audio cards only provide a line level output, which is not enough to drive these.
You may need to go out and get another sound card like a creative labs or the like - but make sure the card has a SPEAKER out on it, and not just a line level output.
You may be better off simply going out and getting a set of powered speakers!
Jun 22, 2011 | HP W19b LCD Monitor
Can not get the audio to work!!
Did your monitor come with a small audio cable? Usually they have green ends. If you have one, make sure it is plugged in correctly to the matching green ports on your computer and on the monitor. Also, sometimes the volume must be turned up quit a lot for the speakers on a monitor to work. Hope this helps.
Sep 24, 2010 | KDS Radius RAD-7c 17" Flat Panel LCD...
No Sound. We moved the computer and now no sound.
Try checking to see to make sure that the audio jacks are plugged into the right ports. Also, check to make sure that nothing is muted, and that volume is up ( I've actually went for sound without a day after moving my computer because I forgot I had muted and turned my volume all the way down the day before xD )
Anyway, I hope this helps, and let me know if it doesn't.
Oh, and one last thing, make sure that your speakers are set as the primary output devices. If you have 3rd party audio drivers, sometimes you have to set what audio output is going through.
Oct 17, 2009 | Samsung SyncMaster 172 W 17" LCD Monitor
IS THERE A PLACE TO HOOK UP SPEAKER TO KDS XF 7B MONITOR
This monitor doesn't have built-in speakers. You'll have to hook up separate speakers to the audio output jack on your computer with this one.
Feb 26, 2009 | KDS Visual Sensations 7b (Black) 17 in.CRT...
No sound
  • Check the sound cable connection at the monitor and at the computer. Make sure the sound cable is still plugged into the external sound / headphone output (colored lime green on most desktop computers). The plugs must be inserted all the way; a partially inserted plug may not work for either speaker. Inspect the cable for visible damage. In particular, if it has a sharp bend at one of the plugs that was not there before, it is probably broken inside.
  • Check the sound icon in the taskbar to verify the sound has not been muted.
  • Open the Sound Control Panel and verify that the sound output is being routed to the external sound/headphone jack.
Jul 09, 2017 | Soyo Computer Inc 19" LCD Monitor, Black
Flat screen monitor
First, make sure that you have all the necessary cables connected, then make sure that they are all connected properly and tightly. Also, make sure that your computer is set to output to the correct output. If that doesn't work, then the speakers are probably broken. That's the exact reason why you don't buy stuff from pawn shops. Cheap, but crappy.
Mar 24, 2008 | Acer AL1917W LCD Monitor
Dec 19, 2007 | KDS Radius RAD-5 15 in. Flat Panel LCD...
KDS Radius RAD-5c 15" Flat Panel LCD Monitor Logo
42 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
